Question about JVC Audio Players & Recorders
Replacement for broken CD compartment lid latch RC-EZ53
  • 2,382 Answers
Hi, you can get the broken CD compartment lid latch for you JVC RC-EZ53 from any Radio Shack around you or by contact JVC on 1-800-252-5722 directly to ask for the nearest place around you to get the CD compartment part because it is very difficult to get the parts around....
Posted on Oct 04, 2010
2008 CTS trunk won't unlock
Hi Jeff,
I was going to say, check fuse/ jump the load side of relay Good post.
Mar 19, 2017 | Cars & Trucks
My remote is bad and the button on the door of my 2008 saturn aura xr will not open the trunk
How about a key ?
Luggage Compartment Description and Operation (Sedan)
Rear Compartment Lid Release
The rear compartment lid can be released in one of three ways:
• Inserting the key into the key lock cylinder, if equipped
• Operating the rear compartment lid release switch
• Using the keyless entry fob
To operate rear compartment lid with the rear compartment lid release switch or with the rear compartment release button on the key fob, the gear selector may be in any position, but vehicle speed must equal 0 for the rear compartment lid to release.
When the rear compartment lid release switch is pushed, the rear compartment lid release signal circuit to the body control module (BCM) is grounded. BCM then grounds the coil side of the trunk release relay through the trunk release relay control circuit. With this voltage is applied to the rear compartment lid release actuator, opening the rear compartment.
do you know how to do electrical testing ?
Circuit/System Verification
Ignition ON, observe the scan tool Trunk Release Switch parameter while pressing and releasing the rear compartment lid release switch. The parameter should change between Active and Inactive.
? If the parameter does not change, refer to Trunk Release Switch Malfunction.
Command the trunk release with a scan tool, the rear compartment lid latch should release the trunk lid.
? If the rear compartment lid latch does not release, refer to Rear Compartment Lid Latch Malfunction
You may want to take it to a repair shop .
Mar 13, 2017 | Saturn Cars & Trucks
When opening the top, it all works until it is time for the truck to close and then it doesn't.
What make ,model an year vehicle ? Could be a sensor or a control module . Some of these convertibles are very complex , could set DTC'S diagnostic trouble codes .
The hydraulic lines and the cylinders
GMLAN communication to the Body Control Module (BCM)
Open/Close request circuit to the driver and passenger window motors
Power and Grounds
Folding Top Main Power Fuse 30A
Folding Top Logic Power Fuse 20A
Ground G301 for the FTC module and G305
Folding Top Open/Close Switch (S15 and S16)
Rear Compartment Limit Switches
Rear Compartment Lid Release Switch (S3 and S4)
Rear Compartment Lid Release Switch-Front Hinge-Left (S11 and S12)
Rear Compartment Lid Release Switch-Front Hinge-Right (S9 and S10)
Folding Top Front Location Pin Guide-Left (S17 and S18)
Rear Compartment Lid Release Switch-Left (S19A)
Rear Compartment Lid Release Switch-Right (S19B)
Rear Compartment Partition Position Switch (S20)
Folding Top Front Location Pin Position Switch (S13)
Folding Top Front Latch Actuator Position Switch (S14)
Hall Effect Sensors
Folding Top Header Latch Cylinder Sensor (S1)
Rear Compartment Cylinder Extended Sensor (S2)
DTC B367F 58: Roof Stowed Ready to Latch Sensor Circuit incorrect reaction after event
DTC B367F 59: Roof Stowed Ready to Latch Sensor Circuit circuit/component protection time out
DTC B367B 58: Deck Lid Anti-Rotation Latched Sensor Circuit incorrect reaction after event
DTC B367B 59: Deck Lid Anti-Rotation Latched Sensor Circuit circuit/component protection time out
Your best bet is probably to take your vehicle to a qualified repair shop.
May 23, 2016 | Cars & Trucks
My trunk will not open. When I take off battery cable and replace, it opens once. Is there an easy fix? relay etc?
Rear Compartment Lid Release Relay
  1. Ignition OFF, disconnect the trunk relay.
  2. Test for 65-90 ohms of resistance between terminals 85 and 86.
  3. ?‡'
    If the resistance is not within the specified range, replace the trunk relay.
  4. Test for infinite resistance between the following terminals:
  5. ?€¢
    30 and 86
    30 and 87
    30 and 85
    85 and 87
    If less than infinite resistance, replace the relay.
  6. Install a 10-amp fused jumper wire between relay terminal 85 and 12 volts. Install a jumper wire between relay terminal 86 and ground. Measure for less than 2 ohms of resistance between terminals 30 and 87.
If greater than 2 ohms, replace the relay.
Rear Compartment Lid Release Relay Malfunction
  2. Verify that a test lamp illuminates between the coil side B+ circuit of the trunk relay and ground.
  3. ?‡'
    If the test lamp does not illuminate, test the B+ circuit for a short to ground or an open/high resistance. If the circuit tests normal and the B+ circuit fuse is open, test the voltage control circuit for a short to ground. If the circuit tests normal, test or replace the trunk relay.
