Question about Cobra Microtalk 100 FRS Walkie Talkie Radios 2 Pack
I recently bought a cobra Micro Talk PR560 at a second hand store . I replaced the 4 aaa batterys. and pressed the off/on button on the top right side, but nothing happens ? Is there some kind of lock out or fuze internally that may be bad? Dan
2 Suggested Answers
micromatikal
  • 2777 Answers
SOURCE: have Cobra Micro Talk Walkie Talkies and have lost
This was extremely difficult to find but I have located the manual for you on these walkie talkies. It will be easiest to just use the manual and follow the instructions. If you still have questions or problems please respond here and I will get back to you. Please rate my answer 4 thumbs up here on the site, it is very important to me. I would be forever grateful. Here is the manual:
http://www.cobra.com/downloads/manuals/PR4000WX_manual.pdf
Posted on Oct 12, 2010
Whats the voltage maximum on the cobra walkie talkies
Most lithium small radio batteries are 3.6 volts. If AA or AAA batteries, multiply by 1.5 volts. 4 batteries = 1.5 * 4 = 6 volts MAXIMUM. Rechargeable batteries are 1.2 volts. Your charger would be a much higher voltage because it takes power to "push" the charge into a battery. You didn't say, so I am assuming you want to operate the radio with a wall charger. I've done this by soldering the wires to the battery contacts. You need a higher voltage than 3.6 volts, but milliamps is more important. You need enough milli amps to get the radio to transmit. Too much and it frys, literally. So, this is all on you to decide if the risk is worth it. I use a 5-6 volt power supply set on no more than 1 amp (800 ma is my favorite size) 1 amp = 1000 ma. Let us know if this helped!
May 20, 2016 | Cobra FA-CG Micro Talk Walkie Talkies
I bought a Cobra 16 mega pixel digital DCA1650 and the battery that came with it does not fit i believe it is the wrong battery where can i find the right one?
Doesn't it just take two standard AAA batteries? They should be available at just about any department store, drugstore, electronics store, office-supply store, or supermarket.
Dec 03, 2013 | Cobra Cameras
Cobra frs 132 talk button not woking
The first radio has the transmit code set improperly.
Dec 15, 2012 | Cobra Radio Communications
I have binatone 100 walkie talkies. they have power to them but we cannot talk into them, they just keep bleeping when we try and talk. any suggestions?
  • Have you checked your batteries? This radio will not transmit with to low of batteries but it will beep every 15 seconds or so. This radio utilizes AAA batteries.
  • The other thing this could be is your pressing "Call" rather than "Talk." That's called "call paging tone." So make sure you press the "Talk" button when you want to transmit your voice because if you press "Call" you will only send a 2 second beep.
Regards, Tony
May 02, 2011 | Radio Communications
Have (2) Cobra 22 channel Micro talk radios that both just quit together. Only get static when tring to talk on them. Have (4) AAA rechargable in each one that show they are charged up. Both quit at the...
  • It is odd to see them both quit just like that. Were you messing with the buttons on one of them when it just quit? Did you happen to change one of the privacy channels on a main channel? The privacy channels isolate a main channel so you can talk on a channel without everyone with a radio hearing you. Make sure the channels on both radios are on only the channels and that no CTCSS or DCS code accidentally got added onto a channel. You should be able to tell by just looking at the screen and you will see the channel you are on and will also indicate a CTCSS or DCS code. Should you see either of them then remove them and retry the radio on a plain channel only.
  • Should this fail the you have got some major internal malfunction that happened to happen at the same time and it is time to invest in a new set of radios.
Regards, Tony
Apr 30, 2011 | Cobra 18-Mile, 22-Channel FRS/GMRS 2-Way...
My watch is stuck on military time somehow. I would like to know how to change it back to normal time. My watch is a Armitron Alarm/Chrono WR 165 sports watch. The number on the back is 45/6915. Thanks for...
