Question about Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1
Rheem Power Vent PVS50-36FV..Constantly goes to lock out..Unplug it turn it off . wait and turn on but sometimes in a day or a week again goes out .\r\nWhat to do??
  • 494 Answers
Call the manufacturer phone # that is printed on the water heater. You probably have the model that requires a retrofit burner with reset button to be installed to fix this issue. You will also have to clean out the bottom screen filter below the burner when you change it out. They will need the model # & serial # to check if yours needs this. Douglas
Posted on Oct 04, 2010
Rheem Intelli-vent intermittently goes in lockout mode
Rheem does not post service manuals.
However AO Smith has posted relevant service manual:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Have you cleaned the air intake located under combustion chamber, and inspected for broken glass vial?
Rheem FVIR system uses glass vial that breaks if combustion air is slowed, and resulting combustion causes slow-moving venting of hot gasses, causing overheating that breaks glass vial.
http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html
Check gas pressure.
Replace gas control valve:
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Oct 09, 2012 | Water Heaters
Rheem model 41vrp40n flashes twice and stops working
Error code means that you have electronic gas control valve.
Copy following link to identify gas control valve, read error code meanings for each, and download service manual relevant to each gas control, but not specifically Rheem since rheem does not post service manuals.
The fact that water heater restarts, means that water heater is getting gas, getting sufficient air for combustion, thermister is ok, gas pressure is good, etc.
The fact that you unplug and replug water heater and it works, shows that you have power vent model.
Since water heater worked correctly before, 2 flashes with Rheem power vent model could mean that pressure switch has failed.
Jul 29, 2012 | Water Heaters
Continuous ignition failure code comes up every day have to shut off powervent switch and on and unit will instantly turn on. problem began intermittently now happens every day. tired of resetting switch...
Hello
You need to unlock disply by holding down the up and down buttons until the lock flashes then goes away.
Once inlocked you can press mode button to resume normal operation.
Here is a link for your HW heater.Note pgs 22 to 24.
http://globalimageserver.com/fetchDocument.aspx?id=a92c7d0e-8a95-48ba-8810-cd714f33d47a
Aug 26, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a rheem power vent 21vp75e-1 it ignites the burner for couple of seconds and shuts off and retry to ignite into a lock out I wire jump the vacuum switch and it works properly than i replace the...
Before calling service technician, read manual for troubleshooting and yearly maintenance requirements.
Open following links to identify same-similar product and download manual.
Once you have product showing on page, click 'specs-docs' tab to see use-and-care manual.
http://www.rheem.com/product.aspx?id=C24E3F52-A6A4-4BC7-AF5B-0DF23A7A0263
http://www.rheem.com/Products/tank_water_heaters/gas_water_heaters
http://globalimageserver.com/fetchDocument.aspx?id=c0471d58-5e59-4be6-96f7-68361b8fb515
Rheem site loads slow, and some manuals never load.
Typical power vent manual:
http://waterheatertimer.org/pdf/Rheem-power-vent-manual.pdf
I believe the 21VP is older and Rheem does not show older manuals, but manuals are generally generic enough to help greatly. Year of manufacture show as second and third digit of serial number.
Lockout condition requires service technician and part replacement, or call Rheem and have them send part.
I found one link that talks about FV lockout that may or may not pertain to your issue:
http://www.diychatroom.com/f7/rheem-hot-water-heater-pilot-burner-not-staying-lit-65755/
Apr 19, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
Rheem power vent 2 water heater keeps shutting off
you need to replace the upper thermostat, it has the overtemp switch made to it. Also make sure that the thermostat is pushed up tight to the tank with no space or object between them.
Mar 12, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem power vent motor doesn't shut off
There could be blockage in your water heaters venting on the outside of the home. It sound like the high limit switch has been tripped. Try unplugging the tank and plugging it back in. this will reset the tank. if the problem persists you will want to call your provider for service.
Oct 07, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
PVS50 rheem power vent water heater do not reignite/restart/kick
I actually just installed one of these the other day, I found that the ignitor wires were straped to the gas inlet and they were shorting out,, I wraped them with electric tape and the unit came on and stayed as for the thermostat make sure your flue is clear of all obstuctions even outside, make sure on the vent on the top back of the unit is clean and no lint or dust has built up on it, you can take a small soft brush and just sweep it across it
Jun 17, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1 Logo
1,461 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