  4. Verify that a test lamp illuminates between the switch side B+ circuit of the trunk relay and ground.
  5. ?‡'
  6. Disconnect the harness connector at the rear compartment lid latch.
  7. Ignition OFF, test for less than 5 ohm of resistance between the rear compartment lid latch ground circuit and ground.
  8. ?‡'
    If greater than the specifed range, test the ground circuit for an open/high resistance.
  9. Connect a test lamp between the trunk release relay control circuit and the coil side B+ circuit of the trunk relay.
  10. Command the trunk release solenoid ON and OFF with a scan tool.
  11. ?‡'
    If the test lamp remains ON all the time, test the control circuit for a short to ground. If the circuit tests normal, replace the BCM.
    If the test lamp remains OFF all the time, test the control circuit for a short to voltage or an open/high resistance. If the circuit tests normal, replace the BCM.
  12. Connect the harness connector at the rear compartment lid latch.
  13. Connect a 3-amp fused jumper wire between the switch side B+ circuit of the trunk relay and the voltage control circuit of the lid latch. Verify that the lid latch activates.
  14. ?‡'
    If the lid latch does not activate, test the control circuit for an open/high resistance. If the circuit tests normal, test or replace the rear compartment lid latch.
  15. If all circuits test normal, test or replace the trunk relay.
Component Testing
  1. Ignition OFF, disconnect the harness connector at the rear compartment lid release switch.
  2. Test for infinite resistance between the trunk release switch supply voltage and ground terminals with the switch in the open position.
  3. ?‡'
    If less than infinite resistance, replace the rear compartment lid release switch.
  4. Test for less than 2 ohms of resistance between the trunk release switch supply voltage and ground terminals with the switch in the closed position.
  5. ?‡'
    If greater than 2 ohms, replace the rear compartment lid release switch.
  6. Test for infinite resistance between each terminal and the lid release switch housing/case.
Could be the relay , could be the switch , could be a problem with the BCM !
Apr 17, 2016 | 2007 Pontiac G6 GT Convertible
Battery compartment latch broken
battery latches broken, battery needs replacement, you will end up forcibly removing the battery thereby doing more damage to battery latches but avoid main computer case. cannot open computer to find solution around broken latches for there are screws that needs to be removed under battery.
Sep 06, 2013 | Dell Computers & Internet
Broken latch on batter compartment Where do I find a replacement latch
You may order a replacement battery cover (the whole cover, not just the latch) in a choice of colors here.
Dec 11, 2010 | Nikon COOLPIX L18 Digital Camera
My Bose remote control RC28TI-27 (for a Bose Lifestyle 48 system) has a heavy rattle in the top portion inside of it. I want to disassemble it and see if it is an easy fix. How do I get it to split apart...
Did you find a solution? I unscrewed the screw under the battery compartment lid near the rear end of the remote. The rattle is a broken radio frequency antenna. A replacement for this ancient remote is $89 plus shipping and handling. Supposedly the Bose systems can also be programmed with some universal remotes without rf antennae.
Sep 25, 2010 | Bose RC-18S Remote Control
The door that keeps the batteries and memory card will not stay closed. Can it be fixed?
Mine is broken also. There are 2 tabs in the cover and 2 raised slots on the camera body. When you open the battery compartment, you are supposed to slide the lid forward releasing the tabs from the slots, before the cover pops open. If you don't do this, you ~will~ break the tabs (or the raised slots). Well someone who didn't know this got a hold of my camera tried to force the compartment door open, breaking the raised slots that are part of the camera body.
Take a close look at yours and figure out how this latch is supposed to work and then see which part is broken. If it's the tabs on the door you can buy a replacement door online (do a search) and have someone good with electronics install it. (requires soldering). If (like me) it's the slots on the camera body that are broken, then it's not repairable. The original parts are too small and flimsy to be repaired (designed to fail). My best idea is to find some other way to latch the door closed. I've tried a velcro strap but it doesn't hold the lid tight enough and I've looked in hardware and craft stores for some kind of latch that might work, if I could atach it to the outside of the door somehow, but haven't found anything suitable (it would have to be small but sturdy and attach to the thin plastic of the door)
I'm thinking of taking it to a jeweler because they work with very small parts and might have something that could be screwed into the plastic door and camera body.
If you know of a better fix, please let me know.
Jun 15, 2010 | Canon PowerShot A720 IS Digital Camera
Replacement part -- broken cartridge lid/latch dell aio a960
go to the dell printer website, they should be able to provide better information, if not listed, send them an email with your question through there contact page.
Apr 29, 2010 | Dell 962 Photo All-In-One InkJet Printer
Broken latch on coffee grind lid
I have drilled a small hole where the latch was and put a screw in. The screw serves as a latch and has worked fine for years.
Aug 10, 2007 | Cook's Essentials CEMB10TC
88 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
