Can i convert my keyboard as piano keys - Computers & Internet
  • 7,733 Answers
Here is a virtual piano that you can use with your keyboard without any installations ---->Virtual Piano.
Please post and thumb back1
Posted on Oct 04, 2010
My question is in regards to a piano keyboard..not a computer keyboard
fixya does not link to your I assume previous question. Please repost the question, mentioning in that post that it's a keyboard instrument. It would also help if you mention the make and model.
Apr 26, 2016 | Music
QS8 keyboard. Why is volume in organ mode much louder than piano mode when I switch between modes without touching volume slide?
On organ mode, in general, almost all brands of the modern keyboard, velocity setting is not enabled. Setting velocity is used to determine how much the level of the sound that follows how strongly you press the keys. It is really just to imitate the sound of vintage organs, which in the past, electronic organ technologi not use the velocity on the keys. So, how strong / slow we press the keys, the sound level will remain the same.
At the Piano mode,modern keyboard using setting velocity. This also to imitate an acoustic piano, which, if we press the keys slowly, the sound level will be slow as well, and vice versa.
So, in your case,at the same volume slider, try to play on the organ modes, note level. Moving to the piano mode and press the keys securely powered (full power). Then the sound level should be equal to the organ mode.
On modern keyboards, also included organ sound that added velocity setting. Usually found on the user bank.
Sep 01, 2015 | Alesis Music
Alesis QS8 keyboard. The volume of the organ is much louder than the keyboard when I switch between both modes without touching the volume slide. How can I fix this.
How do I fix a stuck piano key on a upright home piano
You'll likely need to try removing the keys, so you can see if something is stuck underneath it. That would be my first move.
In order to do this, follow these steps:
The front panel and the keyboard fall are designed to be easily removed for tuning purposes anyway.
To check it out....The front panel likely has a little clip either side near the top on the inside. Just undo these clips and lift the panel out. The keyboard fall should then be easy to lift out too.
There may be a long wooden rail which you need to take out also. Once inside, the keys themselves can be carefully lifted off the central spikes on which they sit.
Remember how you did this so you can get them back in again.
Since your piano is so old and worn, Often times, the wooden rail in front of the keys (just above your knees when you are playing) bows inwards a little due to age and temperature/humidity fluctuations. This then causes the little white front bit of the keys to jam against the wood and you have to physically lift the keys back up to return them.
If this is the problem you will need to take out the keys and shave some wood off the inside of this rail to allow the keys to move up and down freely again.
Or sometimes you may find you have a small object caught under a key or two. Much simpler to remove and free up your keys, if this is your problem..
Hopefully, this is all you will find wrong with your piano.
If all else fails...
I wouldn't attempt to tune your piano by yourself. I would seek out an experienced piano tuner for that.
But it is worth attempting to repair it first before you go that far.
Good luck !!
Feb 26, 2015 | Music
Do they still make the Yamaha CP-300`s
NO - try the
  • Yamaha CP4 Digital Stage Piano which replaced it.
  • A Roland Digital Piano
  • NORD
Apr 30, 2014 | Yamaha Cp300 Cp 300 88 Key Keyboard Piano...
Midi vs. Sound
Think of MIDI like the old time player pianos where you put a roll into it and the punches on the paper roll told the piano what notes to play. MIDI is a way for computers and musical instruments to communicate what is being played. When you plug your keyboard into your computer and enable it in Cakewalk, then Cakewalk records what notes you are playing on your keyboard (makes a piano roll file). Then when you tell Cakewalk to play this file back it communicates to your keyboard and says play these notes just like a person was sitting there playing these notes. The distinction here is you are recording and playing back your performance (which keys you pressed, how hard you struck the keys, how long you held the keys for sustain, etc...). No sound is actually being recorded, just the PERFORMANCE. When you play it back, the keyboard regenerates the sounds on the fly just as if you were actually sitting there performing the music again. Same thing applies to other MIDI enabled instruments (drums, guitar, saxaphone, etc...). This opens up all kinds of possibilities, you can redirect the recorded MIDI file to a completely different sound or instrument. Example... you record MIDI of you playing piano song, then you have Cakewalk play this MIDI back to your keyboard but you change the sound on your keyboard to guitar, it will play the same song, but now you will hear guitar instead of piano. Get it?
Feb 02, 2009 | Cakewalk Music Creator 2 for PC
I wat tolearn the pianowith my key board
I am not sure you can learn the whole number of octaves available on a piano but here is a keyboard game and a small virtual keyboard
http://piano-game.freeonlinegames.com/
http://www.bgfl.org/bgfl/custom/resources_ftp/client_ftp/ks2/music/piano/index.htm
Jan 10, 2009 | Computers & Internet
Ensoniq MR-61 keyboard
reset that piano by giving it 20 min with power!!
plz aret this post
Aug 21, 2008 | Computers & Internet
Computers & Internet Logo
213 people viewed this question
David Payne
David Payne
