Question about Acer SPK 2 PCS 120W RMS 40HZ- 20KHZ BLACK 40HZ- 20KHZ, MAGNETICALLY SHIELDED, POWERED BY AC ADAPTER Computer Speakers
Acer apire 3000 a/c adaptor
I had to purchase a new a/c adaptor and am having a problem keeping it plugged in at the jack. my old one that came with laptop fit very tight this one you move the laptop and it falls out. my husband also has an acer and his cord fits tightly in my laptop as well. this is the 2nd cord i have purchased both are new and the acer brand both have the same issue. thanks for your help. Shauna
  • 23 Answers
Why did you have to buy a new adaptor? Did it suddenly stop working or was the problem intermittent?
It's my guess the adaptors are fine - very unlikely all three are bad - It's the connector in the laptop that's the problem - it's loose or was pushed too far in at some point so it can't make a tight connection. A good tech should be able to solder it on the inside. Hopefully, you can return at least one of the adaptors.
Good luck.
Posted on May 30, 2008
Broken dc jack on acer 3003ln
If the internal DC Power Jack is loose, you will have totake the laptop apart to repair it. The DC Power Jack is on themotherboard and most times it is soldered to the motherboard. That meansyou will have to desolder the old one and solder a new one in it's place. Sometimes the dc power jack sits in a slot between the bottom case and palmrestwhich hold it in place and has a cable harness that plugs into the motherboard.
Apr 21, 2012 | Acer Aspire 3000 Notebook
Does Acer 3000 have bluetooth and how do you turn
Your computer does not have bluetooth but has the option for it and has to be purchased from dell, now you can get a usb bluetooth adaptor that plugs into the usb port that you can get from best buy or any computer store even online.
I hope this does help please do rate my solution
Dec 22, 2009 | Acer Aspire 3000 Notebook
My acer aspire 3000 laptop goes off automatically. i cant even format because it goes off when i start.
You may have a faulty battery or bad power adaptor chord. Try taking the battery out and starting it just plugged with the power adaptor. If it still goes out, then try with battery and no power adaptor.
Sep 18, 2009 | Acer Aspire 3000 Notebook
Power Supply problems
hello :
Sir u are facing a probleme with your ac adaptor jack in your laptop maybe yo need to change it .
changing of a ac adaptor jack its not an easy task you will need a soldring kit & a new propre jack for u laptop
dont forget rating this post if this is not helping u tell me so i can help u further .
Aug 20, 2008 | Acer Aspire 3000 Notebook
Acer Apire 3000 no picture
u need to do a power draining process.. it is also called as hard reset process..
here the procedure to do it
  1. remove the battery from laptop by removing its battery cover
  2. remove the power cable if it is attached
  3. press the power button for 10 seconds
  4. now replace the battery and close the lid
  5. now boot up again
  6. this works for all old and middle range laptops
if this does not work for you then please post back.
Jun 28, 2008 | Acer Aspire 3000 Notebook
Acer apire 3000 dull screen
select primary display from the disply setings and select externel disply as primary
Dec 02, 2007 | Acer Aspire 3000 Notebook
Acer apire 3000 keeps freezing!
The first, best thing to do is to back up your data and do a system restore. Acer's have the restore function usually built into their acer system management software.
Restoring the computer will solve most issues. If you keep having issues after the restore you probably have a hardware error like a bad hard drive or bad memory.
Be sure to back up any important data as the restore will erase everything from the hard drive and set it back to the way it came from the factory
Nov 15, 2007 | Acer Aspire 3000 Notebook
Help! No power.
Remove your battery, then use only the AC adaptor, if is the same the problem is from your Mainboard/ check to supplier if is still warranty. So that you can claim for it.
Aug 15, 2007 | Acer Aspire 3000 Notebook
Battery will not charge
The three likeliest candidates are battery, A/C adaptor and laptop power socket. Battery ? Batteries typically last between 1.5 to 4 years, depending on design and use. They are not safely repairable by users or most computer shops despite what you may read. If you remove the battery from the laptop and can run just off the A/C adaptor then the battery is probably the cause. The next test would be to use the battery in another laptop to see if the same problem occurs there. If it does then the battery is defective and needs to be replaced. If the battery does work then it?s likely the charging circuitry in the laptop itself is defective. A/C adaptor - Even though the green LED on the adaptor is on it can still be the cause of your problem. Inspect the cord, especially the jack that plugs into the laptop. The jack typically takes a lot of abuse and it?s common for the cord to be damaged at the base of the laptop jack itself. Often the damage isn?t visible; however, wiggling the wire at the base of the jack can cause the laptop charging LED to come on and off. The only way to truly test the adaptor is to measure the voltage coming out of the jack under a load. The last part is very important; simply measuring the voltage with a meter does not accurately test the adaptor. An easier alternative if you have the option is plugging a working adaptor into your laptop. Laptop power socket - Most times when the power socket in the laptop goes it?s due to a broken solder joint or a broken socket. Inserting the A/C adaptor jack in the socket and wiggling it back and forth can often cause the charging LED on the laptop to turn on and off. If that happens then the socket or the board it connects to needs to be replaced. That requires a major disassembly and is usually beyond the typical user. Let us know if you have any more questions and please don?t forget to rate this posting.
Mar 10, 2007 | Acer Aspire 3000 Notebook
64 people viewed this question
Top Acer Audio Players & Recorders Experts
NOEL
NOEL
Are you an Acer Audio Player and Recorder Expert? Answer questions, earn points and help others
