Question about Acer Computers & Internet
Removing combo lsc-24082k from an acer aspire 1355lc
  • 326 Answers
And the problem is? If U don't know how to remove, how are U going to install?
Posted on May 28, 2008
Failure to boot Acer Travelmate 243xc Ms2138
Computer does not boot up The problem maybe the RAM, it could be faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Mar 08, 2013 | Acer 20 Travelmate 240 243xc Ms2138...
Wher is wifi card located on Acer aspire 1355LC
Several models of the Acer Aspire One netbook are on the market, but each version is based on the same chassis. The method of replacing the Aspire One's wireless card is the same for each model. Though replacing the wireless card with a newer card is a simple process, opening the Aspire One and removing the original hardware may void the manufacturer or store warranty.
Place the Acer Aspire One face-down on a flat surface so that the bottom is facing upwards. Remove the six screws with a Philips screwdriver; three are located in the battery compartment, and the other three are located under the speakers. Place the screws in a cup to avoid losing them. Turn the Aspire One over so that the bottom is facing down. Open the lid so that the keyboard is exposed. Identify three small black tabs above the "F2," "F8" and "Print Screen" buttons. Depress each tab with a straight screwdriver. Lift the top of the keyboard with a straight screwdriver after the tabs have been depressed. Pull the keyboard forward towards the screen, then lift it free of the chassis. Disconnect the keyboard's ribbon connection by gently prying the plastic clip away from the ribbon with your fingernail or a straight screwdriver. Set the keyboard aside. Remove the six screws holding the top half of the Acer's chassis to the motherboard. Gently pry the chassis upwards; a series of plastic clips holds it to the bottom half of the chassis. Press each clip with a straight screwdriver until the top half of the chassis lifts free. Set it aside and place the screws in a cup to avoid losing them. Remove the metal plate covering the wireless card; it is located in the bottom right side of the motherboard and held in place with two screws. Set the plate aside and place the screws in a cup. Disconnect the wireless card by pulling the two wires holding it in place upwards. Slide the wireless card forward out of the slot it's in and set it aside. Slide the new wireless card into the slot, then plug the two wires into the new card, reversing the actions you used to remove the old card. Place the metal plate over the new wireless card and screw it in place. Place the chassis over the motherboard, carefully align it with the bottom half of the chassis, and then firmly press down onto it until the tabs snap back into place. Replace the screws into the six screw slots. Place the keyboard over the chassis. Lift the ribbon connector and slide the ribbon into the slot. Press the ribbon connector into the 'locked' position, then slide the keyboard into place and press firmly to snap the tabs into place. Turn the Acer Aspire One upside down and replace the screws that were removed from the bottom of the netbook. Not sure if this your specific laptop it might give you some insight into replacing or troubleshooting it.
Jan 28, 2013 | Acer Aspire 1355LC Notebook
I want to locate cmos battery in my Acer aspire 1355LC
The battery of a laptop is always situated at the rear side, just below the screen, when you keep the screen vertical. Or else, it is situated very close to the charging port of your lap. It may be locked by simple switches. You will understand it's operation on looking into them.
Hope this one solved your problem. If you have additional doubts, please come back to us.
P.S: If the solution is helpful, please accept the solution.
Sep 01, 2011 | Acer Aspire 1355LC Notebook
Hi, I have a problem with overheating (I think) acer aspire 1355lc notebook.... I have replaced the fan, HDD, and thermal paste, but it shuts down completely bang after just a minute.... what to replace...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 21, 2011 | Acer Aspire 1355LC Notebook
My acer travelmate 240 wont read cd's anymore. been in device manager and on dvd/cd-rom drives it has a ! slimtype COMBO LSC - 24082K
It is a pretty common fault when drive can not read one type - cds or dvds. That means you have to replace the drive. Price of the drive is not that high so that makes no sense to try to fix it. Cheapest I guess would be eBay (from what I see right now 20 dollars including delivery) but also there are plenty of on-line stores. Just use your favorite search engine to find the drive or simply go to the closest computer repair place and tell them that you want the drive replaced.
Sep 06, 2009 | Acer TravelMate 2300 Notebook
Problems in mouse usb in laptop
i had this problem with wireles mice is it wireless if so then dont buy wierless cause ive gone trough atleast5 that burned out within 1 month
Jun 23, 2009 | Acer Aspire 1355LC Notebook
Slimtype Combo LSC-24082K issue
Ok, I'm finaly done. If you open
enter any name, and the session key for our session is
315 929 620 I'll be waiting, it will work for around a hour before it expires.
You can also click on this link below
Jan 31, 2009 | Computers & Internet
Firmware Here
After you have downloaded the firmware update above,the Firmware flash utility,and the FlashFix and saved them all to the desk top.Run the firmware flash utility in step 1.(and follow the directions) (after you run it and make your back up,move on to step 2), Run flashfix in step 2 (and follow the directions)After you have completed steps 1 and 2 move onto the flash,(just click on the update firware file on you desktop and run it.(follow the directions n the screen)
Note: Firmware flash utility =LtnFw (use it for the backUp)
Step 1: Make a backup copy of your current firmware. You can do so using LtnFW. you should make this backup incase you decide that you want to undo the firmware flash, you will need a backed up firmware.
Note: FlashFix=flash fix
Step 2:The firmware flasher is checking your drive and seeingthat you have an OEM model and is thus refusing to flash it. FlashFix will patch the firmware flasher so that it will agree to flash your drive.
Note: Flash=The firmware file you downloaded
Step 3: After using FlashFix, run the flasher, make sure that you select the correct drive from the drop-down list, and flash
I hope this better explains the steps
Slimtype Combo LSC-24082K does not recognize audio/program software
  1. Click Start, click Run, type regedit in the Open box, and then press ENTER.
  2. Locate and click the following registry key: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\CDRom
  3. To enable automatically running CD-ROMs, change the Autorun value to 1.To disable automatically running CD-ROMs, change the Autorun value to 0 (zero).
  4. Restart your computer
Dec 31, 2008 | Computers & Internet
Computers & Internet Logo
37 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
