Question about Apple iPod MA446LL/A MP3 Player
How much is it to buy a new hard drive? - Apple iPod MA446LL/A MP3 Player
  • Apple Master
  • 7,482 Answers
Try this website, they have parts and instructions
http://www.ifixit.com/
Please rate me
Posted on Oct 04, 2010
Need nec versa e 6000 motherboard faulty . where i can buy the motherboard?
it is not worth it to purchase a new motherboard for around 200$ when you can buy a brand new computer for just a little bit more.
You can have your files moved from the old hard drive to the new laptop by a professional or you can do it yourself if you aren't a complete dummy with computers.
To do it yourself you would need to first remove the old hard drive from the old computer ( NEC ) and then buy a external hard drive case for it that fits to it - there are 2 sizes, 2.5" and 3.5", probably 2.5" hard drive and then there are 2 types of connectors, IDE and SATA. SATA has a flat connector, and IDE has around 40 metal pins sticking out of it.
buy the appropriate USB caseing for it and then connect it to your new computer, you can transfer your files from it to the computer, after you have done so, you can keep the old hard drive as a external hard drive, for backups for example.
Jan 04, 2011 | NEC Computers & Internet
I have a dell latitude E6400 that will not reboot. Can I buy a new hard drive for it....will that work..............
Hello
you dont need to buy new hard drive until you confirmed that your hard drive has no more, for the purpose you need check in CMOS setup, if it is detected by computer then there is a chance to re-use the hard disk, you just need to re-install windows, during installation format the hard disk after re-partition.
if this method fails then you need to buy new one, good luck
do rate the solution if got help
Dec 11, 2010 | Dell Latitude E6400 Notebook
Usb input from hard drive to computer is broken
Will replacing the data-cable replace the broken-off piece?
If not, then for about $30, you can buy a new "empty" external case, and then "transplant" your current disk-space into the new case.
Take your current external drive to the computer-store, so that the new case that you buy will be the correct case for your existing disk-drive.
Of course, because you have a "small" (100GB) disk-drive, any warranty for the disk-drive probably has expired, and it would be good "preventative-maintenance" to buy a new external disk-drive, before your current disk-drive unexpectedly "quits" on you.
Jun 15, 2010 | Maxtor Personal Storage 3100 (M01E100) 100...
My hard drive failed and erased all our stuff now we cant even make our own profile orsave anything what do i do?
Seems like your hard drive might have crashed. I would suggest buying a new one, as well as perhaps buying an Xbox 360 memory unit. It's a lot cheaper to buy a new hard drive than it is to buy an entire new Xbox 360, plus you already have a working console, just not a working hard drive. As far as I know, there is no way to fix a hard drive that's messing up. I would contact Microsoft just in case though.
Otherwise, buy a new hard drive and sadly, start from scratch.
Another thing I would try first though, is testing the hard drive on another console. If it works on the other console, it might be your original console that isn't working (not the hard drive). (You can only do this if you have a detachable hard drive though of course.) If you don't have a detachable hard drive, you won't be able to replace it by simply buying a new one and you won't be able to test to see if it's the hard drive or the console in which case, you have to contact Microsoft regardless.
Hope I was of some help, best of luck.
Feb 01, 2010 | Microsoft Xbox 360 Console
I need a hard drive for my Toshiba Satellite M55-s135. What should i buy and how do i buy it?
The type of drive you need is an IDE drive. You can buy a new a new drive online through places like www.tigerdirect.com or www.bestbuy.com or in a store such as Best Buy or even Office Depot.
Please make sure you buy a laptop IDE hard drive...all others will NOT work.
Dec 23, 2009 | Toshiba Satellite M55-S135 Notebook
Not saving games lost files seems to be corrupted
You can try to reformat the entire hard drive, or you can buy a new hard drive.
To reformat the drive, in the PS3 menu:
NOTE: This will erase everything you saved on the hard drive.
1) Go to the Settings menu, then select System Settings.
2) Select Format Utility, then select Format Hard Disk.
3) Select Quick Format
To replace the Hard Drive, buy any 2.5 inch notebook hard drive that has a serial ATA connection. Then remove the old hard drive from the left side of the PS3 and install the new hard drive.
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
Should I buy Refurbished or used hard drive ( Seagate Momentus SATA 160Gb) to save some money? Any experience on that?
it's okay to buy refurbished hard drive as long as there's a minimum of 3-5 days warranty so can have the time to check if there's any error on the hard drive....
Nov 12, 2009 | Seagate (ST3160827AS) 160 GB Hard Drive
Hard Drive
You can replace it with a larger one, just make sure you buy the proper hard drive. If its and IDE hard drive, buy and IDE hard drive, if its an SATA Hard drive, buy an SATA Hard drive. also make sure after you install the new hard drive that you use the operating system cd to format the drive and to install the operating system.
May 04, 2009 | E-Machines T1840 CELERON 1.8 GHz 128 MB 40...
Apple iPod MA446LL/A MP3 Player Logo
13 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
