Question about Kyocera Mita KM-3035 All-In-One Laser Printer
Failing to Configure KM3530
I have connected my KM3530 on the LPT1 Port but cant print. I nstall he drivers.
  • fdoriossjr Jan 06, 2009
    Have the problem to configure my km3530 printer and the scanner with win xp
    Genius:
  • 2,120 Answers
Try USB
Posted on Jan 02, 2009
WHY DOT MATRIX PRINTER NOT PRINTING DOS BASE PRINTS
It can't.
DOS printing need LPTx parallel port because DOS don't understand/support USB.
YOU can share the printer with windows printer driver, then
go to CMD prompt
Type
Net use lpt1 \\<computername>\<printersharename>
Then print DOS job to LPT1
May 12, 2014 | Parallel USB Print Server 2 Port USB&1...
Looking for printer software hp656c for my laptop windows 7 (32 bit)
Thats quite an old printer, it should work with a generic printer driver for basic text printing, otherwise try some of windows 7s built in HP injet drivers. I doubt you will find a specific windows 7 driver for this model, its out of support life
Mar 17, 2011 | Computers & Internet
Driver for windows 7
According to the Hewlett-Packard support website, DOWNLOAD the DeskJet 3600 Series driver for Windows 7. It is equal to the USB driver for the DeskJet 3325. At the present time, the Deskjet 3600 Driver is available thru WINDOWS UPDATE ONLY. Enable WINDOWS UPDATE on your Windows 7 PC and manually download this driver.
At this time, a full feature Windows 7 driver solution is not available for your product.However, a compatible print driver solution for your product is included with the Windows 7 operating system. There is no need to download any additional software. Follow the steps in this document to identify the print driver that is compatible with the product, install the driver, and then configure it in Windows 7. When this driver is installed, you can use the basic functions of the product.
Follow these steps to install the compatible driver in Windows 7.
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon (c01319360.gif), and then click Devices and Printers. The Devices and Printers window opens.
  3. Click Add a printer. The Add Printer window opens.
  4. Click Add a local printer.
  5. Click Use an existing port.
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port), and then click Next.
  7. Under Manufacturer in the Install the printer driver window, click HP.
  8. Under Printers, select the appropriate alternate driver for the product (listed in the table in the previous step), and then click Next.
  9. NOTE: If your HP product is available through Windows Update, click the Windows Update button to select additional print drivers. You must connect to the Internet before using Windows Update.
  10. In the Printer name text box, type the product name and then click Next. The print driver starts the installation process.
  11. NOTE: The name of the alternate driver displays in the window as the default name. If you prefer, you can change the name of your product. This step is optional.When the installation is complete, a message displays on the computer stating that the product was added successfully.
  12. In the message window, click Finished.
  13. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  14. Click Close (c01900743.gif) to close the window.
Follow these steps to configure the installed driver.
  1. In the Devices and Printers window, right-click the name of the product and then click Printer Properties. The Printer Properties window opens.
  2. Click the Ports tab.
  3. Click the drop down menu, and then change the port from LPT1 to USB or DOT4.
  4. NOTE: If there is more than one USB/DOT4 port available, select the USB/DOT4 port with the highest port number. To see the full port name, widen the ports row in the Properties dialog box by placing the cursor over the vertical line between Port and Description, and then click and hold the mouse button. Move the mouse to the right until the port name is visible.
  5. Click OK.
Jun 07, 2010 | HP DeskJet 3325 InkJet Printer
How do I add a printer to my laptop
At this time, a full feature Windows 7 driver solution is not available for your product.Follow these steps to install and configure the driver that is compatible with the product.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers . The Devices and Printers window opens.
  3. Click Add a printer . The Add Printer window opens.
  4. Click Add a local printer .
  5. Click Use an existing port .
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port) , and then click Next .
  7. Under Manufacturer in the Install the printer driver window, click HP .
  8. Under Printers , select the Deskjet 660c and then click Next.
  9. In the message window, click Finished .
  10. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  11. close the window.
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties . The Printer Properties window opens.
  13. Click the Ports tab.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4.
  15. Click OK .And print a Test Page.
Regards,
Riztech
Jun 01, 2010 | HP DeskJet 656c InkJet Printer
Cant load driver in port lpt1
AN IEEE 1284 port is a parallel port protocol. Lpt1 is a physical port on the PC that attaches to the printer.
