The MENU screen keeps popping up. I can exit out but it comes back on. I thought maybe the button was stuck on my remote so i removed the batteries and it still does the same thing. The longest the screen has stayed off is 5 minutes. I do not have my cable installed yet but I do have a convertor box connected to the tv and have autoprogramed the channels more than once. While in the menu screen the options jump around. PLEASE HELP!
  • 901 Answers
You have to contact the authorized service provider as this fault
seems to be on the control processor.
Or check the menu and try to disable it. Scroll through the options.
Try looking patiently! Finally call the service provider, if no alternative.
Posted on Oct 04, 2010
TCL Blue Screen "No Media"
I have this tv, just had this exact problem and just fixed it. All this screen means is that you have pushed the "media" button on your remote and it's telling you that nothing is plugged in to your usb drive on the tv. If you plug in a usb key with pictures or video on it, you'll be able to view those from this screen. Otherwise, to exit this elusive "no media" screen, grab your remote and hit the button that says "tv" to get back to the blue screen that says "no signal" and from there, you should be able to hit the "input" button on the remote and switch between your inputs of choice. My favorite input is my apple tv plugged into hdmi 2. yay!
Dec 29, 2012 | Televison & Video
I have a small screen which appears in the middle of my main screen which is for adjusting contrast ect. I keeps popping up I can not remove it there are buttons in the front for exit ect which will not...
Sounds like the monitor menu is popping up. If so, it is not your computer but the monitor that is causing the problem. Is the monitor menu button stuck?
Aug 03, 2010 | E-Machines eMachines Desktop PC
Have a philips 42pf7320A/37 with poor menu control. It keep popping up and staying on screen,even after activate exit, it pops back up.
That's your remote, not the TV. Your Remote button is hanging. Try a Phillips universal remote replacement and see if that problem doesn't go byebye.
Mar 09, 2010 | Televison & Video
Menu keeps popping up
check remote faulty batteries/take them out see if it stops doing it also depress menu button on tv might be stuck
Nov 10, 2009 | Philips 42PF9630A 42 in. Plasma Television
Tv continues to go to menu screen (not dish menu, tv menu)
sounds like a button is stuck. Remove the battery from the remote and see if this fixes the problem
Sep 07, 2009 | Televison & Video
Menu pops up while tv is on
Isolate the problem by removing the batteries from the remote. If the problem goes away replace the remote: "CHEAP" .
If the problem does not go away, the problem is in the TV, repair the TV "EXPENSIVE" !
Aug 28, 2009 | Televison & Video
Menu Screen pops up, try to exit and goes to video 1
This could be a stuck button on the front control panel or a bad solder connection on one of the switches on the front control panel.
Aug 02, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
Jul 16, 2009 | Philips 42PF9630A 42 in. Plasma Television
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
Demo Mode wont go away!!
to turn off the demo mode on model 32af42 toshiba tv you can either press recall,exit or power buttons / if this fails enter the menu screen go to the setup menu highlight demo select stop .
Sep 15, 2007 | Toshiba 32AF42 32" TV
Televison & Video Logo
192 people viewed this question
Top Televison & Video Experts
Electro Med Services...
