Question about Car Audio & Video
Hi there. I have an old KAC-9020 amp, but it is in very good condition and I wouldn't like to see it go to waste. However, the input for the amp is an 8 pin DIN cable. I could custom wire an adapter if I knew the printout for the DIN plug. Is there any way I could find that information or purchase an adapter that accomplishes this? Thank you for your time, Beau Black
  • topdown63 Jan 16, 2011
    Hello Julian,
    I have a Kenwood KAC9020 and unfortunately I don't have the plug for it either. I just found this amp in my closet with 5 other amps that have been put away for years. If you find the answer, please post it up and I will do the same.
    Regards,
    Ricky
    Problem Solver:
  • 4 Answers
Julian,
I found the owner's manual on the Kenwood website. Please visit the link below:
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/kac9020.pdf
You'll notice that the plug in the diagram is plugged to receiver/tuner/car stereo. Apparently it's a common plug/setup for the Kenwood stereos that have this type of output plug. You would just need to find any Kenwood car stereo that has this output to get the wiring of the plug if you wish to use this amp with a different car stereo. (Or just get a Kenwood car stereo that has this type of output). Good Luck.
Posted on Jan 17, 2011
I have a Kenwood KAC-9104D that will power on but not produce any sound??
Be sure the RCA cables are attached and in good condition.
Be sure the remote wire from the deck is hooked up and good.
Be sure the GAIN control is turned up.
Volume on head unit is up. Make sure BASS options are not turned off on deck.
Be sure wires are going the right way. + to + & - to -
Loose wires in the box. Make sure subs are hooked to the terminals inside box.
Check all fuses on amp to determine if 1 or more i blown.
Feb 18, 2011 | Kenwood KAC-9104D Car Audio Amplifier
What is the value of a 800 watt kenwood amp KAC 7201
depending on condition of the amp for excellent condition it would be around 90 to 125 in good condition you looking at about 60 to 90 in poor condition you are looking at 30 to 60 and in bad condition under 30 .
Aug 02, 2010 | Kenwood KAC-7201 Car Audio Amplifier
What is the p. con on the back of the kenwood 9105d?
Power control wire - tells the amp to turn on, usually connected to the blue/white or blue wire when blue/white is not present on aftermarket radios. On factory systems you usually want to hook up this connector to an acc source on the car
Jun 13, 2010 | Kenwood KAC-9152D Car Audio Amplifier
Leads for old kenwood car stereo amps
Hey wdalley69, I've got the KAC-8070. My setup has the crossover module for it.
Oct 27, 2009 | Kenwood Car Audio & Video
Does an mp3 player put out enough power for input to KAC-624 amp?
Have you connected the rca plugs to the radio or amp directly? If you've connected it to the radio make sure that the input level controls are adjusted AND available on that model (it will say AUX, INPUT, SUBWOOFER, REAR, etc.) Connecting your mp3 player directly to the amp will not have enough juice to hear sound you need to connect it to the radio first.
Oct 02, 2009 | Kenwood Car Audio & Video
KAC-9104D output terminals
This feature allows the amp to be paired to any stereo. The input may be in stereo but the amp then changes it back into mono using sound from both sides. Hope this answers your question.
Jul 23, 2009 | Kenwood KAC-9104D Car Audio Amplifier
My Kenwood KAC-929 gets power but DOES NOT put any sound out. Whats My Possible problem(s).
Hello Spicer_kyle6,
Possible problems: 1) No output from the head unit. Try a different set of preamp outs. 2) No input to the amp. Check the RCA's and make sure that they are good and coming from a functioning preamp or subwoofer output on the head unit. 3) Input gain turned off or down too low. 4) Speaker wiring shorted, grounded, or open. Check all wires. 5) Speakers defective. Connect to a known good output to test. 6) The amp itself could be defective and still show a power-on indication.
Hope this helps.
Apr 28, 2009 | Kenwood KAC-929 Car Audio Amplifier
Blinking E-03
somthing is fried on your motherboard
Apr 28, 2009 | Kenwood Excelon KAC-X811D Car Audio...
KAC-X520 kenwood 1000w amp
a red light indicates you got no power check your wiring you may not have a good ground, you need the green light to come on
Oct 09, 2008 | Kenwood KAC-X520 Car Audio Amplifier
Kenwood KAC-929
From the Input of amp, just connect cheap speaker with wires to input of amp.
If you have sound from speaker, most likely the amp is bad or loose connection.
Dec 25, 2007 | Kenwood KAC-929 Car Audio Amplifier
Car Audio & Video Logo
420 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
