Question about kawasaki Full Suspension Mountain Bike Men
Need to know how remove thee seal that behinds the small sprocket 00Kdx 200
    Problem Solver:
  • 15 Answers
Where pedals are or rear wheel ?
Posted on Oct 04, 2010
Setting timing marks
Mr. RAGSDALE.
I do not know if you did strip the belt yet or not. If you did not,I will advise you a just easy and good way to do it yourself. String for the stripping,you just remove the outside belts and pulleys,remove the plastic covers of the timing belt. Just put on the crankshaft the pulley bolt and slowly slowly turn the engine until you see all the marks aligned. On the Camshafts the two sprockets do have the letters "E" and "I", E= Exhaust and I= Inlet.means that the inner to dashboard side is the inlet cam and to the vehicle front the exhaust cam. These two cams with the letters must be aligned,with the crankshaft sprocket
having on the side a small groove which mus be aligned with a small point ball behind the sprocket on the cylinder block. There are your marks. Loose the tensioner and remove the belt.
Good Luck!
Mar 10, 2014 | Mazda MX-3 Cars & Trucks
Ive got a oil leak from behind the front sprocket can you help
What model is it? If you are fairly good with the spanners you can remove the sprocket and often replace the seal from the outside.Drain the oil and prise out the damaged seal carefully and fit replacement using a socket as a drift, carefully tapping it into the recess. This should stop the leak. Replace sprocket, fill up with correct amount and type of oil for your specific machine and away you go.
Mar 03, 2011 | Honda VF 400 F Motorcycles
I need to know how to put a new oil gasket 1986 honda xl 100cc. is it as simple as taking out the bolts that hold it on and slide in a new gasket? Thanks
If it is on the right hand side of the bike then yes. Remove the clutch cable by undoing the adjustment nuts on the engine side of the cable and unhooking from the lever. Remove the nut on the gearshift pedal and pull of the pedal. Remove the dipstick. Undo all the nuts on the cover, and remove it. Locate the new gasket on the engine. There are 2 locating dowels so it should not have diffyculty staying in place. Replace the cover and clutch cable and readjust the clutch cable.
On the left hand side of the engine is a bit more tricky as the oil is not leaking past the gasket on the cover itself. There are 2 places where it can leak from. One is behind the drive sprocket. Remove the cover. Undo the nut on the sprocket. Bend back the tabs on the locking plate and remove the sprocket. Drive a self tapping screw into the shaft seal and pull it out with a pair of pliers. Drive a new on back in place. Also see this : http://www.fixya.com/motorcycles/t5649906-1996_yamaha_yz250
If the leak is from behind the alternator you will have to remove the magneto. This is diffycult as you need a puller to get the flywheel off the crank. Then the alternator assembly and only then will you be able to reach the shaft seal. This can be removed as per the previous link.
Aug 18, 2010 | 1986 Honda XL 125 R
Oil leaking from the back of primary case
There are several things behind the inner primary case that could be leaking. There is a seal behind the inner primary where the transmission mainshaft goes into the primary. This seal sometimes starts to leak. Also, there are seals in the transmission in that area. The final drive gear seal is the big seal right behind the front final drive belt pulley. Somethimes this pulley wears on the splines of the final drive gear and it loses tension on the "quad seal" on the final drive gearshaft.
You'll nee some special tools to get to this area. You'll need sockets to fit the compensator sprocket nut and the clucth nut. You'll need an airwrench, a primary locking bar, and a torque wrench that will pull 150-165 ft. lbs. torque in forward direction, 68-80 ft. lbs. LEFT-HANDED on the clutch nut, a primary locking bar, a final drive sprocket locking device, a mainshaft nut removal tool, and some seal pullers and installers. Good Luck.
Apr 22, 2010 | 2004 Harley Davidson FLTRI Road Glide
Ktm output shaft oil seal
if you are lucky there is a clip behind the front sprocket remove both then pop the seal out drain gear box oil first though. if not which i think is most probable the engine will need splitting if you are good with spanners it is quite easy being a 2 stroke .in brief remove engine remove bore and carb in one lump remove sprocket gear lever split g-box .seal up push old seal out, from outside in, fit new then reverse prosses. a good manual will help.
Feb 12, 2010 | 2005 KTM EXC 250
95 touring bike. leaking bad at primary and on the belt.my guess is the mainshaft seal. now my service manual showes an oil seal being installed on the shaft without removing the sprocket. could this be...
more likely trans seal or inner primary seal and may as well change the starter seal while you got it open im not sure what seal you speak of but you got a lot of tear down in front of you and youll need a special socket for the trans pulley
Feb 07, 2010 | Harley Davidson Harley-Davidson Motorcycle...
Front sprocket oil leak
Get a new seal before taking the sprocket off. Remove the sprocket cover plate. You will see two small bolts holding a lock plate on the sprocket. Remove the bolts, lock plate and sprocket. Clean the sprocket shaft so the new seal is not damaged when installing. Now just pry out the old seal any way you can with a screwdriver and small hammer. Install the new seal flush with the casing.
May 20, 2009 | 2005 Suzuki RM-Z 450
kawasaki Full Suspension Mountain Bike Men Logo
48 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
