Question about Briggs & Stratton Briggs and Stratton 030434 3250 Watt Portable Gasoline Generator
Just bought a generator 5000/6250 style but my husband can't pull the recoil handle. i think it's stuck so we can't test the generator. the unit was shipped from california to the philippines. pls advice what to do. thanks
  • 2,019 Answers
Try removing the spark plug and rotating the engine by hand.
It could be just a little corroded from shipment over the ocean.
But once you have it loosened up and the oil circulated, it should start much easier.
Make sure it has oil in it, because sometimes they drain the oil before shipping.
You could also have someone else try the starter rope. A new engine can be hard to start.
Posted on Oct 04, 2010
  • estelaglozad Oct 04, 2010
    thanks so much. i was able to find an advice akin to the spark plug being removed from the engine and pulling the cord but yours is a more detailed step. i hope this will work and thank you again. will let you know if it worked. best regards..
Coleman powermate vangaurd 9hp. how long is the pull start rope?
no set length on any recoil repair
old one will be stretched or broken
melt cord end for ease of fitting and no fraying through holes
and finishing knots
feed one end into recoil internal through outer and inner casing
then knot
set recoil spring into correct position and tension
cord is at least three times around recoil
leave excess cord out for pull handle and later adjustment
then cut .. melt end .. feed thought pull handle
then adjust as you test recoil off the motor
then fit to motor.. pull a few times
and final adjustment of cord length at the pull handle
Oct 13, 2016 | Coleman Electrical Supplies
I already broke one recoil starter assembly on my Astra Korea 3 kVA generator. I can start the generator, but with great effort. It takes about 6-8 pulls, and there's so much resistance that I can actually...
The easiest test to run on the generator is to remove the spark plug and see if it pulls easier. If it does then it is a compression problem. I doubt that is the case. If it does not then you need to take the generator off the motor and see if it still pulls hard.
Jun 20, 2014 | Electrical Supplies
Stihl chainsaw MS460 Can't pull recoil
It could be the recoil is stuck. a couple of things to check. Take the clutch and chain cover off, remove the spark plug and manually try to turn the motor over by turning the clutch. If the motor/engine is not seized, take the pull start/recoil cover off and pull on the cord to see if it will work and that the cord returns back into the recoil automatically. Don't take the nut off the inside of recoil holding the cord spool on. If the engine is not seized, and the recoil now goes in and out by pulling the start cord handle reassemble and pull over the engine a few times. This a good time to check the spark plug is working, now put the spark plug back in and start the engine. It's a good time to clean the air filter as well while the chainsaw is mostly apart and clean all oily sawdust off the chainsaw in the crevices etc..
Jun 05, 2014 | Stihl Chain Saw Handle Models 044 046...
Have champion 3500 watt generator recoil pull cord wont recoil HELP
need to take the recoil off the engine and check for a broken recoil spring, depending on the engine if it is a honda, they sell a replacement recoil unit, anything else and you will have to get creative....try tapping on the recoil with your palm and see if it trys to rewind, if no resistance or movement when bumping is a good indicator of a broken recoil spring....
Dec 14, 2011 | Electrical Supplies
Want to remove the starter recoil from my powermate generator
I got one of these pieces of junk, and had same problem you described.
You will need to remove the end panel to get to the blower housing. You will have to thread the rope through the handle until you have enough slack to remove the rope from the handle. The end panel should now be free to remove entirely.
Find the 3 bolts that hold the blower housing on, and remove them. Once you get it off, make sure that the rope has a knot in it so it won't get retracted into the pulley recoil assembly. Take a screwdriver and push the rope back down into the pulley (that was my problem). Assembly is opposite of taking apart.
May 23, 2010 | Coleman Powermate Premium Plus 6250W...
I have a craftsman leaf blower model 335879770. The pull start doesn't engage. You can pull the cord and it recoils back but doesn't crank the engine. I have it apart but how do I get to the starter pulley...
you shouldn't have to there are little ears on the flywheel that the starter recoil hits when pulling the handle they might be stuck or not moving when pulling handle
Nov 09, 2009 | Garden
Pull start recoil assembly
I bought a replacement recoil starter for my 1850 at Pats small engine parts. The part number for a 3.5 B & S is 499706. If you look on the heat shield on the side of the motor there is the engine model and s/n. Hope this helps.
May 31, 2009 | Coleman Powermate Powermate 5000W...
Have a brand new 6250 generator I have never used.
If you've got a receipt that shows it's less than 2 years old you might be able to get your local Briggs dealer to take the blower housing off and see what is wrong with the recoil starter, have a look at this link http://www.briggsnetwork.com/maint_repair/BS_engine-warranty.pdf
Otherwise you'll have to do some troubleshooting yourself. The carb comes off first (you'll need an E5 torx socket to get the studs off), then the blower housing along with the recoil starter.
Did that help? Rate me friend :-)
Carl
Oct 09, 2008 | Coleman Powermate Premium Plus 6250W...
Briggs & Stratton Briggs and Stratton 030434 3250 Watt Portable Gasoline Generator Logo
368 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
