Question about Epson Stylus 1400 InkJet Photo Printer
I am having trouble cleaning the heads on my epson 1400. I have done is numerous times, but still do not get a good pattern on the head check. Is there some solution I should squirt down into the head or ???? FYI - I am using this as a sublimation printer with Sawgrass Artanium ink.
  • 32 Answers
Hi, what I do in these cases when the head printing doesn't work, is to send very complex or full color images to the printer, at the beginning it prints badly because the cloged head, but chances are that the clog dissapear after some time printing
Posted on Mar 20, 2011
I'm using Mac OS X 10.5.8. My Epson 2200 has gone nuts. It prints reds as green, etc etc. Completely unusable prints
Good Day!
Try "Head Cleaning". you can find it under printer properties, maintenance tab, then hit on head cleaning. once done, hit on print check pattern, please continue doing this until the print out goes clearer. after this, try to print a document again.
i hope this helps.
Jul 20, 2011 | Epson Stylus 2200 InkJet Photo Printer
I have been using an epson stylus color 880 for years. One day it would not print. Replaced the cartridges and still will not print. It goes through the printing procedures but nothing shows up on...
The print head nozzles may be clogged. From the Utility section found in the EPSON printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Perform up to 3 cycles if necessary. If the nozzle check is not printing completely, and if the head cleanings do not help the nozzle check pattern to print completely, try replacing the ink cartridge. Any ink cartridge installed into the printer must have a blue label on top of it. If the blue label has been removed from the ink cartridge, do not install the cartridge. Using an ink cartridge, which does not have the blue label on it, may damage the printer. Caution: If you have already installed a cartridge which is missing the blue label, or if a previously installed ink cartridge was missing its blue label at the time it was installed, and now head cleanings do not help the nozzle check pattern to print completely, your printer may require service and you should contact the EPSON Connection for further assistance.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jul 08, 2011 | Epson Stylus 880 InkJet Color Printer
Describe your Epson Photo 1400 Stylus printingProblem I have lines appearing on My prints, I have cleaned and re aligned the print heads but no joy
: i'mma having problem with my epson 1400 it keep on having horizontal line on the picture after in clean the head and align it
May 16, 2010 | Epson Stylus 1400 InkJet Photo Printer
Trying to replace the black inck cartridge and cannot get the cartridge holder to stop at a position for me to pull out the old cartridge and insert the new cartridg. I've have an Epson Stylus NX1000...
Found this on the Web for Your Printer. You can download the Manual from Epson.
If you find this helpful, pls rate me.
http://files.support.epson.com/pdf/nx100_/nx100_qr.pdf
Checking the Print Head Nozzles
If your printouts are faint or have gaps in them, some of the nozzles in the print
head may be clogged or ink may be running low in one or more of the ink
cartridges. Follow the steps below to check the print head nozzles.
1. Load letter-size paper in the sheet feeder.
2. Turn off the NX100 Series.
3. Hold down the y Stop button as you press the P On button to turn the
NX100 Series back on. Hold down both buttons until the P On light begins
to flash, then release the buttons.
Cleaning the Print Head 21
4. Check the nozzle check pattern that prints to see if there are gaps in the lines.
5. If there are no gaps, the print head is clean. If there are gaps or the pattern is
faint, clean the print head as described in the next section.
If print quality has declined and the nozzle check pattern indicates clogged
nozzles, you can clean the print head. Print head cleaning uses ink, so clean it only
if necessary.
Note:
You cannot clean the print head if an ink cartridge is expended, and you may not be able
to clean it when a cartridge is low. You must replace the cartridge first (see page 23).
1. Make sure the NX100 Series is on and the B ink light is off.
2. Hold down the y Stop button for three seconds to start the cleaning cycle,
which lasts around one minute.
Caution:
Never turn off the NX100 Series during head cleaning or you may damage it.
3. When the P On light stops flashing, run a nozzle check (as described on
page 20) to verify that the print head is clean.
4. If there are still gaps or lines, or the test patterns are faint, run another
cleaning cycle and check the nozzles again.
Note:
If you don’t see any improvement after cleaning the print head two times, turn off your
NX100 Series and wait at least six hours to let any dried ink soften. Then try cleaning
the print head again. If quality does not improve, one of the ink cartridges may need to
be replaced. If that doesn’t help, contact Epson as described on page 31.
If you do not use your NX100 Series often, it is a good idea to print a few pages at least
once a month to maintain good print quality.
Good Luck and Please rate me.
Jan 13, 2010 | Epson Office Equipment & Supplies
Black ink nozzle clogged
If you have tried 5 or 6 head cleans, left for about 10 hours and then tried 3 or 4 more without noticeable result then you probably need a head cleaning solution. Google for stockist near your area or try this one:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
Hope this helps. Please take a moment to rate this solution, thanks.
Mar 25, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Magneta ink isnt working
Simply a blocked head.
Make sure you've removed the yellow tear-off strip on the cartridge otherwise ink can't flow into the print head.
Carry out 4 head cleans but cancel the nozzle check pattern by clicking [Finish] after each clean until the 4 cleans are done then allow the nozzle check pattern, it should be now be perfect or at least improved. If not perfect do it again as above.
Any further problems, use our help pages on our website linked from the Epson page and various others: http://www.the-inkstore.co.uk/frame/pages/epson.htm
If you don't know how to clean the heads or prime the heads, again refer to our website on the link above, there'll be step by step guides with pictures to help.
I hope this helps.
Nigel
The INK Store
Jan 10, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Epson Photo R265 Lines every 2.5 cm
If its doing it on all types of paper despite of any setting on printer driver, chances are you are having a hardware issue with the product.
pls try this site: support.epson.com try use passcode; lock
only applies for US printers
pls dnt 4get to rate soln hope the site will help thanks
Apr 06, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson 1280 red lines on photo
One of the best possible solution that we can suggest is to run a cleaning cycle for three times. Just to make sure that cleaning is effective please try the step below:
1. Using your computer go to printer utility.
2. Click on Maintenance then select Head Cleaning. Head cleaning usually took 1 minute.
3. Once the Head Cleaning is done Print a nozzle pattern to check whether the head cleaning is effective or not.
Repeat those steps for 3 times. If the nozzle pattern after 3 cleaning cycles still bad. Reseat ink cartridge if possible replace the ink cartridges.
After all those steps and issue still present printer needs to be in service.
Aug 05, 2006 | Epson Stylus Photo 1280 InkJet Printer
Epson Stylus  1400 InkJet Photo Printer Logo
174 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
