Question about Canon FAX-JX200
In the LCD display showing Check 5100, how to solve it?
    Guru:
  • Canon Master
  • 452 Answers
Hi; transparant plastic ribbon that serves to guide the slide is dirty clean it with cotton and alcohol
Posted on Oct 17, 2010
Accere aspire 5100 desply not show
Please write in English. Thank you.
May 14, 2014 | Acer Aspire 5100 Notebook
CHECK 5100
Jams in the Document Tray
When a document jams or misfeeds in the Document Tray, CHECK 5100 are displayed on the LCD.
When CHECK 5100 is displayed
1 Check if any paper is jammed.
If jammed, make sure to take out all the jammed paper.
2 After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF].
Jams in the Multi-Purpose Tray
If paper jams in the Multi-Purpose Tray, CLEAR PAPER JAM is displayed on the LCD.
1 Gently pull any jammed paper out of the fax as
shown, then press [Stop].
Pull it gently in either direction.
If you cannot pull the paper out, continue with the steps below.
2 Open the Printer Cover.
3 Gently remove the jammed paper inside the fax.
4 Press [Stop].
The fax returns to standby mode.
Feb 20, 2012 | Office Equipment & Supplies
I want to resolve error 5100 in canon mp 250 series printer pl tell me to do what
Error 5100 show your ink absorver almost full. So reset your printer by using the following methods. * Keep your printer off. * Now press stop/reset button and press power button with holding stop/reset button. * After your power is display a light release stop/reset button but still pressing power button. * Press Stop/reset button two times by holding power button. * Now release both button. * Wait for few minutes until your printer display "0" on your printer LCD. * Now download Canon MP258 reseter ServiceTool_V1050. After
Aug 11, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
How can i fix my ibm thinkpad t23 no display on his lcd. but power still on
Check & connect the display connector properlymay solve your problem.
Revert back for more assistance.
Jan 20, 2010 | IBM ThinkPad T23 2647 Notebook
Chek 5100
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
Thanks for using Fixya.
Apr 02, 2009 | Canon FAX-JX200
Canon jx500, getting 'check 5100'
I had this problem and solved it = )
You turn off the fax, take the paper out, then open the cover just after you turn it back on.
Leave it open for a minute and let the cartridge go back and forward close the cover and wait till it tell you to press stop and it should be back to normal.
Hope this helps
Mar 10, 2009 | Canon FAX-JX200
Cracked screen can it be fixed
No..the Glass Display Panel ... If cracked... Cannot be repaired.. it is not just a piece of glass, it is a layered panel with pixel grid panels along the top and sides that show color to the grid on the screen panel and go all throughout the display ..
If the Crack ocured behind the display panel on the plexiglass protective panel, that can be replaced... but No Not The Front LCD Display Panel.
Nov 19, 2008 | Acer Aspire 5100 Notebook
Service error 5100 canon pixma ip1300
see this --As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Nov 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
The LCD of my acer aspire 5100 stop of work..
Video card cannot be replaced on laptop. Is part of motherboard... motherboard must be replaced.
Not cheap.. cost about $300. plus labor.
Oct 26, 2008 | Acer Aspire 5100 Notebook
Inverted colors
be certain it is not the video card connect it to an external monitor and test,
and reseat the video connector from the panel to the card.
look for bent connectors too.
Mar 19, 2008 | Acer Aspire 5100 Notebook
Canon FAX-JX200 Logo
67 people viewed this question
old marine
old marine
