Question about GE GSH22KGM Side by Side Refrigerator
Not getting cold - GE GSH22KGM Side by Side Refrigerator
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 27, 2010
Water does not get hot on a hot wash
Shut off the water. Disconnect & check the BOTH water supply hoses at the MACHINE to check for obstructions / kinks / etc: Check for and clean any strainer / filter on the hoses and inlet to the washer. Direct the hoses into a tub or other container and turn water ON. make sure you have water flow from BOTH hoses and that one is HOT and the other is COLD. If OK, reconnect to machine. Turn water back ON. Choose a WARM wash.
If you get COLD only, you probably have a bad HOT solenoid - if HOT only you have a bad COLD solenoid. Be sure by:
Shut water off and swap hose connections (hot to cold & cold to hot) and try again.
If you get COLD only, you probably have a bad COLD solenoid - if HOT only you have a bad HOT solenoid. If you get HOT only, you probably have a bad COLD faucet / hose - if HOT only you have a bad COLD faucet / hose.
Replace the bad solenoid as needed. Good luck!
Sep 28, 2015 | Hotpoint WMA48 Front Load Washer
Kenmore 110.42822203 no cold water
Reverse the water hoses and see if you get just cold water. Post back the results.
Nov 06, 2012 | Kenmore Washing Machines
Could you catch a cold while sleeping on a matress on the tiles
Hi.
If you sleep with dust on the tiles, then yes.
It is recomended to sweep it first or vacuum clean it. A cold may be an alergy from any dust sticking on your matress or body freezing and warming at the same time..
Before you get a cold, you will feel a certain irritation while swallowing your saliva, that is a sign of a cold infection in your system.
- you need to make a hot tea, squeeze half a lemon, pour in the tea. break half paracetamol and drink it.
For sure the cold will vanish in no time.
Take care.
-avoid dust
-avoid swift changes of temperature environment.
Feb 07, 2011 | Health & Beauty
The fridge freezer does not get cold. The outside of it gets cold but not the inside. There is still a humming noise.
if the outside gets cold and inside is not getting cold this is sign of low refrigerant
Aug 27, 2010 | Freezers
Not getting cold water
As long as the water valve is turned on.....most likely you need a new water control valve. This valve turns on the cold water for cold, the hot water for hot or both hot and cold for warm water cycles. About $100 or less parts and labor to fix. Or if your inclined you can get the part yourself and replace it....not to much trouble. You can get a generic valve for $15 to $20
Oct 17, 2009 | Maytag LAT3600A Top Load Washer
Should freezer compressor get very hot when waiting to get cold
it is normal for the compressor to get warm as long as the freezer is cold
Apr 24, 2009 | Refrigerators
My refrigerator won't get cold
I have a whirlpool side by side refrigerator and it stopped getting cold on both sides. i installed a defrost heater and it still want get cold. Why is that?
Jan 18, 2009 | Refrigerators
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Air condition
Does the evaporator thicker pipe coming to the compressor gets a bit cold or not at all?
Jul 14, 2008 | 1991 Buick Park Avenue
Refrigerators Logo
118 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
