Question about Canon imageCLASS D340 All-In-One Laser Printer
Check document message
Where & how do I check the sensors?
  • 81 Answers
I checked the Canon website and the message you get can either be in the document handler or in the machine. I am including a link to the Canon website that discusses this problem. Let me know if it helps.
Posted on May 27, 2008
Actually copier is telling the problem- Originals left on glass. That is document sensor is dirty or blocked. Hence copier is giving message. Clean sensor or refer to qualified service.
Jan 08, 2015 | Konica Minolta Bizhub c203 Copier
Cannot clear "CHECK DOCUMENT" message on canon PC-D340 printer
Message on the LCD Check printer. I try Press Additional Functions key Press # Press > to #7 Printer Function Press Set Press > to #4 Printer Reset Press Set Press < Unplug printer and repower it. It work`s but only few times, after that the same message. What can i do?
Jun 08, 2010 | Canon PC-D340 All-In-One Laser Printer
Document too long error message during 2 sided print job
clean all paper pick up, feed and separation rollers. That means that paper is "late" on sensors.
But you also should check the sensor flappers. If they are worn out replace them, the problem also can be the flapper of registration sensor.
May 23, 2010 | Canon imageCLASS MF6590 Copier
I have a fujitsu 4120 scanner that will not pull the paper even after i changed the roller and pad.
Does the scanner displays any error message on the scanner panel? Is there any TWAIN error message?
If paper jam occurs, U1 error will be displayed on the scanner panel and TWAIN driver will display " Paper jam the ADF (Code DS32002)" error message.
This error is detected when one of the followings occurs:
1) A document does not reach the TOP sensor while the scanner has transported the document about 250 mm to pick. (The scanner
performs retry operation.)
2) The trailing edge of a document does not reach the TOP sensor after the scanner transports the document by the length (L) below. (The document may have slipped on the rollers) Scan condition Transported length.
In order to assist you with your scanner issue, Please provide the issue details with error message.
If nothing is being displayed, then the issue could be due to failure in Pick Motor function or Pick Sensor malfunction.
Hope the above information is helpful.
Thank you for contacting FixYa.
Apr 24, 2009 | Fujitsu fi-4120C Path-Through Scanner
'Doc Cover open' error message
look for switch where the doc door closes and insert a piece of paper to trigger it, message should clear, adjust switch.
Aug 21, 2008 | Brother MFC 8440 All-In-One Laser Printer
you will almost certainly have a torn piece of paper ( or small document) in the document feeder sitting over a sensor.It doesn't need to be very big to be detected.Open ALL covers on the feeder, check particularly at the edges of the feed area where you may have torn a corner off.Sometimes you can hand feed a piece of card through by turning the belt or rollers and push any obstruction out..........
Jul 28, 2008 | Canon imageRUNNER 1023iF Black and White...
It thinks there is a document stuck in the document handler. Check for a small piece of paper, or a stuck sensor.
May 27, 2008 | Canon imageCLASS D340 All-In-One Laser...
Add paper message
you will be glad to know, this is not your printer's fault. We went round and round with dell support when we first got 150 dell 1600n's. We sent in copies of documents that were causing the problem. Finally, they figured it out for us. Embedded in the document was junk that was telling the printer to pull from tray2. All you have to do to fix the problem, is take the word document, go into file, page setup. on paper tab, select default tray for first page, default tray for all other pages, and apply to whole document. to clear the message, you will have to delete the print job from the queue, and turn off the printer, then turn back on, and you should be set. The message add paper, is really what the printer should be telling you, except that it should add to tray2, so you know it is trying to pull paper from the manual sheetfeed port on the front.(you could add paper there, till the document finishes printing, but our docs are hundreds of pages, so that is not practical. Barry Smoke Network Administrator AR Division of Legislative Audit
Feb 25, 2008 | Dell 1600n All-In-One Laser Printer
Document Cover Open
I had the same problem with mine. Lift the top scanner, and check the hinges on the left. That error message means that the little black sensor on the left next to the hinges is not meeting flat with the unit when closed. Hold the sensor in for a few seconds, and your printer will start working properly.
Oct 11, 2007 | Brother MFC-8840D All-In-One Laser Printer
Canon imageCLASS D340 All-In-One Laser Printer Logo
196 people viewed this question
old marine
old marine
