Question about Sharp Office Equipment & Supplies
When I put in numbers and press the (-) red subtract button it adds the number.
If you go here http://www.sharp.ca/manuals/default2.asp you will find the op manual for that Facsimile Machine.
Posted on May 28, 2008
How do you simply add/subtract on a HR-10-TM Casio mini desktop printing calculator?
the function buttons are labeled + and -
to add put in the number then press the + button then put in the next number and + and son for all the numbers you are adding up
to subtract put in a number then press the- button ,then put in the next number and press the - button and so on
to do a combination calculation put in a number then press the + button and so on until you come to a number that you want to subtract in which case you put in that number then press the - button and if the next number is to be added ,put the number in and press the + button
Oct 22, 2015 | Casio Office Equipment & Supplies
What do i set it on to add and subtrack
To add, turn the calculator on and enter the first number. Press the + key and enter the next number. Press the = key and see the result.
To subtract, turn the calculator on and enter the first number. Press the - key and enter the next number. Press the = key and see the result.
Feb 07, 2015 | Casio Office Equipment & Supplies
Answer always appearing
Minus and change-sign are two completely different things. Minus is used to subtract one number from another. When you press minus when the input line is empty, your telling the calculator to subtract. The only way it can subtract the number you're about to put in is to subtract it from something else, and that something else is the previous answer, hence the "Ans."
If you want to input a negative number, use the change-sign key. If you want to subtract one number from another number, use the minus key.
Try pressing the plus key when the input line is empty. You'll get Ans+ in this case as well, The same with multiply and divide, among others, and for the same reason.
Sep 23, 2013 | Texas Instruments TI-84 Plus Calculator
I want to do subtraction. But when I enter the "
There's a negative button and a minus button. I think you're accidently pressing the negative button. The actual subtraction button is the red "-" button above the "+" button. I hope this helps, but if all else fails, you can always add a negative!
Apr 16, 2011 | Canon P23-DH Calculator
I do not have the manual. If I want to add or subtract do I put the total amount in and than hit the plus or minus key ? i.e., $128,000 -10000. do I hit the minus before the amount or after? -1500....
You can download the manual from
http://downloads.canon.com/cpr/software/calculator/P170-DH-(USA-HWB).pdf
128000 - 10000 then press = or chain the calculation by pressing + or - and the number you want to add or subtract.
Sep 30, 2010 | Canon P170-DH Calculator
How to add figures and then subtract from a larger number
use the + key after each number to add the total will appear on screen. When all numbers have been added, enter number to subtract and then press - key. The subtracted number will appear in read on the paper (if two color). and then press the star key to get total.
Jul 08, 2010 | Canon P23-DHV Calculator
How do I add and subtract on this thing?
I do know what calculator you have but on most calculators you have digit keys to key in numbers, operation keys (multiplication, division, addition, subtraction), function keys (log, exponential, %, square root, square or a power) and you have the = key to obtain the result of the calculation.
Press the [ON] button
To add 2 numbers, exemple 12 and 13
12 [+ key] 13 [= key]. Calculator displays 25, or 25.00 or 25.0000...
To subtract
13 [- key] 7 [=key] . Calculator displays 6 or 6.00, 6.0000....
To multiply
32 [x key] 5 [= key]. Calculator displays 160.
You may have memory keys, to store values. They may be labeled M to enter a number in memory, M+ to add a number to the one already in memory, M- to subtract from the number already in memory.
Hope it gets you started.
Oct 10, 2009 | Canon Office Equipment & Supplies
Tring to subtract
With an adding machine, which is what this is, you enter the number followed by the + or -. If you wanted to add 10+20, you would enter 10 then + then 20 then +. This would show your answer. If you are using the printer and you wish to see the final answer on the paper, hit the * key and your answer will print.
If you are subtracting, let's say 100-40, you would enter 100 then + then 40 then - then *. Adding machines expect you to enter long strings of numbers to total. You may have both positive and negative numbers. So, you always enter the number first followed by either positive + or negative -.
You might have 100 + 25 - 37 - 1 + 50. For that enter:
100+25+37-1-50+ then *
Different than a calculator but the same for all "adding machines". This machine should really be called an adding machine since that is the kind of input it is looking for.
Jan 13, 2009 | Canon P23-DHV Calculator
Car radio code
Check put the peugeot GSi 6 site.
I read there trhat the way to locate the code is;
1) pull out the radio ( I had to get the metal "keys", named sony at Halfords)
NB the slots for the 1995 306 are underneath the facia.
2) from the two numbers on the bar code...take the LAST 4 DIGITS of the BOTTOM number
3) add the following numbers in sequence to them;
a) add 1 to the first number
b) add 2 to the second number
c) add 3 to the third number
d) add 4 to the last number
IF ANY OF THE NUMBERS GO ABOVE 6 YOU MUST SUBTRACT SIX FROM IT AS THE RADIO CANNOT ACCEPT NUMBERS ABOVE 6.
To input the CODE into the radio, you need to keep pressing the number 1 button UNTIL you see the first number of your code displayed ie press it 3 times if entering the number 3 from your code.
Then use the number 2 button to enter the 2nd number of your code
Then the number 3 button to enter the 3rd number of your code
Then the number 4 button to enter the LAST number of your code.
God Bless!
Apr 20, 2008 | Car Audio & Video
47 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
