Question about Cameras
I have a Sony fx7 hd camcorder and when i turn it on i look throught the eye piece and it has a blank white screen. Now it wont let me record, when i press the record button it flashes eject the tape or that there is no tape in there or connect to power source ???
  • 10,515 Answers
this problem is associated with the ccd imager chip,and ccd will most likely be in need of replacement,although poor internal cable or solder connections at ccd may also be,but I suspect defective ccd imager. This is a very invasive replacement and disassembly procedure and I recommend service.Due to the fairly recent mfg dates on this model I will suggest to contact mfg for warranty repair or replacement.Contact Sony factory service at (866)357-6230.
There were few reports of firmware to be at fault as well.However, it would be really tough to diagnose the exact cause without opening the cam.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 04, 2010
Viewfinder and LCD screen only show black and record black
If camcorder shows old recorded tapes picture with correct colors in LCD but does not show live view in camera mode to record new movie then its ccd imager chip failure.
And if camcoder shows live view and old recorded tapes in its eye piece view finder but does not show any thing in LCD the its problem of broekn/ cracked flexible wire between lcd board and main board of camcorder.
Let me know your finding with bit detail to provide you solution/ helpful info.
Nov 18, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
WHY MY LCD WONT WORK BUT CAN RECORD THROUGH THE EYE PIECE
send it in for repair. You may have pointed the lens at the sun while carrying the camera around and burned out the lcd.
Jun 27, 2009 | Panasonic AG-DVX100B DV Digital Camcorder
Blank screen when recording
In some cases when recording on a camer the display is run through the eye piece on some models there are switches or settings in your menu .. you can try that
Mar 24, 2009 | Canon Elura 60 Mini DV Digital Camcorder
Sony handycam camcorder lcd screen white and no displays
For the "all white screen" in daylight problem, check to make sure the "Nightshot Plus" slider switch is set on "off."
Jan 05, 2008 | Video Cameras
Camcorder is not able to use for recording
Sony DVD92 Blank Screen
http://esupport.sony.com/US/perl/news-item.pl?mdl=DCRTRV19&news_id=161
Sep 03, 2007 | E.Digital Sony DCR-TRV265E camcorder Pal
Video cam model DCR-TRV265E
CCD sensor block needs replacing. Sony should do this free of charge. IF you have to pay for the repair it is not too expensive because this particular job requires only +- 1 hour labour and the CCD component is not that expensive.
Aug 27, 2007 | E.Digital Sony DCR-TRV265E camcorder Pal
Sony digital camera will not working correctly
Aug 02, 2007 | E.Digital Sony DCR-TRV265E camcorder Pal
LCD Screen Blank
hi, this usually happens with the ribon cable which is giving power and signal to LCD is becoming loose or damaged due to folding..since the LCD wiring replacemet is a skill needed task i recommend you to give it to the nearest service centre so that your cam will be ready for future shots all the best my friend sreejith
Jun 26, 2007 | JVC GR-DVL9000 DV Digital Camcorder
LCD won't project
You may have a problem with the image sensor device (CCD). From October 3, 2005 through October 2, 2007, Sony will repair, free of charge, affected products exhibiting the above-mentioned problem where it is caused by the image sensor device. Sony will also cover the cost of shipping and handling from and to addresses within the United States and US Territories for service to correct this issue. To see if you have this problem: Power On your camcorder (make sure the battery is fully charged). Check the LCD screen and verify that the display icons are turned on. If you cannot see the icons, press the Display button until the icons are visible. Put a tape in the camcorder. With the lens cap off, record some video. NOTE: Be sure to speak during the recording so the video will contain your voice. Rewind this section of the tape (using tape counter to verify start of your recording). Play back the recorded video and use the LCD screen on the camcorder to view it. You should hear the audio you recorded and the Display icons/text will still appear. If your camcorder is affected by this CCD issue, the picture will either be extremely distorted, or there will be no visible picture (just a blank LCD screen with the display icons still visible).
Mar 22, 2006 | Sony Handycam CCD-TRV318 Camcorder
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
