Question about Hotpoint Ultima WF860 Front Load Washer
How do i check the filter on a hotpoint washing machine
How do iI check the fliter on a hotpoint washing machine, as the water is not drainging out and i have checked the pipe
    Genius:
  • 1,028 Answers
No filter but pump may be plugged remove front panel pump om right side ..to remove panel putty knife press hidden clips under front edge and pull panel forward
Posted on May 29, 2008
Hotpoint washing machine wf640 there isn't any water coming through when the rinse cycle is on
could be the filter at the water input location in the back of the machine. Or the screen filter at the spigot-end of the input hose....check both hot and cold. First, turn both hot and cold water off at the wall outlet.
Jan 21, 2015 | Hotpoint Washing Machines
How do I get into check the pump for blockages on my hotpoint wmud942 washing machine, the key symbol is on all the time with door locked, when a programme is running the pump starts but then when it
I would suggest you fill the washer with water externally up to below the door level and run it in one of the short wash cycles. I would assume it will progress further into wash. This would suggest the inlet water circuit has a fault. I am hoping the laundry water tap was turned on when you were running the washer.
Best to replace the inlet valve and see. Worth spending the 20 quid.
Hotpoint WMUD 942 UK Washing Machine Valve
Sep 07, 2014 | Hotpoint Washing Machines
WMUD962p not taking water
Possible the filters in the inlet of your machine (top behind) are clogged. It is simple to clean out, refit carefully. Plug off the machine, unscrew the inlet water connection just behind machine to check fine filters. The water from your wall faucet should have good pressure.
If helped, pl click.
Apr 16, 2013 | Hotpoint Washing Machines
My WMS38 Hotpoint washing machine has the wash, rinse and spin and final spin lights on but nothing happens when the start button is pressed
Assuming tap water is turned on. If there is no water intake, the machine will not start. Check for the sound of water pouring in the machine. Check the water inlet filter, if it is jammed with foreign materials such as rust deposits, small stones, soil etc. Then check for the proper functioning of inlet water solenoid valve. Sometimes the valve gets stuck.
Nov 25, 2011 | Hotpoint Washing Machines
WATER NOT DRAINGE NOT SPINING IS WELL BEKO 8227 9KG
Hi.
If the machine does not drain the parts that can be responsible are the drain system and pressure switch. Motor and control board must also be tested If machine is a front loader testing will start from the drain filter. a first action will consist in checking the drain hose at the back and checking the drain filter accessible from lower front side of your washer.
Here a page about drain and spin problems.
If you need parts or schematics see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 20, 2011 | Washing Machines
Fliter cap at front of machine leaks water
Remove filter, and thoroughly clean the seal and inside the filter housing.
If it still leaks, then you you are going to have to replace the filter seal if a seperate item, or the filter itself.
Jan 09, 2010 | Belling SGE12X Front Load Washer / Dryer
Hotpoint bwd129 how can i open the filter at
If you have located the fliter, then grasp the filter cover, and twist and turn to the left to remove the filter
Please rate my solution.
Thanks.
Jul 21, 2009 | Washing Machines
Can you remove hotpoint bwm 12 washing machine filter
Hi, yes it is. Hotpoint bwm12 is a built-in washing machine, the filter is located at the bottom (black round knob). Undo the filter by turning it to the left (please be sure there's no water inside the machine, or getas much as possible out before opening the filter).
Cheers
Feb 19, 2009 | Washing Machines
Hotpoint Ultima WF860 Front Load Washer Logo
230 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
