Question about Fisher and Paykel GWL11 Top Load Washer
My machine is not spining &also pump is not pumping out water has a burning smell too.
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now turn the machine off at the wall and do not use the machine until it is repaired as the control module might short out and then the repair will be expensive.Now bail some of the water out of the machine with a small bucket or pot , enough so you lean the machine back against the wall so you can look under the machine without the water pouring out onto the floor.Now when you can look under the machine look to the front right and you will see a black fan.This is your pump.Check the pump for corrosion with a torch.Turn the fan a few times to see if it is jammed.The fan should turn freely.Please reply on the pump condition and if you have loosened the pump by turning the fan.Looking forward to your reply.
Posted on Oct 04, 2010
Hello I have a Fisher and paykel 7.5g smart drive excellence washing machine it doesn't spin and I can smell something burning.thanku Kelly
Has it drained the water out. It will not spin until completely empty. If it is not draining then Iwould say the burning smell is the drain pump overheating. Do not try to run it like that as the drain pump will short out the main control board eventually. Bail the water out by hand, tip the machine back against the wall and check the pump on the front right side of bowl. Replace the pump.
Jan 04, 2017 | Fisher and Paykel Washing Machines
My LG washer stopped mid-load at spin cycle, how can I fix this?
It sounds like a serious fault if there is no power the fuse has gone or some item has burnt out . You will have to arrange for a service engineer to look at it more closely.
Apr 28, 2015 | LG WM-2277HW Front Load Washer
Intermittent Draining and Burning Smell
The water will not run in the machine.It will for a few second then stops. What could be the problem?
Aug 15, 2012 | Fisher and Paykel GWL11 Top Load Washer
TOP LOAD KEEPS WATER IN FROM RINSE CCLE, ALL OTHER FUNCTIONS WORK FINE, SMELLING BURNING ELERICAL SMELL.
Your pump is not working because it is not extracting the water. You are right with the smell of burning electrical. Depending on the age of the washer it might cost more to repair than purchase a new one. There could be a leak somewhere because water got to the wires and maybe shorted the pump. Good Luck
Jan 07, 2011 | Washing Machines
Washer won't drain and burn't smell
Hiya,
this sounds like a pump issue once the pump becomes blocked it is unable to spin freely as intended leading to a burning smell the burning smell comes from the pump motor which is still trying to spin & do its job but will be locked in place.. if you are going to try to fix this yourself you will need to shut off all power to the apliance then open it up when you have located the water pump you will see a small fan looking part if you can NOT spin that with your fingers then the water pump has siezed & will require replacing.. you will often find a blockage somewere has caused the problem so if the fan on the pump can be turned by hand then you may just need to clean the pump before continuing..
Always remember you should seek the help of a qualified enginer for your own safty but you can check these points to avoid a coslty call out charge.
Hope this helps
Apr 22, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer not spining burn smell
belt burrt out advise new belt or new machine
Jul 12, 2009 | Maytag LAT3600A Top Load Washer
Maytag SAV 3652 AWW Washer: During spin cycle, burning smell occurred while making unusual noise. (For months, major squeaking during agitation).
Bad water pump. Replace water pump.tip machine back,Look under machine, remove belt, turn pump by hand, if not spinning freely replace pump.
Mar 23, 2009 | Maytag PAV2300 Top Load Washer
Maytag washer stop spining and smell burned
two main things pump and motor pulley.the motor pulley on admiral designed maytags is plastic and melts and causes belt to burn.also pump pulley spot welds break causing pulley to drag.tip machine so rests on wall in back and you can inspect from there.hope that helps God bless ,tom
Jan 04, 2009 | Maytag Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
24 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
