Question about Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel gwl 11 burning smell on rinse cycle
I was reading your response to a couple of emails, do you really think the motor is bad? The unit will run and spin, its actuating the motor, is there some other part related with the motor that could be causing the problem?
I was impressed with how well the unit cleaned and spin dryed much of the water out of the washed clothes reducing the drying cycle. Is the product really a throw away product pretty much when it breaks? I paid quite a bit for the washer and I am a little bit suprised that this is the second time that it has broke in less than 4 years. First it was the cold water solenoid, now possibly the motor. Is there a better washer out there with a fast spin cycle that would be more reliable.
Thank you,
Louis Carriveau
  • 868 Answers
There are more problems than you should have to deal with.This company has left a endless number of customers hanging and yes, it's expensive.Why put out money for something that shouldn't have failed this soon in the first place.Red flag any time a service is needed and following is a completely  is a  different problem.
Posted on May 29, 2008
How do you ascertain if its drain pump or faulty controller board causing a fault 37 on a gw612?
Read the answer in the link below first, but in your case it can also be a faulty or blocked diverter valve. If you are good with a multimeter check the resistance of the pump windings. It should read around 33 ohms. It is not uncommon for the pumps to cook themselves and you can smell and see the burned out motor. I hope this is of some help
Jul 24, 2015 | Fisher and Paykel Washing Machines
Gwl 11 wont rinse or spin
(00000101) Phase 1 - Communications Fault
The Display Module has had difficulty communicating with the Motor Controller.
Primary Source: Display Module.
Action: Turn off at the wall and on again after 5 seconds and try again.
1. Undo 2 screws at the back
Check connections of the 12 way harness for bad contacts,
corrosion etc.
2. Check for moisture in the console area. Dry out if necessary
2. If still faulty, replace the Display Module
3. If still faulty, replace the Motor Controller. If the new Motor
Controller corrects the fault, then refit the original Motor Controller.
Oct 11, 2014 | Fisher and Paykel Washing Machines
Fisher & Paykel Washing Machine Model GWL 11
The power supply needs three resistors removed,R129,R130,R131.
and one 1megOhm put in it's place.
Feb 25, 2012 | Fisher and Paykel Washing Machines
My mw512nz started making a burning smell and wouldnt finish the cycle. i think it has stopped at the rinse. it definitly wont spin. i thought maybe its the water pump where the smell is coming from but...
That will be your waterpump, try popping the plastic cover off the coil on it and sniff the coil itself, you will most probably smell abit of the burnt smell you could smell earier. Also try measuring the ohms with a multimeter, should read somewhere around 33ohms give or take 5ohms depending on temperature.
Sep 18, 2011 | Fisher and Paykel Fisher & Paykel Washer
Burning Smell on Fisher and Paykel GW11 on spin and is not getting up to speed on spin cycle. Motor Bad?
Hi just read your posting.In my experience the only part on a Fisher and Paykel top loader machine that creates a burning smell is the pump.Try looking under the machine and you will see a black fan.This is your pump.Check to see if it has corrosion on it with a torch and try smelling it.I am sure you will find it is the pump that is smelling.Please reply for additional help and tell me how you got on with checking the pump.Looking forward to your reply.
May 14, 2011 | Fisher and Paykel GWL11 Top Load Washer
Model gwl 15 us not draining
find black rubber drain hose under machine and squeeze several times to loosen soap and hair gunk.
start the mahine on the rinse cycle. This should start the draining process.
Dec 08, 2010 | Fisher and Paykel Fisher & Paykel Washer
During the rinse cycle, our GWL 11 Fisher & Paykel
The problem is in the pump, so it will not pump out, you will need to find another way to empty it, removing the agitator will make the job easier.
When you get the water out the pump can be accessed from underneath, it turns anticlockwise to remove it,.
I would buy a new pump as it is most likely that is all that is wrong with it.
Apr 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
sounds like the motor controller is faulty.if u have power to unit and the lights aren't on then it is either faulty controller, or faulty pump or best case broken power wire.please turn power off b4 u work on it. dont want any accidents. please reply 4 more help.
Apr 09, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel GWL11 washer won't rinse
sounds like you have two problems, the burning smell is probably the pump,out of balance is usually due to worn aout suspension rods
Oct 14, 2017 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
Oct 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
179 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
