Question about Gaggia Coffee Makers & Espresso Machines
Hi we are using a gaggia platinum vision, and it's not making coffee,it goes thru the procedure but nothing comes out.Sounds as like it is straining a bit the at the end of cycle it displays PRIME WATER CYCLE ???
    President:
  • 1,618 Answers
Sounds like the coffee is ground too fine or the screen in the brew unit is blocked.
Posted on Oct 04, 2010
Coffee coming one side only of spout
There are two ways to overcome this uneven drip of coffee into the cup.
1- Make sure the machine is placed on a level counter top. The coffee drips as a gravity flow. Machine placed on a tilted surface will allow coffee flow more on the tilted side.
2- It appears the coffee faucet outlet has not been cleaned/flushed with any coffee cleaners or descaling solution. Clean the coffee outlet as following:
* Prepare two or four cups of Baking soda solution.Fill the Baking soda in water tank and make few espresso, using the preground cycle.
** Then use two to 4 cups of descaling solution and repeat the process making several espresso.
Oct 14, 2014 | Gaggia 74845 Platinum vision coffee maker...
Gaggia platinum vision
Seems that the valve stuck in wrong position. Try to start cleaning mode.
May 20, 2014 | Coffee Makers & Espresso Machines
Gaggia Platinum Vision no power
You are correct it could be any of the possibilities you have mention.
It is worth checking the two thermal cutouts on top of the boiler.
These can be accessed by removing the top cover only.
If you press the center of the resets and you hear a click you have found the fault
Jan 22, 2013 | Gaggia 74845 Platinum vision coffee maker...
My Coffee Gaggia Vision is grinding and the coffee is coming out very weak. The billet coming out is very wet and small. Any solutions or ideas?
see this matter causes:
Make sure there's water in the unit's water tank.
  • 2 Unscrew the shower disk from the top of the unit and rinse it. Dry the disk and screw it back in place.
  • 3 Replace the coffee grounds with properly ground beans. Coffee beans that are either too finely or too coarsely ground will adversely affect the flow of coffee from the machine.
  • 4 Make sure the coffee in the filter is not packed too firmly if the coffee isn't flowing at all. If the flow is too fast, tamp the coffee down a bit more with the tamper.
  • God bless you
    Jul 18, 2012 | Gaggia 90950 Platinum Vision Espresso...
    What does wrench on screen of gaggia platinum vision indicate
    I found a failing power supply board can cause the 'wrench' error code even in standby. The board is available for about $65 online and works in many Saeco models as well.
    Jul 18, 2012 | Gaggia 74845 Platinum vision coffee maker...
    Gaggia platinum stays in warming mode
    Mine had the same problem, try resetting the two thermal cut-outs on the boiler. They are little dark grey switches that look like jumpers nested between the 4 cables going into the boiler. If they pop back when you press them, you have it.
    Jan 14, 2012 | Gaggia 74845 Platinum vision coffee maker...
    NEW GAGGIA PLATINUM VISION GRINDER NOT WORKING ANY WAY TO FIX THIS?
    If it's new send it to a service centre.
    These grinders are failing and can also damage the power supply board.
    Dec 29, 2009 | Gaggia Platinum Vogue 90800 Espresso...
    Gaggia platinum vision grinder not working
    The grinder is faulty,take the unit to a service agent for repair
    Dec 29, 2009 | Gaggia Platinum Swing 2-Cup Coffee Maker
    Coffee Makers & Espresso Machines Logo
    661 people viewed this question
    Top Gaggia Coffee Makers & Espresso Machines Experts
    Henry  Thomas
    Henry Thomas
    Shehu Pro
    Shehu Pro
    Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
