Question about Garden
Large neon sign above a sound stage is causing noticable hum in the audio mix when turned on. The sign is wired on a seperate circuit from stage power. Sharing a common ground? Thank you.
  • 25 Answers
Marty McCann posted this on Peavey Tech notes about "Hum and pin #1 with common ground. It helped me on a hum problem in several places I've worked. I'm sending you the link to his note on this plus the link to other sound related problems. Hope you find this useful.
http://www.peavey.com/support/technotes/soundsystems/humandpin.cfm
Posted on Oct 04, 2010
My bang and olufsen 7002 wont select the phono stage
The Phono/Aux input has a slider switch to the left of it to choose whether to make it a regular line-in jack or to utilize the phono stage. The ground terminal is just above the jacks. The Beogram 4002 likely has a muting circuit that's in effect when the tonearm is in the lift position, which would explain the lack of hum til the stylus lowered to the record.
May 19, 2015 | Bang and Olufsen Audio Players & Recorders
How do I adjust the mixer to remove humming noise?
I used to be a hi-fi enthusiast many years ago.
A low frequency hum can be caused by inadvertently creating a "hum loop". This is when audio separates are earthed or grounded where they are plugged into the power outlets and then connected together using screened audio leads where the screening is connected to both plugs.
The situation can become worse when one of the separates is a type that isn't grounded.
Ineffective or insufficient power supply smoothing and/or shielding leaving an AC ripple on the DC also creates a hum or in the case of poor design or bad shielding can radiate AC magnetism into the high gain input stages of amplification.
Whatever the cause of the hum it can be aggravated by poor matching of separates with regard to input/output sensitivities and impedances. If the pre-amp stage gains have to be high to compensate for a low input signal the signal-to-noise ratio will always be poor through every stage. Small signals requiring large amounts of amplification requires low impedance circuitry and appropriate sensitivity.
Food for thought...
Mar 04, 2015 | Samson Xm410 Powered Mixer
Replaced the starter,hook the battery up starter turns without the key on,why nis this?
starter switch faulty, not to be confused with key switch. or the relay wired up wrong. The two large wires on the relay should not be on the same connection, pay no attention to the red arrows, but the two large wires are seperate. Again, starter switch my first thought.
Dec 17, 2013 | 1998 Dodge Neon
I have Sansui G-9000, and its phono stages emit a buzzing/distorted sound even if a turntable is not connected. There is also no sound coming from the left speaker (I already tried switching the speakers,...
The Phono section has a very high level of amplification and so the audio input is very sensitive. So a possible faulty/loose grounding of the input can create a HUM which can be due to even a poor shielding of the input from stray AC factors. So you need to check for the these factors that can bring in the hum , you can confirm by isolating the phono circuit and working to the faulty stage.
Also it can be due to a faulty power supply - non filtering in DC- to the phono preamplifier.Finally faulty capacitors in power and feedback circuits can be a reason- check the negative feedback circuit which can be an op-amp with a feedback , check the capcitors here as a higher amplification can also be a reason.- check the preamp IC.
Oct 08, 2011 | Sansui Audio Players & Recorders
I have a pioneer xc-is21v .basically 2000 audio model which has a vcd player and amp with woofer . i get a humming noise in the speaker but not in the headphones pluged in amp.this is a low ?60hz hum...
It may be that your headphones just don't handle that frequency well enough for you to notice it. A hum at this level could be due to earth(grounding) problems caused by a double earth. If you have other devices (tv, laptop, CD player, games console and the like), plugged into your amp try unplugging them one at a time to try and identify the source of this hum. (I get this occurring with hum on my television if I leave my laptop plugged into my audio system - which the TV is also connected to - even if the audio system and laptop are powered off).
If this resolves the problem you may need to insert a ground loop isolator device between your amp and the device that is causing the problem.
Although this one (on sale in the UK from Maplin) is designed for car audio systems I use it on a public address system to eliminate ground loop hum on the stage fold-back amps. http://www.maplin.co.uk/ground-loop-isolator-33172
Feb 25, 2011 | Pioneer Audio Players & Recorders
When we are trying to get a reasonable level of sound for vocals before it gets loud enough to be able to hear clearly with the band playing it starts to clip at the speakers now we are only using this set...
Proper level setting of the mixer is important. HOWEVER if the clipping is occuring at the speakers the only possible problem MIGHT be that you have a supersonic feedback that is saturating the speakers above your hearing range, Be sure you don't boost the highs too much with the EQ as this can cause the feedback that you can't hear. Also make sure that you power the speakers from the SAME receptacle as the mixer, even if it means running an extension cord to bring power to the mixer. This is to avoid a low frequency hum and common mode distortion/damage. A low frequency hum could cause the clipping.
It would be a good idea to get a sound meter to check the sound level. You should be able to reach 85 Db from this system without clipping. If you need more than that, you MAY need more speakers if the band instruments are too loud. Also if the band has amps that get into the vocal microphones that adds to the clipping level... make sure the mics don't "hear" the band instruments. Make sure your speakers are toward the audience from the mics to avoid the supersonic feedback problem. If the vocalists can't hear themselves with that configuration you need to set up seperate stage monitors.
There are some pretty good videos on YouTube about proper mixer level setup.
Jan 30, 2011 | Behringer Xenyx X2442USB / Harbinger...
I have a Sony subwoofer for the home entertainment theater. There is a loud hum coming from the subwoofer. The hum persisits even if unplugged from the receiver. Also, I've tried a ground loop isolator...
Hi and welcome to fixya.
To answer your question;
From your description of the problem it sounds like your powered subwoofer has a power supply circuit problem.
It would be either with the large capacitors in the first stage of the supply(most likely) or with the regulation system that supplies +-15 volts to the preamp section.
If you are not familiar with electronic circuits you could still ask a repair shop to verify those large capacitors.
Hope this help and happy holidays.
Dec 06, 2010 | Sony Audio Players & Recorders
My Garnet Pro 200 tube guitar amp has low volume
You must first isolate the stage that is causing your problem. Start at the master volume control by injecting a signal using a screwdriver. If you get a good level of hum from the speaker then output and phase splitter stages are ok. Work your way back to the front end by touching the screwdriver to inject hum into the input grid of each valve in turn to isolate weak stage. Check anode and cathode voltages on valve of suspect stage. Check cathode bypass capacitor and anode/grid coupling capacitor for open circuit. If fault in output stage check screen grid resistors for open circuit. WARNING high voltages exist in valve amps, keep one hand in your pocket and do not hold on to the chassis while testing.
Feb 21, 2010 | Audio Players & Recorders
Buzzing sound in my speakers when I switch to the phono stage
It is a grounding issue with the turntable most likely. Some turntables came with a ground wire that you attached to the receiver. You can also try a power strip that has a line filter incorporated to get rid of the hum. Check the local stereo shoppe to see if they carry them.
You may also want to replace the audio cable that connects the turntable to the amp with a good quality shielded cable. If it has bad shielding it will pick up electrical interference and even radio interference as well.
Turntable inputs on receivers have a preamp built in and the gain for each type of pickup is different. The pickup is either ceramic or magnetic and if I remember correctly, the ceramic pickup needed more gain than the magnetic one. The preamp will definitely make a ground hum a lot more audible.
Cheers and good luck.
Dec 20, 2008 | RME Intelligent Audio Solutions RME...
Noise when it turns on
have you checked your music source? Some systems like computers have a sort of output first before normalizing, which isn't your powered subs or powered amps problem. Try plugging in a regular solid state player like an ipod if the humming is still there when automatically turning on or off...
Dec 06, 2007 | JBL PB12 Subwoofer
Garden Logo
75 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
