Question about PC Chips M957G Motherboard
The 4 USB Ports in the rear stopped working. Can they easily be replaced?
I have been forced to use the front panel USB ports as the rear ones (4) don't appear to work at all anymore.
Thoughts?
    Brigadier General:
  • 3,614 Answers
the rear USB port cannot be replaced, & glad that you still have a front USB connections into your MOBO..?
May i ask why did they suggest you to use the front USB panel..? Can you give us some info why this was happen..?
Thank you
Posted on May 27, 2008
How to remove front panel to repair the front usb ports on an Acer Aspire E380 -?
The front USB connectors are usually either molded into the front case or held in via a clip or screws. Unfortunately, when they go out due to the tab within the USB port breaking, they are not easily replaced as each manufacturer creates their own proprietary connector...not the USB part but the hardware to hold the USB in place. So you will find the hardest part of this project finding the right connector or "jerry-rigging" the new one to fit.
Another alternative is to remove everything from the old case...the mainboard, all the drives and whatever else can be moved, and put it into a new case. If your current power supply is good and of a standard size, etc...you can get a used case for around $10.00 and put all the other things from the old one in it. Fortunately, this series of Acer seems to be pretty much generic so everything should fit....just make sure the "new" case has good front USB ports.
Jul 12, 2014 | Acer Aspire E380 ASE380-UD500A PC Desktop
My son tried to put a usb lead into my pc the wrong way and he bent all copper pins inside is it easy and cheap to repair or could i connect the tower to my laptop???? theres a hard one for you teckno
No, it isn't hard.
Wrapping your mind around Quantum Mechanics, and String Line theory, is a little tough; though. lol!
http://en.wikipedia.org/wiki/File:USB-Connector-Standard.jpg
http://en.wikipedia.org/wiki/File:USB.svg
Will make sense in a moment.
The front of your computer is the Front Panel.
Those are Front Panel USB ports.
On the motherboard are USB headers.
Small rectangular shaped pieces of plastic, that have contact pins sticking up.
EACH USB header will support TWO USB ports in the Front Panel.
Therefore; there will be two cables coming from two USB ports, in the Front Panel; and connect to ONE USB header on the motherboard.
IF, you feel the contact pins in the USB ports in the Front Panel, may be Touching each other; I strongly advise disconnecting the cables TO them.
Disconnect from motherboard.
Why?
Because if they touch each other, it will short the USB header out; on the motherboard.
This = No.
Then just use the USB ports on the back of the computer.
!O_O!
This is to save money, Mark; and save your computer.
Going further; If there are enough funds available, then I suggest replacing the Front Panel I/O/USB/Audio Control Panel Board,
http://www.ebay.com/itm/DELL-MJ282-DIMENSION-3100-E310-FRONT-I-O-USB-AUDIO-CONTROL-PANEL-BOARD-CN-0MJ282-/380380245011?pt=LH_DefaultDomain_0&hash=item58906dec13
http://www.dell.com/support/Manuals/us/en/19/Product/dimension-3100C
Service Manual (1611KB)
A) Removing the Computer Cover
B) Removing and Installing Parts
Connect desktop to laptop to do what?
For USB port availability? IMHO that is like shooting yourself in the foot.
Also, how do you propose to accomplish this?
The USB ports in the Front Panel, are for ease of accessibility.
(As the young tyke has found, lol!)
Connecting a laptop greatly detracts from this.
Jus sayin'.
For additional questions please post in a Comment.
Regards,
joecoolvette
http://www.youtube.com/watch?v=Nv1_YB1IedE
http://www.youtube.com/watch?v=Mlbuh3_ZKsE
Mar 23, 2013 | Dell Dimension 3100 PC Desktop
Gateway 5632E usb high speed ports locations
You can view the rear I/O panel of the GM5632E (including six USB 2.0 ports) atGateway Support - Ports.
The front view, including two USB 2.0 ports is atGateway Support - Front View.
May 02, 2012 | Gateway Computers & Internet
My dell latitude d600 usb ports stopped working how can i get it fixed. thans
If ALL the usb ports have stopped working, this is a problem with the USB controller. The short answer is that you cannot easily repair this. In all probability, the controller, or a circuit trace to it has blown or shorted. You would need to get another motherboard.
If one is still working, then you can get a PCIMCIA card to usb port that will give you 2-4 extra ports, but this will only work if at east one of your existing usb ports is still functioning
Aug 16, 2011 | Dell Latitude D610 Notebook
I need to replace that front usb ports on my compaq Presario s4020wm Can they be replaced
I think it would be much easier for you to use a USB hub instead.
It's much more easily available .
You can connect the hub to one of the rear USB ports
Mar 28, 2010 | Compaq Presario s4020wm (DK214AR#ABA) PC...
My usb ports stopped working. i unistalled them and restarted my computer. computer saw the usb ports on start up but still doesn't see any devices I plug into it. Is it a bad motherboard or a driver...
Some computers have both USB ports on the front and back of the case. The ones on the bark are directly off the motherboard while the ones on the front are usually connected by a separate cable. If you are trying the front ports, try one of the rear ones instead. if it works in the back, that cable may need to be reconnected inside the case.
Feb 26, 2010 | MSI 865GVM2-LS Motherboard
Usb & Front panel Problem..!
these front usb ports cause prob lem always kindly change the whole panel with usb ports in front they are faulty and giving problems and will create more problems if u dont change them kindly get new one u can find them easily on any store and simply chang them see the connector going to the motherboard plug it out and plu the new one at same location
rate me WELL !
Regards
May 23, 2009 | Gigabyte Computers & Internet
PC Chips M957G MB. Can the 4 rear 4 USB ports easily be replaced?
hi there,
Thank you
May 27, 2008 | PC Chips M957G Motherboard
PC Chips M957G Motherboard Logo
135 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
