Question about Whirlpool Dishwashers
I'm going to install a gu2700xtst dishwasher over a laminate flooring. The dishwasher is on order and I do not know the minimum height. How much clearance do I need under the counter top?
  • 525 Answers
The dealer should be able to provide you with that info.
Posted on May 27, 2008
Instruction not clear asto wether an underlay is needed or advisable on top plywood I am replacing laminate floor with these click fit tiles
An underlayment is usually used to either; raise a floor to a certain height or to give a resilient floor a smooth surface that won't mirror what I is under it. That being said. ... check that the floors transition well. ... height wise. Determine if existing floor is sound, ie no squeaks and is strong enough to not flex under foot then proceed with your floor
May 04, 2015 | Building Materials
Hi friends just I need know how much charge for a room of 10ft by 10ft of laminate floor wood how much by square foot thank you for your help
Maybe a bit late ...but typical rates are 2.00 per sq ft. Plus base shoe installation and or tear out of whatever is down now.
Some areas will install laminate for as little as 1.50- 1.75 per sq. Competition can be fierce.
100 sq ft in your case I would make sure to have a minimum of at least 200.00 for the day ...especially if there is tear out involved ..a helper... fuel ...tools etc You get the idea
Base shoe is additional as well.
Oct 12, 2014 | Building Materials
Is Pergo the same as laminate?
Pergo is the name of a specific manufacturer of laminate flooring
make sure you follow all the instructions in the package when installing a laminate floor. They all have slightly different methods for success.
Jun 29, 2014 | Dream Home - Ispiri 12mm Americas Mission...
What are the advantages of laminate flooring over hardwood flooring?
First, you can get the exact visual design that you wanted and it will cost you considerably less. Second, laminate flooring can be installed above and below the grade unlike hardwood flooring. Moreover, the laminate flooring is installed without using any nails or glue which make it much easier to it yourself. Furthermore, laminate flooring is extremely durable, easy to maintain and can be replaced easily.
Feb 06, 2013 | Building Materials
Can I put laminated floor over my carpet?
Laminated floors are possible to install over virtually any type of floor you have although over carpets and especially high-pile carpets it is not advised.
How much laminated floor should I get?
You get an idea on how much laminated floor you will need by measuring the length and the width of the rooms that you plan on installing laminated floor, multiply the length by the width and add 10 percent for installing errors and variation in floor design.
My cabinet maker needs to know the minimum height needed to install it in the custom cabinets. A copy of the specs. would be appreciated. Thanks.
There is no spec which is 100% correct - you should pick the dishwasher you want and buy it and if need be let him go pick it up
Sep 24, 2010 | Dishwashers
Dishwashwer wont fit under counter
it depends on how much tallerit is . you can adjust the legs but you have to know how much. if this helps let me know.
Dec 27, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwasher leaking on floor
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
wata
Feb 26, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Installing GU2700XTST , I dropped a screw inside the pump area
Follow the series of pictures at: http://www.flickr.com/photos/appliancejunk/731287159/in/photostream/
Jan 12, 2008 | Whirlpool GU2700XTSB / GU2700XTSQ /...
Dishwashers Logo
76 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