Basically, the PC is telling you that it expects the printer to be connected to the LPT1 port on the printer and that it is expecting the printer to be conversant with the IEEE1284 protocols.
Given what you have described, you should not be having a problem connecting the PC to the printer.
Please let me know what the exact failure is and the make and model of the printer that is causing the communication between the PC and printer to go "Toes Up."
Don
Dec 11, 2009 | HP OfficeJet T45xi All-In-One InkJet...
Unable to install printer
Step one: Determine the appropriate compatible driver
Since there is no driver for the deskjet 656, the hp site says the alternative driver would be for the deskjet 660c. There is no need to download it as it comes with Vista, but we will need to install and configure it.
Here are some directions:
Step two: Install the driver
1. Verify that the Universal Serial Bus (USB) cable is not connected to the printer.
2. Click the Windows icon ( start ), click Control Panel , click Hardware & Sounds , and then click Printers .
5. Select the Use an existing port check box.
6.In the Use an existing port drop-down list, select LPT1: (Printer Port) , and then click Next .
7. Under Manufacturer on the Install the printer driver dialog box, select HP .
8. Under Printers , select the appropriate alternate driver for the printer (in your case, the 660c) , and then click Next .
9. In the Printer name text box, type the printer name, and then click Next . The printer driver starts to install.
NOTE: The name of the alternate driver displays as the default name. Change this name to the name of your printer, if desired.
10. After the computer displays a message that the printer was successfully added, connect the USB cable to the printer and to the computer.
11. On the Found New Hardware screen, click Cancel .
NOTE: If multiple pop-up windows display, click Cancel on each window.
Step three: Configure the driver
1. In the printer folder, right-click the name of the printer, and then click Properties .
3. Change the port from LPT1 to USB
4. Click Apply .
Step four: Print a test page
1. Click the General tab.
2. Click Print Test Page .
Dec 15, 2008 | HP DeskJet 656c InkJet Printer
New comuter with windows vista and can not load printer hp photosmart 7660
1. Verify that the Universal Serial Bus (USB) cable is NOT connected to the printer.
2. Click the Windows icon, click Control Panel , click Hardware & Sounds , and then click Printers .
4.Click Add a local printer .
6. In the Use an existing port drop-down list, select LPT1: (Printer Port) , and then click Next .
8. Under Printers , select "Deskjet 5600"
Now let's configure the driver
3. Change the port from LPT1 to USB.
Now let's make a test
1.Click the General tab.
Your printer should start printing in a few seconds.
Dec 02, 2008 | HP Office Equipment & Supplies
Zebra printers & MS Word
HI Les1810,
You should be printing faster with Zebra fonts.
Which driver are you using? Version?
I strongly recommend the Zebra Designer V1.3.08, available at Zebra.com
To isolate the problem, capture the output to a file.
Define a local port as C:\output.txt and set that as the port in driver properties.
Now print your document. The printer commands will be in C:\output.txt.
Send c:\output.txt directly to your printer.
For LPT1, use the DOS copy command to send the file. (Copy C:\output.txt LPT1)
For serial connections, use Hyperterm to send the file.
For network connections, use ftp.
No easy USB method is readily available.
Does this print faster than printing the original document from Word through the driver?
If yes, then update your driver.
If no, debug your communication to the printer (LPT1, serial, network, etc.)
Sep 24, 2008 | Zebra TLP 2844-Z Thermal Label Printer
CANNOT PRINT WITH NEW COMPUTER
I had many problems with Vista fixed in this way.
1) Unistall drivers supplied with printer
2) Download new Vista drivers
3) Disconnect printer
4) Restart computer
5) Install new drivers (connect printer when it asks)
6) Restart computer
For me it now works.
Jan 15, 2008 | Lexmark Z640 InkJet Printer
Printing,hp deskjet3420
Hi Malcom,
The HP3420 is connected to your PC through the USB port and not through the LPT1/parallel port.
You have to change the port setting. Go to Start, Printers, right click on HP3420, click on Properties, go to the Ports tab, check/select USB, OK.
Alternately, you may have to re-install the drivers for the HP3420 and allow the program to Search for the printer connection. Clicking on the button Stop Searching will auto install it again to LPT1.
Hope this be of some help/idea. Post back how things turned up or should you need additional information.
Good luck and kind regards.
Oct 25, 2007 | Computers & Internet
Kyocera Mita KM-3035 All-In-One Laser Printer Logo
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
