Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
How do I drain out the water, by override function
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Sorry to ask these questions but does your machine drain the water automatically after the wash cycle?If you advanced the cycle to spin and pushed the start button does your machine drain the water?Why do you need to drain the machine by an override function?Please reply with additional information on the questions and I am sure I can help you rectify this fault on your machine.Looking forward to your reply.
Posted on Oct 04, 2010
Boiler,heating and water all working OK but manual override to turn heat on before preset time caused dripping under boiler.Cause and solution?
Did the boiler winter over with the heat turned off and no winterization? If so, then the boiler may have frozen and cracked. Replace it.
If it WAS drained down and winterized, and you just filled it with cold water before firing it, it may be condensation.
May 05, 2017 | Water Water Heaters
Whirlpool wfs1071aw
Wait for 3 to 5 minutes. Usually the door opens thereafter. Be sure to run the drain and spin cycle before opening otherwise, you've got water spilling on your deck. There is a override cable on the bottom of the washers next to the drain pump which is located on the lower front of the washer. You may use this by pulling on it. Remember to drain first.
Aug 16, 2014 | Washing Machines
Is the sunvic sp2 a 2channel timer please
Yes. It appears the Sunvix SP2 is 2-channel timer.
http://www.sunvic.co.uk/documentation/Programmer_Select_207.pdf
Two-channel means CH central heat and WH water heater can be programmed separately, and each can have its own timing program.
pg 3
The timer offers pre-programmed options for both CH and WH, which can be used, or program your own schedule. chart pg 5 and steps pg 3
Limitations: both channels operate on same clock time, and dip switch setting. pg 6. So the WH cannot be programmed for 5-2 weekdays-weekends and CH programmed for 24 hour.
As a convenience for varied work schedules, Sometimes people use the 5-2 weekday-weekend option so 2 days of week can have different programming, and then fudge current day setting during the set-current-time step pg2 so the 'weekend days' are actually moved to wedsday-thursday instead of sat-sun.
Option: both CH and WH timer programs can be linked and follow same programming by using copy button. pg 5
Using advance button on either side of timer, pg 3-4, WH and CH timing schedules can be overridden temporarily until next set point is reached. Then regular programming automatically resumes.
If override or Advance button is pushed for either CH or WH, it reverses whatever programming is in effect. On becomes off, or off becomes on. However if CH thermostat is satisfied and room temperature has not fallen below thermostat set point, then override will not turn CH on, but override will turn CH off. Same for WH override: If cylinder thermostat is satisfied with internal water temperature, the water heater will not turn on and heat more water, but the override can turn water cylinder off.
Unit requires Cr2033 lithium button battery. Pg 6. Probably lasts 3-5 years. Programming is protected for 30 days from power outage.
If programming is lost, change battery, the reset timer and reprogram to restore functionality.
Nov 24, 2012 | Hardware & Accessories
No reverse on 1998 Polaris Trailblazer 250 2x4
You could try Disconnecting the override and see if it will work that way,its just for safety reasons and really dont need it.
Jan 15, 2012 | Polaris ATV
I have an Darlac Electronic water timer DW253 but haver mislaid the instructions, where can I download a set?
I cannot find a manual for the Darlac DW253.
It appears the timer is set by moving each selector knob.
http://www.watermate.co.uk/secure/uploads/DW253%20(Small)%20new%20darlac%20pop.jpg
Knob on right is Run Time:
This is how many minutes timer will run each time.
Set run time from 1 minute to 120 minutes.
Knob on right also has ON-OFF override.
Knob on left is Frequency:
This is how frequently the timer will turn ON. Once per hour, once per each 2 hours ... once per 24 hours ... once per 72 hour ... once per week.
So set frequency to 48 and set run time to 20, then every 48 hours the water will turn on for 20 minutes.
To turn timer off, move right knob to OFF.
For continuous watering, turn same knob to ON.
This timer is battery-powered, probably 9 Volt, but maybe AA.
Battery carriage appears to be located on front below the function knobs.
Typically, water timer batteries last one season.
Timer can be connected to household spigot, or connected to any passive water supply for example rain barrel or tank.
Appears to have standard female hose thread on top, or possibly 1/2 pipe thread, and quick connection on bottom.
Plastic water timer exposed to freezing temperatures can crack. Drain water out of timer during cold weather.
Generally if water timer stops working: replace battery, clean battery terminals, and if functionality is not restored, then buy another timer.
Add a comment to fill out the missing details.
Aug 02, 2011 | Woods Inwall 24 Hour Programmable Timer
Unit runs but does not collect water. If I shake unit water will drain into bucket from coil. I pushed a plastic trigger sprayer pickup tube into drain tube and some water came out. I felt some kind of...
Use an 18" long plastic Zip Tie that will fit into the drain tube and carefully slide it in. The tricky part will be when you reach the curve in the drain tube. So be careful, but persistent. Once it has gone as far as it can, slowly pull it out while rotating it. This will help to dislodge the clog. Be prepared for water to follow. This should solve your problem.
Mar 29, 2011 | Haier DM30EAL Dehumidifier
How do i unlock a Gt 3215 apex tv? and where and how does the function button look like on a remote??
Hello
Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
  1. To use the override code:
  2. Hit the MENU key to get to the menus.
  3. Go down to the SYSTEM menu and hit the right arrow on the remote control.
  4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
  5. Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired.
Function buttona nd Menu buttons are the same or some remotes. I don't know whether you have the original remote of Apex or not. On original remote there is a function buttom marked as Function.
OK>
Jan 06, 2011 | Apex Digital GT3215 32" TV
My INDESIT W43T washing machine problem is cannot start,water no come in and i check the door also no lock,i try to another stage,only pump water out system function.another stage no function.what should i...
I have index w43t. it makes some abnormal noise from drain pump and water is not drained. I opened the drain filter and found the noise came from the drain motor. How can i solve this problem?
Aug 02, 2010 | Indesit Washing Machines
Water not filling in electrolux front loader, have cleaned out pump and detergent area, require sequence tpo override error
You have checked the pump area,does the pump actually spin when you put control to drain or spin,because if the pump does not function correctly the machine will not bring any more water into the machine.There may still be a problem at the inlet valves etc.
Hope this helps.
Jun 26, 2010 | Washing Machines
Continuous drainage
Take out the drain pan and look in left hand top of the compartment and you will see a drain hole for the pan.Plug the drain hole with a small rubber plug, I used an electrical wire nut wrapped with tape and it worked fine.replace the pan and the water will run out the back. A 3/4" garden hose should work for the drain hole.
Jul 27, 2009 | Haier HDN655E Dehumidifier
Washing Machines Logo
164 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
