Question about Sony CXSGT5416F Bundle (CDXGT540UI receiver and GF16 speakers)
Installed the Sony cdx-gt540ui. The amp and sub-woofer work great on the radio, but when a cd is put in, the amp and sub-woofer don't work.
  • ellingtonbla May 03, 2011
    I'm sorry I don't have a solution. In fact, I found this page because I have the same problem with this stereo! Using USB or CD sources, my subwoofer works at very low levels, but when the radio is on, the subwoofer works as expected. I have my amplified subwoofer connected to the line-out connections on the stereo.
  • 78 Answers
SOURCE: Memory loss
you need to remove the radio and swap the red wire for the yellow wire and vice versa, they have bullet connectors to allow you to do this, basically the permanent live and the ignition live are the wrong way round.
Posted on Nov 27, 2007
SOURCE: lost instructions for sony cdx-gt11w car cd receiver
Press and hold the volume knob until the display shows clock adjust.
use the forward and rewind serch buttons (the small arrow buttons next to the volume nob) to switch hour and minute.
use the volume knob to adjust the time. When done press the volume knob to return to normal operation.
HTH
Posted on May 01, 2008
SOURCE: Sony CDX-GT360S NO AM OR SHORTWAVE RECEIVE
IT IS NOT A PROBLEM AT ALL, MOST CARS NOWADAYS DON'T HAVE SHORTWAVE ANTENNAS, THEY OFTEN COME WITH ANTENNAS SUITABLE FOR FM STATIONS SO WHEN SW DXers LIKE US HAVE CD PLAYERS IN OUR CARS WE SHOULD ALWAYS HAVE IN MIND THAT ANTENNAS MUST BE CHANGED, HERE IS THE SOLUTION.. GO TO A RADIO SHACK OR EBAY AND GET ONE OF THOSE HIGH SW ANTENNAS AND YOU ARE READY TO GO.
HOPE IT HELPS
Posted on Aug 02, 2008
JustJeeps
  • 74 Answers
SOURCE: sub not working after installing the jensen vm9022 deck
reinstall the factory radio use a digital volt meter to see witch wire supplies voltage when radio is turned on and off, note placement on harness then verify this wire is hooked up on the output side aftermarket harness you may have to jump it to get the maps to turn on. tip you can carefully pull unused wire from harness example (dimmer wire orange white) and move it to the position needed to keep it a clean install .
Posted on Nov 21, 2008
thefazool
  • 3 Answers
SOURCE: No sound from cd or aux on CDX-GT32W
Just connect together the solid blue wire on the main harness to the radio with the blue/striped wire. The blue wire is for the power antenna and the blue striped is for the remote amp. but if not connected together only the fm/am has outputs to the line output RCA jacks. I learned this through Sony's tech line and it works perfectly now.
Posted on Dec 15, 2008
Sony cdx gt170s wiring diagram
Yes. This model has a dedicated zubwoofer output. Virtually any sub woofer amp that connects via RCA will work.
Oct 17, 2013 | Car Audio & Video
I have a sony mp3 xplod car radio, buttons wont work on it to operate probaly, any suggentions as to what is wrong?
I had the same problem with my sony CDX-GT540UI and solved it! I just kept clicking the "source/off" button when the display was showing the demo and suddenly it started switching to USB/CD/AUX etc. This means that the contacts inside the micro-switch were stuck in the down position, continuously making contact, and blocking the signals from the other buttons. Have to replace the micro-switch now.
Dec 29, 2011 | Sony XPlod CD Player w/MP3 Playback...
Subs not responding to Sony CDX-GT500
you cna switch the working rca's to the sub out put to check for sound if u get sound it means your rca's are bad but if no sound then your other outputs in your radio may be deffective
Jun 12, 2010 | Sony CDX-GT500 CD Player
I just installed a sub and it only is working for
there should be two blue wires. one solid blue and one with a white stripe. if i remember the solid should be antenna remote and the blue with white stripe is the amp remote turn on. if you are using the power antenna,it will turn off the amp when not in radio mode.
Mar 08, 2010 | Sony CDX-GT420IP CD Player
No sub signal from a CDX GT520.
connect the speake(sub) directly to the stereo(just use one of the rear 6x9 speaker wire to test the sub and make sure it's not the amp. if it does not work, it's the sub
Sep 07, 2009 | Sony CDX-GT520 FM / AM Receiver
CDX-SW200 plays the stereo but not the CD's
sounds like you connected the amp turn on lead to the power antenna wire coming from the deck, so the amp turns on when you have the radio on, but turns off when playing cds. you need to connect the amp turn on lead to the amp remote wire.
Jun 11, 2009 | Sony CDX-SW200 AM/FM Compact Disc...
Sony xplode cd player sub problems
Switch your blue wires around.
You have put the remote antenna wire to the remote turn on of the amplifier. The radio cuts off the power to the "power antenna" when you switch to a different mode... so your amplifier is now losing the turn on signal it requires to stay on.
Simple 2 minute fix.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 19, 2009 | Sony XPlod CD Player w/MP3 Playback...
Troubleshooting in car cd player
that is very strange but it could be that when you put the cd in the radio it maybe sending out a quick shot of amplified power I would try disconecting the subs put in a cd let it play a little then plug the subs in while the cd is playing and see if they work if this works you may to get a new radio or put in a switch to turn the subs off or some type of momentary circuit breaker I'm just trying to help I never saw anything like that before good luck........
Nov 06, 2008 | Sony Xplod CD Player w/MP3 Playback...
May 17, 2008 | Sony CDX-GT300 CD Player
No sub when listening to a cd
you're using the wrong remote output wire. You have it hooked to the power ANTenna wire (blue) which turns off when not using the tuner. You need to use the REM OUT wire (blue w/ white stripe).
Oct 14, 2007 | Sony CDX-M630 CD Player
Sony CXSGT5416F Bundle (CDXGT540UI receiver and GF16 speakers) Logo
3,880 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
