Question about Miele 24 in. G665 Built-in Dishwasher
The water temperature seems to be below that selected. Is there a fix or do I need a serviceman (the detergent is not dissolving properland the dishes are not as clean as normal). The model is G665
  • 10,515 Answers
In this case, i would usually recommend a repairman. There could be many causes for the same.
This could be a problem with your timer or a problem with your heater. You'll need to uninstall the unit, tip it backwards and check the resistance of the heater. It should be between 10 and 50 ohms and if not replace it. If it tests good, replace your timer inside the door. If the element is getting slightly warm, that usually indicates your timer is bad because the contact is only sending partial power instead of the 120 volts needed.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 04, 2010
Think the element or thermastate has gone as it's not disolving the tablets can I fix it myself
One of the first things to check if the dishwasher detergent is not dissolving is the water temperature that is in the dishwasher. If the water temperature is too cold, it may not be able to dissolve the tablet effectively. . If it is below 130 degrees Fahrenheit the setting needs to be increased or contact a plumber for assistance.
Read more : http://www.ehow.com/info_8597080_dishwasher-tablet-not-dissolving.html The Dishwasher Tablet Is Not Dissolving eHow
Nov 18, 2015 | Dishwashers
Sludge On white clothes
WASH PERFORMANCE INFORMATION
12.1 Creasing
Creasing can be caused by over loading SmartDrive or the dryer. Permanent Press or Delicate
cycles have been designed to minimise creasing as they use a lower spin speed. Do not leave wet
clothes to sit in the washer or laundry basket.
12.2 Soiling
Soiling is the result of insufficient detergent for the load. White clothes are better washed
separately. Separate lightly and heavily soiled items, as clothes can pick up soil from dirty wash
water. Cold water below 20oC does not wash effectively. Select the wash temperature according
to soil type. For example, blood and mud are better washed in cold water, while sweat and oil
based soil wash better in warmer water. Loads made up of articles of varying sizes will wash
better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent than
soft water.
12.3 Linting
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading SmartDrive can increase the likelihood of linting. Insufficient detergent for
the load can increase linting as there will not be enough detergent to hold the lint in suspension.
Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the
fabrics attracting lint.
12.4 Detergent Residue
Over loading SmartDrive can result in detergent residue being caught in the creases of the
fabrics. If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check
the instructions for the detergent. Cold ambient temperatures, cold washes or short agitation times
may not let the detergent dissolve properly. In these cases pre-dissolve the detergent.
Overdosing of detergent can also cause residue when foam breaks down and will show as white
specs on the clothing. Poor quality detergents can result in residue.
12.5 Black Marks on Clothes
A build up caused by the interaction of fabric softener and detergent (scrud) can flake off and mark
clothes. Do not use too much fabric softener, maximum 75cc. If this is a problem, it is
recommended that SmartDrive is periodically filled with hot water, plus 1-2 cups of dishwasher
powder and left to soak.
12.6 Grey Marks on Clothes
Not enough detergent for the amount of soil on the clothes can result in grey marks on clothes. If
this is a problem it is recommended that SmartDrive is periodically filled with hot water, plus
detergent and left to soak.
12.7 Dye Transfer
Wash and dry non-colourfast clothes separately. Non colourfast clothes left sitting in a washer or
laundry basket can transfer dye to other clothes.
12.8 Tangling
Washing with too much water (i.e. under loading) can cause the clothes to tangle around each
other. Do not load SmartDrive by wrapping clothes around the agitator.
Aug 09, 2013 | Fisher and Paykel Washing Machines
My Fisher and Paykel Aquasmart is leaving white marks on my clothes. I am using the correct washing liquid, so how can I fix this? I am sick of re-washing half of my clothes
12.1 Creasing
12.2 Soiling
soft water.
12.3 Linting
12.7 Dye Transfer
12.8 Tangling
May 24, 2013 | Fisher and Paykel Aquasmart wl80t65c
How do you clean **** buildup in a top load washer?
9 WASH PERFORMANCE INFORMATION
9.1 Creasing
Creasing can be caused by over loading the washer or the dryer. Permanent Press or Delicate
9.2 Soiling
water. Cold water below 68oF / 20 oC does not wash effectively. Select the wash temperature
according to soil type. For example, blood and mud are better washed in cold water, while sweat
and oil based soil wash better in warmer water. Loads made up of articles of varying sizes will
wash better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent
than soft water.
9.3 Linting
fabrics). Over loading the washer can increase the likelihood of linting. Insufficient detergent for
9.4 Detergent Residue
Over loading the washer can result in detergent residue being caught in the creases of the fabrics.
If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check the
9.5 Black Marks on Clothes
recommended that the machine is periodically filled with hot water, plus 1-2 cups of dishwasher
9.6 Grey Marks on Clothes
this is a problem it is recommended that the machine be periodically filled with hot water, plus
9.7 Dye Transfer
Wash and dry non-colorfast clothes separately. Non colorfast clothes left sitting in a washer or
9.8 Tangling
other. Do not load the machine by wrapping clothes around the agitator
Dec 03, 2012 | Fisher and Paykel Washing Machines
Fisher Paykell washer left black grease spots on some clothes
9.1 Creasing
9.2 Soiling
than soft water.
9.3 Linting
9.7 Dye Transfer
9.8 Tangling
other. Do not load the machine by wrapping clothes around the agitator.
Sep 21, 2012 | Fisher and Paykel GWL11 Top Load Washer
How do I clean gw711 lint filter
There is no lint filters in these machines,
It is automatically pumped out with the drain water.
9.1 Creasing
cycles have been designed to minimize creasing as they use a lower spin speed. Do not leave wet
9.2 Soiling
than soft water.
9.3
Linting
9.7 Dye Transfer
9.8 Tangling
Jul 09, 2012 | Fisher and Paykel Washing Machines
Fisher and paykel washing machine GW703-U leave black spot on clothes during final spin
12 WASH PERFORMANCE INFORMATION
12.1 Creasing
12.2 Soiling
soft water.
12.3 Linting
12.7 Dye Transfer
12.8 Tangling
Jan 30, 2012 | Fisher and Paykel Washing Machines
Finish dishwashing product does not dissolve
Many dishwashing detergents need a water temperature of 140 degrees to dissolve. If your water is at the correct temperature, the only other suggestion I have is to make sure the detergent dispense is not blocked by large objects such as baking sheets, frying pans etc. If the dispenser cannot open fully, the detergent won't dissolve.
I hope one of these suggestions helps you. If it does, please rate my effectiveness. Thanks.
Jun 02, 2011 | Dishwashers
The detergent packet doesn't dissolve. The dishwasher seems to go through the cycles ... the dishes are wet. However I find the detergent packet in the bottom of the dishwasher.
Hello- Water flow, temperature, and pressure inside determine whether this little packet will dissolve.  Sump blockages or pump /motor weakness both effect amount water spraying inside. Some of these packets don't dissolve in time to enter wash water. Start by using powder or gel again. If it still leaves soap residue, other pump/motor issues exist. Let me know if this info helps- have more if needed. Thanks- ED
Mar 09, 2010 | Frigidaire Dishwashers
Detergent packs will not dissolve
check the water temperature, run hot water at the adjacent sink before pushing start on the dishwaher, or switch to powder, is your detergent door opening ? do not block the detergent door with long objects like spatulas etc.
Aug 27, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Miele 24 in. G665 Built-in Dishwasher Logo
57 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
