Question about Canon FAX-L1000 Plain Paper Laser
Comm error I am regularly getting the "Comm Error" message when receiving faxes. Although occasionally the fax does receive, it is the exception rather than the rule. I have checked the set-up and re-set it several times, but there is no improvement. I have swapped the m/c with another fax (a FAX-B160) which works perfectly,again with no improvement. Any suggestions?
Could be down to the line, had a similar issue which I believed to be hardware related, so got supplier to send a new fax out, spoke to someone at canon who said is def hardware related, any yet it turned out to be rabbits outside chewed through a cable (was in scotland..) so was a BT issue.
Posted on Jul 28, 2008
My fax can receive but is unable to send. Message is COMM ERROR 2
Your machine failed to communicate diring the initial protocol. This is the handshake that tells the receiving fax that you are what you are. IMPORTANT Check that your fax ID is entered in the fax, as some countries require that if it is not present to reject it. This can also be set on any receiving fax to reject junk fax. So Both the TTI and the CSI must be entered in your fax to work.
Oct 06, 2010 | Sharp FO 760 Plain Paper Thermal transfer...
Fax comm error 232 problem
Hello sir ; Why don't try to replace a phone cable or check the wall jack.
Aug 28, 2009 | HP LaserJet 3050 All-In-One Printer
Brother FAX 8360P comm.error
It could be line noise on the phone.., which allows phones to work ok, but causes problems with faxes. See this document from the brother website concerning comm.error:
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000100/000067/faq000167_000.html?reg=us&c=ca&lang=en&prod=fax2800_us&Cat=11
Would recommend having the phone company run a line check to make sure the phone line is clean of interference !
Jan 21, 2009 | Brother FAX-8360P Plain Paper Laser
Receiving Problem
Do you have a DSL or any other digital phone line?
Are you set to "AUTO RECEIVE" ?
Call the fax machine from a regular phone and listen for fax tones.
Sep 29, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Laserjet 3330 is resulting in fax Comm Errors 327, 232, 442, 356, 421 Comm Error 327 is always with fax # 780.467.6516. i can not fax to this number and when i receive from it, it always prints a Fax...
232-A communication failure has occurred between the two machines.
327-*Reattempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
356-The remote user has pressed the Stop key, causing the session to be aborted.
442-An error occurred during transmission after one or more partial pages had been sent. The transmitting machine was unable to restart the control channel (handshaking) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page but can also occur if the receiving fax is using a fax format that is incompatible with the HP fax machine (usually during color faxing).
Aug 15, 2008 | HP Computers & Internet
Rx comm error 200082 on receiving fax Ricoh aficio 222SF
I have Dell Monolaser MFP1125, can not send and receive fax
Aug 04, 2008 | Office Equipment & Supplies
Comm. Error
Try this website: http://www.instruccionesweb.com/u2/pdf/fax/Canon-L120-en.pdf
Jun 25, 2007 | Canon L120 Fax Laser Printer
Brother MFC 3360C
Try turning off ECM (error correction mode or overseas mode). Try calling the fax # from a regular phone line - If you hear the fax shrill tones you know you've got the right #) I it does not go through, you should get an error code #. let me know what it is
May 02, 2007 | Brother MFC-3340CN All-In-One InkJet...
Canon FAX-L1000 Plain Paper Laser Logo
225 people viewed this question
old marine
old marine
