Question about Sony Playstation 3 (PS3) Console
Blank screen ie; no video or audio
Thanks i'm glad there is a solution to my problem, so what do i need to fix it and do you know what it is exactly thats the problem
  • 3 more comments
  • josh1459 May 27, 2008
    my playstation is having a similar problem. nothing. i turn it on, i hear the fan spin up, and then not very much. it will take a disc and eject a disc fine, but i have absolutely no audio or video. tried the reset, nothing. tried connections with hdmi using multiple cables as well as the composite and component. nothing. any ideas?
  • Anonymous Nov 25, 2008
    I bought a PS3 today and I plugged eveyrthing in correctly I put a brand new game in and there is no picture and sound but the PS3 was on
  • Anonymous Jan 01, 2009
    ps3 turns on fine but no video or audio all of a sudden
  • Anonymous Jan 14, 2009
    yeah i have the same problem........an now i wish i never bought the dame thing.....if anyone now's how to fix it pls say fast!
    I tried pushing the power button, the correct way, for 2 hours... any better ideas. This POS is about to go out the window.... any ideas!>?
    Champion:
  • 207 Answers
Ya its a general video problem tons of ppl have, I am actually due to an appt right now but as soon as I get back ill email you the how to fix it.
Posted on May 27, 2008
  • mathew eaton May 27, 2008
    1. First off check your connections. Make sure that whichever display/video cable you might be
    currently using, is connected all the way & properly hooked up to your TV & PS3. This will fix
    most display/video problems.
    2. Check your display/video cables to make sure that there is nothing wrong with your cables. If
    you suspect there is a problem with your cables but are not sure, try them on another PS3 (one
    that you know for sure is working & does not have display/video problems)
    3. Hold the power button on the ps3 for 5 seconds until you hear a beep. If this doesn't work, try a
    few times. It should work. This will also fix most display/video problems (i.e. no display/
    video)
    . (When turning on your PS3, be sure to hold the power button down.DO NOT LET GO ! If you turn it on, then repress the power button again for 5 sec. until you hear a
    beep, IT WILL NOT WORK)
How to fix a blank screen
I have the same problem ...any one knows how to fix this
Mar 18, 2016 | Dual XDVD210 6.2" Touchscreen DVD Receiver
Have an HP pavilion A705W. Monitor has blank screen. Installing a PCI video card, but BIOS is set for on board video. Is there anyway to change this when I don't have a screen to see the bBIOS settings ?...
If the screen's completely blank, ie. it doesn't show a 'No Signal' message then it's probably the monitor not the pc. If you have another monitor then you can test the spare monitor with this pc or this monitor with another pc, to see where exactly the problem lies.
If it is the monitor then it could well be some bad electrolytic capacitors on the power board which are causing your problem. If so it's easy and cheap to fix yourself, even easier but not as cheap if you pay a tv repair man to do it. I've posted a link which will help you identify if this is your problem and how to fix it.
If it is the onboard video that has gone then I doubt installing a video card will help, as the signal from the video card has to pass through the onboard chipset. I was given a dell with this problem and the only way I could've fixed it was to buy a new motherboard for it, which just wasn't worth it in my case as I already had much better pc's anyway.
http://www.badcaps.net/forum/showthread.php?t=485 - It talks about motherboards mainly, but it still applies to other stuff as well, just ignore the motherboard specific stuff eg. remove cpu and ram etc
Mar 09, 2011 | HP Pavilion a705w PC Desktop
Wii loads then screen goes blank
Hello there
From what you have said it sounds like you have the BLANK SCREEN OF DEATH
The main causes are Hardware failure, overheating or wear & tear.
You may need to perform simple maintenance, clean or in some cases adjust settings.
To get the best advice on where to start I recommend a GOOD REPAIR GUIDE, From this you can fix the problem at home and avoid any large repair bills. Its easier than it sounds when you have help from the guide.
I used Gamer Fix to get the best guides
The other solution would be to send the console off to its manufacturer, This is free if your still in warranty. If your console is out of warranty then the usual price of repair is $150
I am Glad I could help and You can help others by rating this Post or leaving a comment.
Many thanks
Peter Fix
Jan 17, 2011 | Nintendo Wii Console
No Sound, No Picture on Magnavox 51MP392H/17
If you hear a constant clicking or chirping sound get the chirping TV repair kit from www.TvRepairKits.com
If you have no video - but have audio - its most likey the HVG.
Note: When the video goes out sometimes its hard to tell if you have audio becuase you can't see the screen to change to the correct channel.
May 08, 2009 | Philips Magnavox 51MP392H Rear Projection...
No audio no video
Its the same as the 3 red light error GPU solder . It will need to be serviced if not under warranty we do offer a fix if you are interested xbox360fixer@verizon.net
Thanks
Dec 26, 2008 | Microsoft Xbox 360 Console
Laptop does a long beep, followed by two short beeps.
One long followed by two short beep IS a video error. However, your model laptop does not have a separate video card. The only fix is to replace the mother board. Here is the service manual that will show you how to take apart the laptop and even give you the part number you would need to replace the motherboard.
Thanks and please take a moment to rate as fixya.
Dec 07, 2008 | Computers & Internet
Video will not show up on TV, can hear audio but screen is blank
You could sell it to me or pay me to fix it but I am not that mean:)
Ok so the system is on standbye and the red lights on.... push down the power and hold for sec.. dont let go as soon as u push it... you will hear a beep then it will reset itself and you should have video.. I know this works as I have fixed 4 ps3 THIS WEEK doing this!
Jun 19, 2008 | Sony Playstation 3 (PS3) Console
Call sony 1-800-345-SONY (7669)
ask them what to do and their price on it!
There is a fix but it normally requires you to take the seal off and if you dont want to attempt that then you can send it back or sell it to me ;) I do buy broken ps3's.
If you are willing to have a go at it via yourself let me know I can help you get the parts and fix it!
May 27, 2008 | Sony Playstation 3 (PS3) Console
Screen goes blank intermittently
Check to see if your constant(yellow) wire get a constant 12 to 14 volts. Goodluck.
Mar 05, 2008 | JVC KD-NX5000 Car Video Player
Blank screen when booting up
Does it get audio or is that missing too?
Sep 09, 2007 | Sony PlayStation 2 (PS2) Console
Sony Playstation 3 (PS3) Console Logo
76 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
