Question about LG DU-50PX10 50 in. Plasma HDTV
When i turn the TV on, the led turns green, then shuts of immediately.
    President:
  • LG Master
  • 1,779 Answers
You could either have a Power Supply board issue or a Y sustain module issue. I would have it diagnosed professionally.
Posted on Oct 04, 2010
2 Suggested Answers
  • 541 Answers
SOURCE: red led flashes. when i try to turn tv on it shuts
There should be a number of flashes that you can count. This is an error code. It will flash a number of times and stop. Again, Flash a number of times and stop. Contact a repair shop that is familiar with panasonic and have them to check it out.
Posted on Oct 14, 2009
My T.V. Will power on for a couple seconds then immediately turn off! Please help!
Unplug the unit from the outlet for at least 1 hour and check if the symptoms persists. If yes, check if the unit can give an error code by following the steps below.
- Power on the unit and wait until the initialization takes place.
- Press the front panel "Input" and "Menu" buttons at the same time and hold it for 5 seconds, it will activate the error code mode. LED flashes a two digit error code. Example, if the error code is "22" the LED will flashes two times pause and then flashes two times and will repeat the error code for 5 times.
"12" means no error has occured.
Please let me know what will be the result to assist you further.
Regards,jimvincentvillanueva@yahoo.com
Mar 07, 2012 | Mitsubishi WS-55313 55" Rear Projection...
Philips TV model 34PW9815/17 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt...
Philips TV model 34PW9815 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt respond to controls either on the set or the remote
May 12, 2010 | Philips 32PT81S 32" TV
Tv shut off will not come back on
Look closely at the red LED below the screen whilst turning the tv on to see if it flashes green and immediately turns red again. I f it does the power supply is bad. Go to ebay to get one. Here is a link to get one. Others are available on ebay besides this one.
http://cgi.ebay.com/AC-Power-Adapter-LCD-F-12-Volt-5-Amp-12V-5A-DC-Supply_W0QQitemZ280306032459QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item280306032459&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
Jan 17, 2009 | Proscan 19LA25Q 19 in. LCD Television
Sony KP-65WS500 65 in.
Check your CRT boards on the end of the tubes for burn spots, and burnt components, check the resistors to make sure they are not shorted, burnt, and they read the correct resistance. Check the diodes to make sure they conduct in one direction only and are not shorted or open.
Mar 24, 2017 | Sony KP-65WS500 65" Rear Projection...
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
Shuts down after power up 50ux53k bought new 1998
Refer to owners manual will tell you what blinking light means. But at the front not at the back.
Dec 16, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Shut-Off Problems with Philips 28ps6515/05
Green Screen with some lines lines are called retrace lines. it is due to maybe dry soldered or no green drive signal. This problem can be fixed by complete soldering in crt board. 1 green video supply absent 2 loose contact in green skt in crt board 3 crt board loose 4 no green drive signal.
Sep 15, 2007 | Philips 32PT6441/37 32" TV
LG DU-50PX10 50 in. Plasma HDTV Logo
199 people viewed this question
