Question about Samsung Microwave Ovens
I have samsung microwave oven model no.CE1031LATB....when i swich it on i get 'SE' sign in indicator , and i can not operate oven after that..what is the problem and how 2 solve it?
Ihave samsung Microwave oven model 1031LATB.when I switch on it get '5E sign in indicater and i can not operate the oven .what is the problem and what is the solution
Alex. email id:-alexvmathew@hotmail.com Mob.9496107660
Posted on Oct 31, 2012
4 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Samsung Microwave Oven shows -SE- on the display. Why?
-SE- error means you have a shorting membrane keypad.
Since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You can find your nearest Samsung-authorized service center here or call Samsung's Service Division at 800-932-3837.
Posted on Jun 16, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: faulty microwave oven
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: I have a problem with
"SE" means you have a shorted membrane keypad. It's not uncommon for it to be intermittent or partially operable, too.
On some models, you have to peel off the old keypad and stick on a new one.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
On some models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do it yourself job.
On some models, especially Samsung models, it's often economical to replace the entire controller / control box.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you have to replace the frame, you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
You can locate parts suppliers via Samsung India Support here.
Posted on Jul 10, 2011
Why does my Samsung microwave smh8165ste have error code --SE--?
SE indicates a shorted membrane switch on the keypad. Unplug the oven for a few minutes to see if it clears. If not, leave it unplugged overnight. If the problem persists, then you probably do have a switch that's bad.
Jun 27, 2014 | Samsung SMH9187ST Microwave Oven
Samsung Microwave-Oven Control Board IC corrupted. Hi, I have Samsung Micro Oven Model CE1031L/CE1031LATB whose IC is corrupted. When we called service centre,a guy came claming as samsung...
I dont understand the last part of your issue but if you get that part and put it in, you may have an issue because something caused that part to fail in the first place.
Jan 06, 2014 | Samsung ASSY DOOR;CE1031LAT/XTL, -...
Samsung microwave se error
see the video attached. God bless you
Dec 09, 2013 | Samsung MS1040BB Microwave Oven
CE1031LAT
Samsung Microwave CE1031 LAT is not working It shows the indication -SE-
when made on it gives 8888 and all signs on .
Please give me the solution
Oct 20, 2012 | Samsung Microwave Ovens
This indicates a systems error caused by a shorted membrane in the keypad.
Jun 27, 2012 | Samsung SMH7178STD Microwave Oven
My Samsung SMH8165ST Stainless Steel 1600 Watts Microwave Oven Problems
This indicates a system error, the keypad has a short in the membrane, the keypad control board will need to be replaced.
May 02, 2012 | Samsung SMH9187ST Microwave Oven
Samsung microwave se message
That indicates that the keypad membrane is shorted.
Apr 24, 2012 | Samsung SMH9187ST Microwave Oven
Samsung microwave child error/ turnd power off now se appears in window and does nothn when push buttons
SE indicates a short in the keypad membrane, the keypad control board will need to be replaced, a costly venture.
Apr 06, 2012 | Samsung 1.8 Cu. Ft. Over-the-Range...
My SMH9151W Samsung Microwave displays a -SE- or a -5E- and will not operate. I unplugged over night and still will not operate
I had the same issue on a 2010 smh9151w samsung microwave after installing it and using it with no problem for 5 days. The second time we unplugged the microwave and turned the circuit breaker off and on we didn't reset the clock on the microwave so the display shows :0 and it has been working for 7 days straight now. Fingers crossed that this is a long term solution. Hope this helps. Thanks!
Mar 20, 2012 | Samsung Microwave Ovens
I have a problem with MICROWAVE CE1031LATB. It shows error 5E or SE. It is not working at all. The local Sumsung mechanic does not know what it is. Can you please guide me? He changed the mother board...
Jul 06, 2011 | Samsung Microwave Ovens
Microwave Ovens Logo
223 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
