Question about Microsoft Xbox 360 Console
RED LIGHTS FLASHING
MY XBOX360 HAS RED LIGHTS FLASHING
  • lynchm May 27, 2008
    all for lights are flashing red when i turn on my xbox. i am very frustrated
  • Michael Wooldridge May 11, 2010
    How many of the quadrants are flashing?
  • 74 Answers
Check the cable leading to the TV is plugged in securely both ends. If it is, it is probably a faulty cable, and you will need a new one.
Posted on May 27, 2008
XBOX360 FLASHING RED
To fix the flashing red lights what you will need to do is stop the heat getting to the GPU and the CPU and to do this you can use a good Xbox 360 Repair guide or of course you can send it in.
Nov 05, 2011 | Microsoft Xbox 360 Console
My xbox360 has 3 red lights what wrong sian
Three flashing red lights means there is a hardware problem with your Xbox 360 console or its power supply.
Jul 07, 2011 | Microsoft Xbox 360 Console
I have 3 flashing red lights on the console and a yellow light on the power supply
3 red flashing lights is known as the red ring of death. Your power supply showing a yellow light is ok, that just means that your power supply is on standby. The first thing you should do is check with microsoft to see if your unit is still under warranty with this site: http://support.xbox.com/support/en/us/xbox360/LiveIDSignIn.aspx?redirectUrl=http://support.xbox.com/support/en/us/xbox360/registerdevice.aspx?step=repair
If your unit is not under warranty, go to www.wiredextreme.com. We are a console repair company based in Texas, and we can fix your console. We give a free diagnoses on your unit(excluding shipping), and will call with an estimate before any work is done on the unit. All our work is covered by a 90 day warranty, and you can buy up to 4 years worth of warranty coverage.
Nov 16, 2009 | Microsoft Xbox 360 Console
Red flashing lights ,3 flashing red lights ,when we turn it on.
this looks like a useful page to diagnose your problem:
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Oct 29, 2009 | Microsoft Xbox 360 Console
One flashing red light on xbox360 ( not red ring)
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
Sep 15, 2009 | Microsoft Xbox 360 Console
Xbox360 2 flashing red lights left side of ring
Call 1800-4myxbox
They should repair it
This is a defect that should be covered by warranty.
The soldering has come loose on the CPU.
Jan 15, 2009 | Computers & Internet
Red lights flashing
3 Red Flashing lights problem is one of the most common problem of Xbox 360. You will have to either get it repaired from Microsoft (in case your Xbox's warranty is not expired, but one thing to note is that you will have to wait for at least 3-4 weeks to get back your Xbox) or you can Fix your Xbox's 3 Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
Dec 25, 2008 | Microsoft Xbox 360 Console
3 red lights on xbox360 and screen problems
Hi there!
The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. The main thing that causes the 3 red lights to start flashing is because of overheating and as the motherboard within the console takes more heat it actually warps and bends until the solders become loose.
Once this happens you will receive the 3 red lights. Even before you get the 3 red lights you may have noticed your games freezing and this is caused in the same way, by overheating. As the chips take more heat they shut off to prevent lasting damage, although they can only do this a number of times until you get the Xbox 360 3 Red Lights.
To fix the problem you need to stop the level of heat the motherboard takes and you can do this in a number of ways, but it will involve opening up your Xbox and working on it. In addition, you could always send your Xbox back to Microsoft as they are offering free repair for this error, you will just need to wait 3-4 weeks that’s all.
Cheers!
Dec 21, 2008 | Microsoft Xbox 360 Console
Xbox360 3 red lights
YOu are having problems with the three red lights right (red ring of death)? How old is your xbox?
Dec 12, 2008 | Microsoft Xbox 360 Console
Red lighted
if its 3 red lights it has to be sent in for repair
Jan 17, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
57 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
