Question about Texas Instruments TI-89 Calculator
Won't turn on batteries good - Texas Instruments TI-89 Calculator
  • kakima Oct 04, 2010
    TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and hold the diamond key. Press and hold the + key for a few seconds and see whether the screen becomes legible. If you go too far, use the diamond and - keys to lighten the screen.
    Does this help?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Receiving no response in over five months, I assume the suggested contrast adjustment solved the problem.
Posted on Mar 28, 2011
Automotive electrical problem
Daniel, If battery is known to be good, could be bad connections at battery, starter/solenoid, or ground on engine/frame, battery cables also could be bad with build up of corrosion internally. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Engine Won Crank or Start
Diagnostic flowchart for car that won start or stalls Troubleshooting for...
No Crank No Start Diagnosis EricTheCarGuy
Aug 21, 2016 | 1988 Ford F 150
I have a 95 honda civic ex,wont start.ran fine yesterday,wont start this morning.battery is fully charged,new cap and rotor.would do u think might b my problem
if it wont turn over 1st check the ground s on the car and the battery 1st. your battery can be fully charged and the car will not start even over night this can happen. then look at the starter. Note: if you have over 109K on the car and the timing belt has never been replaced you will need to have this checked as well.
Aug 16, 2014 | Cars & Trucks
Engine won't start
Check to make sure you are getting voltage to the small post on the starter solenoid when the key is turned to the "crank" position. if so, check all of you connections on the battery cables. If your connections are all good, your cables are in good shape, and you still do not get the starter to crank, I would have the starter removed and tested.
Apr 21, 2013 | 2004 Toyota Tacoma
My truck won't start battery is good y won't it
how can anyone help you with out knowing what our working on..
Jan 21, 2013 | Cars & Trucks
It won't turn over
Try this procedure:
Check the battery like this:
Turn on the headlights, then try to start the car.
If the headlights do not dim or go out, then the battery is likely ok.
Check that the battery cable plus post, goes to the starter, Minus post to a good ground, like the engine.
If wiring is ok, then look at the starter solenoid for a good connection, and proper voltage at the starter.
Problem is most likely the Solenoid's bendix gear or starting relay, Have someone bang on the starter while you try to start the car. This usually works by dislodging the bendix gear..
Hope this helps.
Jul 27, 2012 | 1994 Oldsmobile Cutlass Ciera
My Volvo s60 won't start replaced battery and starter and still won't start battery test fine what can I do I have good power throught out
you will need to try to turn the engine manually to make sure its not frooze. if it turns then you might need to check the starter again.
Aug 28, 2011 | 2001 Volvo S60
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
94 vette won't start,bat good,have org. key,fuses ok,high beam light on lights off,lcd cluster won't light up?
Disconect the battery and ECM for FOUR DAYS then reconect the ECM and BATTERY. Let it sit for another four days without turning anything on. It should start but will run rough for about 200 miles as the ECM relearns the system. I had the same issue and that is what fixed it.
May 14, 2009 | 1994 Chevrolet Corvette
Texas Instruments TI-89 Calculator Logo
21 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
