I can't eject my dvd drive, and when i pressed the eject button at the side of my laptop, it doesnt eject as well. I tried everything to eject, but doesn't work. The only thing that worked is only when i use a pin to poke the small tiny hole beside the eject button at the side of my laptop. Even after I put a disc in there, my laptop can't read the disc. I've used basically every programs but doesn't work. I've tried going to the regedit and delete the upper and lower filter, but the thing is, none of the filter exist. My laptop is inspiron 1520. My dvd drive is basically DEAD and I was just wondering if theres any other way to make it alive again other than buying a new one.
5 Suggested Answers
jessee007
  • 310 Answers
SOURCE: Acer aspire 4720z DVD drive not working
remove the device from your pc and rebooting it. sounds like a drives or new software problem try uninstalling all and reinstalling
Posted on Nov 17, 2008
  • 13433 Answers
Hey,
it could be a dirty lens. here's a video on the cleaning, its annoyingly loud but shows how to clean the lens with rubbing alcohol.
might want to turn the volume down in advance:
its for a ps2 but the drive is basically the same, and you would clean the lens in the same way.
if this doesn't solve the problem, you would probably have to disassemble the drive completely and get it working properly and put it back together, might want to get the help of a pro for that.
Last option is to replace the dvd drive completely, it will definitely solve the problem, You can buy such a drive from few places, few come to mind, for example, www.ebay.com, www.pchub.com and www.acerparts.com
Let me know how that goes,
Thanks,
Ekse
Posted on Jun 03, 2009
  • 90 Answers
SOURCE: Inspiron 1520
I would always go with an extended warrenty dell pc's usually don't use the best hardware and tend to die in the 2-3 year range. The only reason I would say don't get it is if you are just going to go out and get a new if that one dies anyways.
Posted on Jun 22, 2009
  • 14 Answers
SOURCE: Dell Studio 15, CD stuck in slot
remove drive out there's 4 screws below drive remove them, you should be able to open drive in 2 bits remove cd put all back together ;)
you may have 1 or 2 more screws just remove them to open drive in 2.
www.e-repairs.co.uk
Posted on Jul 04, 2009
How do I open the dvd tray
is there not a small button on the laptop.
Feb 12, 2015 | Acer Computers & Internet
I own a acer aspire az3101-u4062. everything seems to work normal except i cant open the dvd drive
Look carefully at the front of the drive, near the eject button. There maybe a small hole. If there is insert a straightened paper clip and the drive will open.
Nov 17, 2014 | Computers & Internet
How do I eject a DVD from the MacBook Pro?
Press the eject button on the keyboard, top right-hand side, just above delete button.
You could also try going to your HDD, click on CD Drive, right click and eject.
Hope this helps.
Feb 07, 2014 | Apple MacBook Pro Notebook
My dvd wont play on laptop
b> Copy-protected DVDs prohibit people from copying them, which is piracy. Copying a DVD to sell or even to give away is illegal. You can play copy-protected DVDs in a standalone DVD player or in your computer's DVD drive, as long as your computer's software is up to date. These DVDs will play the same as DVDs that are not copy protected
Press the "Eject" button on your DVD player to open the DVD tray. Set the DVD into the tray, and push the "Eject" button to close the tray. Press the "Play" button on your DVD player, and the DVD will play. b> On a DVD Drive on a Computer Press the "Eject" button on your DVD drive to eject the DVD tray. Set the DVD into the DVD drive, and push the tray in to close it. Click the "Start" tab on your computer's home screen to open the "Start" menu. Click on "My Computer" to open it. Click on the DVD drive to open the DVD. Click on "Autoplay" to play the DVD.
Jan 28, 2013 | Compaq Computers & Internet
Dics stuck will not eject it is the one with out the tray no place to stick a paper clip
open my computer right click on the DVD drive and select eject if still doesnt work restart the computer and press F2 in Bios press the eject button (the triangle with line underneath on the top of F12)
if still doesnt work it needs to be replaced
Sep 07, 2010 | Dell Studio 1537 Laptop
Door will not open
make sure the drive is not reading a disk, because if its spinning it can break when you do this process.
look for a hole in the front of the drive, get a paper clip and stick it in there all the way, the tray will now eject or if its a slot loading drive the cd will eject
Sep 06, 2010 | Computers & Internet
Dvd will not eject from slot drive of dell vostro 1510
Restart your computer and enter set up bios. Try ejecting your dvd rom from there... it that doesn't work, get a pin and insert it in the pinhole on the dvdrom whuile pressing the eject button... that should do the trick!
May 24, 2010 | Dell Vostro 1510 Laptop
The DVD tray doesnt eject
either it is the ribbon wire, the motor that ejects the tray or the belt that connect the tray and motor is the problem. In case the above three are fine, replace the drive as the sparking might kill your moterboard.
Jul 08, 2009 | Compaq (CDD480172) CD-RW Burner
Cd/dvd drive
You can see a hole located on the tray of the cd rom drive. Commonly seen beside the button to eject the cd out. Grab a small pin and push the hole and this should eject the tray. Close the tray again by pressing the button. Eject it using the button. If everything still failed, call up Dell to have the CD Rom Drive replaced.
Sep 19, 2008 | Dell Inspiron 710m Notebook
Trouble Ejecting Disks
Turn your laptop upside down. Whilst it's upside down, press the eject button!!!!
Oct 07, 2007 | Apple MacBook PC Notebook
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
