Question about Brother HL4040CN Laser Printer
Drum error. slide green tab in each color - Brother HL4040CN Laser Printer
1. power down the printer.
2. remove all color cartridges from their slots.
3. inside the color slot, you will see a green slide that will not move until you pick up the plastic cover.
4. rotate the plastic cover forward.
5. slide the green slide 3 or 4 times. (DO NOT TOUCH SMALL WIRES!)
6. return slide to original position.
7. snap the plastic cover back in place
8. return each color cartridge to it's slot.
9. replace color cartridge holder back to printer.
10. close all covers
11. turn printer back on.
If you still get the "move green slide" error, just repeat these steps
This took me about 10 minutes for the process, after understanding what the "green slide" meant.
Posted on May 22, 2011
1) Each toner cartridge has two green tabs. One green tab can be seen while the cartridges are inside the printer, the second green tab can be seen when the cartridges are removed from within the printer itself.
2) Remove the Black toner cartridge, ensuring you do not touch the round drum parts, but rather you only hold the cartridge on its ends.
3) The second green tab (as shown in the image attached), literally slides along the length of the toner cartridge. BE VERY CAREFUL not to touch the very fine wires underneath it which it appears to slide along.
4) It is "Slightly" clipped into its own little Clear or opaque coloured "Parking" spot.
5) Carefully hold the unit at its ends, whilst sliding this green tab away from its parking spot, along towards the other end of the toner cartridge, then return it to the original end WITHOUT clipping it back into the parking spot.
6) Return the cartridge into the printer.
7) Do this for each coloured toner cartridge.
8) Print & enjoy.
drum error. slide green tab in each color - 23963f08-0fcc-47cd-a81a-6de7210ee04c.png
Posted on Mar 13, 2014
  • Kevin M Cuddeback
    Kevin M Cuddeback Mar 27, 2015
    This worked, but with one extra step: After sliding the wire-cleaner back and forth, I put them all about 1/4" (.5cm) "short" of fully redocked. The printer didn't like this. So I opened up, slid them all back to "fully locked" and tried again. With that, it worked.
4 Suggested Answers
57 varieties
  • 1653 Answers
SOURCE: drum error
Do the following
Posted on Oct 17, 2009
lserni
  • 466 Answers
SOURCE: Our brother printer is saying drum error slide
You need to open the printer access panel. Inside, there's the "drum", which is secured with plastic tabs.
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/000300/000016/faq000316_005.html?reg=us&c=us_ot&lang=en&prod=mfc9440cn_all
Posted on Oct 28, 2009
SOURCE: my brother MFC9840cdw has an error message that
The guy that replied solved the problem. He rocks and I can't believe that brother does have a large posting on this issue. Sham on them:
ben2913 did the job "This is NOT the solution to this error code. The code is telling you that the Corona wire must be cleaned. Remove all 4 color drums. Look down into the tray that you removed them from and you will see 4 green tabs. Open the plastic cover that protects the corona wire and move the green tab back and forth several times. After you have done this with all 4, reinstall the drums, close the machine front and everything will work fine again."
Posted on Aug 18, 2011
Try removing all the toner carts and remove the drum unit from the printer. Using the upholstery tool on your home vacuum cleaner, clean all over the drum unit being careful not to directly touch the drum surfaces (they scratch very easily causing permanent marks to print) also vacuum out the inside of the printer. It is likely that dust is preventing correct charge build on the drum. Also make sure the green slide tabs are placed back at the home position at the side of the drum unit. Re-assemble and test.
Oct 13, 2016 | Brother HL4040CN Laser Printer
Brother HL 4050 CDN suddenly got DRUM ERROR, and there're message slide green tab on the drum unit in
The green tab slides from left to right.
This cleans the croner wire. These wire also have a tedancy to break every often.
The drum unit will need to be replaced
Feb 15, 2011 | Brother HL-4050CDN Printer
Brother printer 4070CDW drum error slide green tabs on each color
Open up the printer and slide the green tabs to clean the drum chargers
Jun 17, 2010 | Brother HL-4070CDW Printer
My brother MFC9840cdw has an error message that says, "drum error, slide the green tab on each of the colored drum units. Refer to the users guide". I have tried sliding the green sliders several times. I...
Feb 25, 2010 | Brother MFC-9840CDW Laser Printer
Drum Error: It says to Slide the Green tab on each color drum to correct problem. I do it on all and nothing happens error continues.
this printer has 6 Drum, check all, and look internal counters is available on the menu they are down counters. If Continues go the Brother Repair Center, for repair.
Nov 01, 2009 | Brother HL-4040CN Laser Printer
Newly set-up Brother color laser printer displays drum error.
The slides you are moving are for the drum units, you could try using canned air to blow in the same area that the sliders slide across, if that doesn't help you may need a new drum unit..
Aug 21, 2009 | Brother DCP-9040CN Laser Printer
Brother 4070 CDW Drum Unit Error
The green tabs that you have to slide are under the color cartridges, so remove the three color cartridges and you will see three green tabs, to slide the tab across the wire you have to first open the translucent plastic wire cover, then slide the green tab across the wires and return it to it's original position, close the wire covers, replace the color cartridges, and reassemble the printer. All the Best
Jun 11, 2009 | Brother HL-4070CDW Printer
Brother HL4040CN Laser Printer Logo
5,311 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
