Question about Dell Latitude D600 Notebook
I hav a hp p6570. the battery used to work jus fine until one day suddenly it stopped charging and an amber color light started blinkin. dis won't stop. my lap won't start till its connected to the battery. when it is connected to the battery it works but still won't start charging. if som one knows the solution i will be ver grateful. pls help.....
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Oct 04, 2010
I have a 2007 ES 350. Changed key fob battery,now nothing works. Only immobilizer security light is flashing and engine start stop button has amber colored light on
Be sure to use the correct battery, properly in place, clean the key contacts , See owner's manual for additional information.
There are specialized locksmiths for car keys
Oct 02, 2014 | 2007 Lexus ES 350
Samsung N145 Plus battery charge failure
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 03, 2012 | Samsung Computers & Internet
Montor blinks white
If this monitor is new return it to the place of purchase, the problem is in the LCD panel display, if out of warranty! cheaper to replace.
Mar 24, 2012 | E-Machines E202 20 inch LCD Monitor
Battery light won't change colors, drops to 0% once unplugged
Let the battery completely discharge all they way and let it sit for a day or so. Some times when a battery is new most user do not let it fully charge and then completely drain this causes problems for long use batteries. Then give it a try. It also sounds like your plug your cord that connects to the battery may be faulty. Did you by a different cord with the battery? Or use the one from your old one? If you did. This is a "No No" always buy the cord that come for those battery since they are rated for the particular battery.
Feb 25, 2012 | Fujitsu LifeBook A1110 Notebook
Medion E1210 notebook. Battery has suddenly stopped charging. Didn't get a fall. Laptop works fine when power supply connected, but if plugged out laptop shuts down immediately. When power plugged in...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 21, 2011 | Computers & Internet
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
I changed my black ink cartridge and my canon i 70 stopped printing. my computer gives me an error saying there was an error and my document could not be printed. the indicator light is green and then it...
Hi Good day!! did you try to print other documents? if yes try to restart your print spooler Click Start- Setting- Control panel- administrative tools- services now you should be on services box find the "Print spooler" click Print spooler and then restart it by click stop and then start
reply to me for further assistant if my solution did not work thanks
Thank you for using FixYa
Nov 09, 2010 | Canon BubbleJet i70 InkJet Photo Printer
My car want turn over and new radio install fuse problems
mcdevito75 here, The battery light indicates the charge the alternator is putting back into the battery, a regulator in the alternator allows only a certain amount of electricity to be built up. Sounds like the regulator in the alternator is shorted and draining the battrey, Have your repair shop test the alternator and replace.
Mar 04, 2009 | 1989 Chevrolet Celebrity
Ipaq rx3115 frozen
Red LED light means a major problem at the charging of the battery.
You have several options to repair it:
1. Leave several hours the PDA with not battery and unplugged from the AC power adapter, then put the battery and leave charging it.
It's more likely that the red light will appears again, but leave plugged it. Sometimes will start charging and blinking with orange color after 30 minutes or so. After that, it will work normally.
2. Use other good working battery to test it.
3. If the above two steps fail, then there is a good chance that the mainboard has a problem, and needs to be fixed or replaced.
Best regards,
Jan 25, 2008 | HP iPAQ RX3115 Pocket PC
Dell Latitude D600 Notebook Logo
57 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
