How can i fix my laptop black screen? I can hear it coming on, but no image on the screen.
    Guru:
  • 166 Answers
Instructions Things You'll Need:
  • AC adapter
  1. 1 Check the power source. While you have presumably already attempted to turn your laptop on and off, the problem may lie with your AC power adapter. Is the power-indicator light on the adapter on? If not, your problem may lie here. However, whether or not you have a power indicator light on your adapter, consider unplugging it and plugging it into another outlet. This may turn on your laptop and take care of your blank-screen problem.
  2. 2 Check your brightness settings. While it seems like a simple oversight, the brightness on your laptop may sometimes be turned all the way down. Thus, the screen appears to be black, off or defective, when the problem is simply that the brightness is on its lowest setting. To fix the brightness, check your laptop keyboard. Most laptops have the brightness settings mapped to two keys at the top left of the keyboard, accompanied by a symbol (often a sun). Use these keys to fix your brightness, but keep in mind that some laptops require that you press the Function key at the same time as the Brightness key.
  3. 3 Check the status of your laptop battery itself. There should be a battery indicator on the laptop that is connected to the battery. This indicator is either on the bottom of the laptop or (likely) on the side. If there is no indicator, your battery itself may be the problem, and may require replacing. Keep in mind that older batteries of the nickel-cadmium variety are more likely to decharge over time and forget their initial maximum charge level; this may be a particular issue to users of older laptops.
  4. 4 Find a VGA connector and hook up your laptop to an external monitor if the above steps have not alleviated the blank-screen problem. Turn on the computer and the external monitor. Does the external monitor light up? If so, the blank screen is likely due to a video subset problem/LCD problem in your laptop.
Posted on Oct 04, 2010
Error message 8801 sony laptop windows 7 black screen F8, F11 will not work i have a system image on a disc
You can restore the image to your laptop or use a software to directly fix the issue after boot from a bootable disk, Windows Boot Genius should be available for you, it can fix all kinds of computer errors. Or the below artilce related may do you a favor:
http://www.squidoo.com/computer-black-screen-and-computer-blue-screen
Mar 20, 2013 | Computers & Internet
Gateway laptop seems to boot, but no screen and cannot do anything. Seems to boot up, but nothing at all is on the screen (not even the cursor). Power and wireless lights are on, can hear CD drive scan and...
Can you hear sound playing as if it were loading the Windows desktop? If so, there are are a few things to check for:
  1. Look VERY closely at the screen once the laptop is on. Can you make out very faint images? They will be hard to see and it's best to be in a well lit area at the time. If you do see images, then the backlight on your LCD screen has gone out. You will need a new LCD most likely.
  2. If you don't see any image at all, try plugging an external monitor into the laptop and booting up the laptop. If you see an image on the external monitor but not the LCD, then you may have a bad inverter/cable/LCD.
If you cannot get an image on the external monitor either, then your video card may be bad. Considering that a lot of laptop video cards are built-in to the motherboard, you may be looking at having to replace the motherboard of the laptop (about 2/3rds the cost of the laptop).
There may be other problems at hand, but those are the most common I've found in this type of situation.
Sep 02, 2009 | Computers & Internet
GATEWAY LAPTOP COMPUTER IS FULLY FUNCTIONAL WITH BLACK SCREEN
umm i would not if you really never opened a laptop before there is deffently a wire loose in there no doubt about that. if you know anyone that could just open the scren part and fix the wire you should be in buissness
Jun 05, 2009 | Gateway MT3705 Notebook
Screen is black
If it's still under warranty, IBM should come out & fix it. Call them.
Mar 25, 2009 | IBM ThinkPad T21 2647 Notebook
Full screen on my laptop only shows black screen but i still hear the sound how can i fix this
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 16, 2009 | Acer Aspire 4720 Notebook
Toshiba laptop
First test is hold a flashlight at an angle to the screen to see if there is a faint image. If you can see the image with the light then the problem is with the laptop's display, either the backlight went out or the inverter is bad.
Second test is to hook an external monitor by VGA cable. Image should be complete and in full color if the onboard video card is functioning.
Please post comment with results for more direction.
Jan 01, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba P205D
either screen or viedo card has gone out try plugging it into a alt screen and see if it shows or not if it does I would say your screen took a floop or if it does show on a atl screen I would suggest you have prombally lost your veido card let me know la la linda
Jun 02, 2008 | Toshiba Satellite P205D-S7479 Notebook
Monitor Went "BLIND"!
Actually, there's 3 major manufacturers of laptops and parts.
Can you connect to an external monitor and boot the unit up. You may have to toggle (F3 or F5 i think) between on board and external a few times. If you get an image on the external, it's probly the lcd inverter (#1), or the backlight (#2), or the cable is not completely connected to the lcd (#3)
Let me know how the external monitor test works and we'll narrow it down from there.
Good luck
Nov 27, 2007 | Toshiba Satellite A45-S150 Notebook
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
