Question about HP 9250c Printer
I'm forget admin password on hp 9250c. Please, how recovery admin password.
Cold reset for HP9250C
A cold reset resets the values of permanent storage variables to factory default. Often this is necessary
for clearing the HP MFP Digital Sending Server IP address.
The following items are cleared during a cold reset:
Embedded Jetdirect IP address
SMTP IP address
LDAP IP address
Embedded Web server password
All control-panel configurable items
The following items are NOT cleared during a cold reset:
Local address book e-mail addresses
Real-time clock (date and time)
Page counts and maintenance counts
Product serial number and formatter number
Service ID
Event log
To perform a cold reset
1. Turn off the digital sender.
2. Turn on the digital sender.
3. Immediately after turning on the device, press and hold down the #6 key (do not wait for the memory-count). When the three status LEDs are illuminated, release the #6 key.
4. Press the #3 key four times until the display shows COLD RESET.
5. Press the #6 key once to initiate the cold reset. The product will continue its boot-up sequence.
Posted on Jan 29, 2011
Forget Admin password in Windows 8
If you can sign into your Windows 8.1 using another admin account, you can also reset password to login Windows 8.1 free from the command prompt. Go back to Windows Password Recovery tool if you don't have another admin account. Press "Win Key+R" and type "cmd" in the "Run" command box and hit enter to open command prompt. Type the command "net user UserName NewPassword", in the command prompt and hit "Enter".. If you want to remove this password, just replace NewPassword with *.
May 05, 2015 | Microsoft Windows 8.1 - Windows
I am looking for a twain driver for a HP Digital Sender 9250c Scanner
here is the site for the driver
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=3330760&taskId=135&prodTypeId=15179&prodSeriesId=3330619&lang=en&cc=us
Just be sure to select the operating system you are using and download the software.
Hope this helps!
Don't forget to rate;)
Gary
May 18, 2011 | HP 9250c
I forget my hp pavillion password i had it on storage for sometime
If its a XP operating system on you laptop then you can boot to safe mode by tapping f8 key when the laptop is powering on and in safe mode choose admin account and once logged in can go to user accounts from control panel and under user account select the profile for which you have forget the password and click manage account from there you can change or clear the password
note : by default there would be no password for admin account
in safe
Vista or Windows 7 OS you can try doing a restore if the password was expired then it will ask you to enter a new password if not reinstall of the OS is the solution
if the NB goes with Recovery partition then you can reinstall the OS from it
keep tapping the f11 key when the NB is booting and it will take you to recovery screen follow on screen instructions this will FORMAT the hard drive and then re-installs the OS
Aug 22, 2010 | HP Pavilion dv9000z Notebook
Cant remeber adminisrator password /think it was changed by teenager
If you are referring to your Windows user account password then you can try the information below.
You can start your computer is safe mode, you can do that by pressing the F8 key will you boot the computer.
Then you select the ADMIN account, if the admin account is password protected then you need to contact the computer manufacturer since that password is created when they install the Windows on your computer.
If there is no password then you are lucky then you can remove or change the password for your user account, just open the control panel then select USER ACCCOUNT and select your user name then you can change or disable the password.
You can also search you utube or google on how to reset forgotten password.
http://www.wikihow.com/Log-on-to-Windows-XP-if-You-Forget-Your-Password
Jul 12, 2010 | HP Mini 1035NR Notebook
I forgot my password on my computer
I know a windows password recovery tool called windows password buster. This software could help you recover the password.
Nov 28, 2009 | HP Computers & Internet
Wants to reset 3824 3com switch via console
You forget the password for the "admin" user account and can no longer perform important management operations. solution.gif Use the password recovery method outlined below to define a new password for the "admin" user account:
  1. Access the Command Line Interface from the console port and enter the user name "recover" and password "recover" to place the Switch in password recovery mode. The Switch remains in password recovery mode for a maximum of 30 seconds, before it returns to the CLI login prompt.
    note.gif You must use the console port to recover the passsword. If you attempt the recovery method using the network, the password will be rejected.
  2. Perform a hard reset on the Switch whilst it is in password recovery mode by switching it off, waiting a few seconds, and switching it on again.
    note.gif You cannot use a soft reset operation to reset the password of the "admin" user account. This will end the password recovery procedure and return you to the CLI login prompt.
  3. When the Switch has rebooted following the hard reset enter a new password for the "admin" user account.
Mar 05, 2009 | 3Com SuperStack 3 3824 (3cr17402-91-uk)...
HP Digital Sender 9250C Color Scan Problem
We purchased 2 HP scanners 9250C and have the same issue. Send it back to HP, they make some correction for firmware, after 1 day, everything is ok.
Dec 06, 2007 | HP Digital Sender 9250c scanner Printer
HP 9250c Printer Logo
5,285 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
