Question about Biostar U8648 Motherboard
I need your help me
Hi, I have a motherboard U8648, with 256 Mb in Ram, but I need up to 1 Gb, I don't know how to make this change, please you can help me ?
Hi. This motherboard can support up to 2GB of Ram. And the kind of memory is SDRAM
lucky
Posted on Mar 10, 2010
  • 13,433 Answers
You need to upgrade your memory modules to a bigger size, check your motherboard manual for supported memory speeds.
You can also look at your current memory be removeing it from the socket and see what it reads on it. Its either DDR memory or older SDRAM. I beleave your maximum memory is 3 GB
Posted on May 27, 2008
I currently use 256 mb ram,I want change 1 gb ram,pls ur opinion
Upgrading RAM on your ASUS P4B-MX Motherboards is easy, we carry compatible RAM Upgrade for ASUS P4B-MX Motherboards, the ASUS P4B-MX Motherboards takes the PC100/133 SDRAM DIMMs.
Supports ECC RAM Type, and comes installed with 0 MB (removable) of RAM. You can upgrade your ASUS P4B-MX Motherboards to up to a maximum of 3.0 GB RAM, the Motherboards has 3 sockets to install RAM, already with 0 MB (removable) standard RAM installed. For best Motherboards performance use the maximum amount of allowed RAM per slot for your system.
Buy our Motherboards RAM with confidence, we provide lifetime warranty on all RAM Modules purchased, backed with an excelled customer support. Choose the following RAM Upgrade for ASUS P4B-MX Motherboards.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
hope this helps you
Mar 20, 2012 | ASUS Intel 845 Chipset P4B-FX Motherboard
Hello Sir, I had 512 MB 533 MHz DDR2 RAM(Dynet). Now I have bought 1 GB 667 MHz DDR2 RAM(Dynet). My system has 2 slots. In one slot, I have 512 MB RAM and in another slot, I installed 1 GB RAM that I have...
The Intel D102GGC2 uses a Dual Channel Memory Architecture meaning that both slots need to be running at the same speeds. I would suggest getting another 667 MHz RAM card and installing it along side your current one, just as I reminder this motherboard only supports 2GB RAM Max so don't get one that is above 1GB.
Mar 28, 2011 | Intel D102GGC2 Motherboard
Hi, I wish to upgrade my Ram speed from 256
Hi friend,
You can use more then 2GB Ram in your motherboard. it should be DDR-1 Ram .....you can change..
Dec 28, 2009 | Intel Motherboard
My msi pm8pm mb doesn't accept 1gb memory pc667 its accept only 256mb pc533, what i need to do to accept 1 gb memory, pls help me!!!!!! tnx!!
Your MB can take a max of 2 GB RAM. And it has to be DDR SDRAM. So, please ensure that it is compatible. Then only would it accept the RAM SIMM else it may damage the mother board. or the RAM itself.
Oct 13, 2009 | MSI PM8M-V Motherboard
I have problem about ram
If the manual says this motherboard support up to 1 GB RAM, you cannot put 2 GB. You can put 2x 512 GB RAM or 1GB RAM
Also try to upgrade your bios, maybe a better bios version supports more than 1 GB RAM.
Aug 24, 2009 | AOpen MX36LE-UN (91.89Q10.101) Motherboard
Loss of Ram in D102G intel Board
hello, you just have a shared memory with the on-board ati graphics, if it's on- board graphic card it shares the system memory-most are adjustable through the system bios-in 64,128,256 settings. and if you put more memory, in most cases it will automatic-raise the memory size of the graphics memory. i hope this helps you, all the best. if you need further assistance reply. don't forget to rate this solution.
Mar 25, 2009 | ASUS P4B533-VM Motherboard
1gb shows 512mb only
Your mobo is quite old and its chipset can only support a maximum of 512MB PER SIDE (technically called a bank) of a memory module. I would guess that your 1gb memory module has 8 chips that are all located on one side of the module, putting all of the 1 GB on one bank. Thus, only 512MB of your 1 gb RAM is detected and usable by your motherboard (the remaining 32 mb is most likely being used by your onboard video). You'll need to find a double sided 1 gb memory module (usually 8 chips on each side).
Mar 06, 2009 | ASUS P5VDC-MX Motherboard
Pc uprade
u can use 1 gb 400mhz DDR ram,single or 2
Mar 01, 2008 | Intel Motherboard
Biostar U8648 Motherboard Logo
97 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
