Question about Panasonic Elite Panaboard UBT880W Whiteboard 41 x 72 in wired USB UBT880W
Product: Panasonic T780 Elite Panaboard Problem: Device had been unplugged for 2 mths. Placed a new fresh AAA battery in electronic pen and tried to calibrate board after turning the board on. Unable to calibrate. Have tried several new batteries in pen and have cycled the power to the board. Barreries are installed correctly. How can I tell if the pen or the board is faulty? There is no fault light lit on the board.
2 Suggested Answers
SOURCE: My UB-T880 elite Panaboard is
I am having the same issue and I think it maybe a driver conflict. What OS system are you using at the moment? When my pen software was not updated, everything worked fine. I am trying to resolve it now and will post back when i have a solution.
Posted on Feb 04, 2011
PANASONIC PANABOARD UB-5338C I need a 'user's guide' for the above.
The Panasonic product page for the Panaboard UB8325 explains its features including button functions, accessories, diagrams, etc.
The instructional manual can be downloaded from the Panasonic website in several languages, Click here for the English version (requires agreement to term of use before download begins). It's a .PDF file, so you will need Adobe Acrobat Reader. It's a free download available at:
http://get.adobe.com/reader/
May 20, 2011 | Panasonic UB8325
I can not get a replacement battery for my panasonic sv-sd85,any ideas?
try www.batteriesplus.com according to the product specs located on the panosonic website it uses Ni-MH Rechargeable Battery (DC 1.2V); 1 "AAA" or a 1.5v akaline these things are everywhere. http://www2.panasonic.com/consumer-electronics/support/Audio/Portable-Audio/MP3-Players/Technical-Specification/model.SV-SD85.T#ts
Apr 19, 2011 | Panasonic E-Wear SD SV-SD85 128 MB MP3...
My UB-T880 elite Panaboard is not responding to the electronic pen. It responds to the finger however. I have changed batteries and recalibrated the board. What else could I try. Thanks Ed
Feb 03, 2011 | Panasonic Elite Panaboard UBT880W...
My replacement stylus won't work for my MousePen 8x6 tablet
Is the stylus the exact same one that came with the tablet? ( I own this tablet.)
If it is, remember to place a AAA size battery in the pen. To open the pen, simply grasp the upper and lower dark purple parts, the ones on either side of the lighter purple band, and pull them apart from each other. Place the battery negative side on the spring, twords the tip of the pen, and the positive side under the small metal hook. Replace the cover, taking care to align the sheet metal hook with the pen clip. (there is a notch there for it to fit inside of.) Now tap the pen against the tablet to wake it up. It should work perfectly. If it already had a battery in it, remove and replace it to restart the pen. If it still doesn't work, try a fresh battery.
~KenjiFox
Jan 07, 2011 | Genius MousePen 8x6 (MOUSEPEN8X6)
WHEN I TRY TURNIN IT ON IT JUST STAYS ON THE SANDISK 256MB WELCOME SCREEN HOW CAN I UN FREEZE IT?
Reset the device. 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
Power cycle the device.
The power cycle discharges excess/residual power from the player; with the use of a new battery, it should be able to power on the MP3 player properly.
STEP 1 - Remove the battery STEP 2 - Power cycle the player 1. Connect the player to the PC. 2. Leave the device connected for about 2 minutes.
STEP 3 - Turn on the device 1. Unplug the player from the PC. 2. Insert a fresh AAA battery into the player. 3. Turn on the player.
Dec 29, 2010 | SanDisk SDMX1 MP3 Player
Panasonic Panaboard UB5815 flashing with "L" Message
Recommend others do not purchase the Panaboard. Finding a repair person is like pulling teeth. When you finally find someone to repair it, the cost is almost as much as purchasing a new one.
Jun 30, 2009 | Panasonic Panaboard UB-5315
T.V. Has nopower
Try a power drain:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
If the TV still won't come on, and there is no indication of electricity getting through, the problem will be with the TV's power supply or it's cable.
Mar 26, 2009 | Panasonic CT-36SX31 36" TV
Sansa MP3 not working
Try these steps:
SOLUTION 1 - Reset the device.
SOLUTION 2 - Power cycle the device.
1. Connect the device to the PC.
1. Disconnect the player from the PC.
Jan 18, 2009 | SanDisk Sansa m240 MP3 Player
BATTERY LOW, POWERING DOWN! SANSA M240
Hey,
Try these steps, if they aren't of any help, you may have to have the vendor replace your mp3 player.
Jan 16, 2009 | SanDisk Sansa m240 MP3 Player
Panasonic Elite Panaboard UBT880W Whiteboard 41 x 72 in wired USB UBT880W Logo
98 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