Welcome to Fixya,
The Armitron WR165 is a digital watch that includes a 24-hour alarm, hourly chime, stopwatch feature, countdown timer and is water resistant up to 165 feet. With a rubber wristband and rugged style, the watch is meant for outdoor enthusiasts and athletes. The WR165 can be found online, in some sporting supply stores and in certain department or general home stores. Setting the Armitron WR165 only takes a few steps to perform properly.
1 - Push the top button on the left-hand side of the watch until the seconds flash on the display.Press the top button on the right-hand side to zero the seconds.
2 - Push the bottom button on the left-hand side of the watch until the hours flash and then the top button on the right-hand side of the watch to increase the hour on the watch display. Note that "PM" will appear on the watch display for PM times, but there is no "AM" indicator on the display.
3 - Press the bottom button on the left-hand side of the watch until the minutes flash on the display.Press the top button on the right-hand side of the watch to increase the minutes on the display.
4 - Repeat to set the month, date and weekday on the watch. Press the top button on the left-hand side of the watch to return to time mode.
5 - Press the bottom button on the left-hand side of the watch to enter the stopwatch mode. Press the top button on the right-hand side of the watch to start the timer. Press one more time to stop timing. Press the top button on the left-hand side of the watch to reset the stopwatch to zero and the bottom button on the left-hand side of the watch to return to time mode.
6 - Press the bottom button on the left-hand side of the watch twice to set the alarm. Press the top button on the left-hand side of the watch until the hours flash on the display. Press the bottom button on the left-hand side of the watch until the alarm number flashes. Press the top button on the right-hand side of the watch to choose Alarm Time 1 or Alarm Time 2. Push the bottom button on the left-hand side of the watch again until the hours flash. Push the top button on the right-hand side of the watch to choose the alarm hour, followed by the bottom button on the left-hand side of the watch to change to minutes. Press the top button on the right-hand side of the watch to advance the alarm minutes. Press the top button on the left-hand side of the watch to set the alarm time and the bottom button on the left-hand side of the watch to return to time mode.
I hope this will help you.
Thank you for usinf Fixya.
Feb 21, 2011 | Watches
How do you replace the battery
Battery Installation
Battery Compartment Cover
1) Grip the front of the mouse (the end with the buttons) with your left hand.
2) With your right hand hold the back of the mouse (end opposite the buttons) with your thumb on the bottom, and your index finger and middle finger resting on top.
3) Grip the mouse firmly, pressing down slightly on the GE logo on top of the mouse with the index and middle finger of your right hand, then pull back to release the battery cover.
4) Set the battery compartment cover aside. Insert 2 AAA batteries, being sure to match the polarity of the batteries with the polarity markings inside the battery compartment.
5) Replace the battery compartment cover.
6) Re-link your mouse. See Section 5.
Dec 10, 2009 | GE Wireless Optical Mini Mouse 3087897985
Press
Have you tried to reset the calculator?
From page 671 of the TI-84 Guidebook:
To reset the calculator:
1) Remove all AAA batteries
2) Hold down the On button for 10 seconds
3) Reinsert AAA batteries
4) Turn the calculator back on.
Note: When you reset your graphing calculator, the contrast sometimes changes.
Nov 05, 2009 | Texas Instruments TI-84 Plus Silver...
How do you change batteries in the wireless optical minnie mouse?
you will need two new AAA batteries, then:
e264c6a4ce3d69934c8bb459d43674dc.png e264c6a4ce3d69934c8bb459d43674dc.png 3c999630ea1690918771a6d53ee37f35.png4. Battery Installation Battery Compartment Cover 1) Grip the front of the mouse (the end with the buttons) with your left hand. 2) With your right hand hold the back of the mouse (end opposite the buttons) with your thumb on the bottom, and your index finger and middle finger resting on top. 3) Grip the mouse firmly, pressing down slightly on the GE logo on top of the mouse with the index and middle finger of your right hand, then pull back to release the battery cover. 4) Set the battery compartment cover aside. Insert 2 AAA batteries, being sure to match the polarity of the batteries with the polarity markings inside the battery compartment. 5) Replace the battery compartment cover. 6) Re-link your mouse.
Aug 18, 2009 | GE Wireless Optical Mini Mouse 3087897985
Radio Communications Logo
536 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
