Question about Sony Cyber-shot DSC-S700 Digital Camera
Lens not cumin out
Hi... actually i was lukin at the pics in my cam, and the battery was going to die. so i took out the batteries without closing photo section and now my camera is not working... i can luk at my pics but i can't take any new pics, because the lense is not coming out. Can someone please help me.
  • 10,594 Answers
Hello adorbalgurl,
Try this procedure, while pushing power button ON, turn lens clockwise or anticlockwise with littel force. Please remember, don't turn the lens with much force because it can be damaged easily.
Posted on May 27, 2008
My screen is blank can not see anything
do you have the lens cover open? do you get any error code or warning message? do this: make sure you have fully charged battery. close the lens cover.make sure cam is lens cover by sliding it down until click is heard.if no go.close lens cover.make sure cam is off.remove the battery from cam for at least 15secs.reinsert lens cover until you hear the click.if no go try this. can you see the operational buttons and icons on the screen? if you do try to initialize the camera. touch HOME ->settings (looks like a toolbox icon) -> Main Settings (touch OK) -> [Initialize] -> [OK]. if it doesn't work service might be required.thanks :)
Mar 19, 2010 | Sony Cyber-shot DSC-T9 Digital Camera
Lens cover would not close. Now camera will not turn on.
Lens cover not close, This will happens due to two reasons.
1) Either your camera battery got died or need to be recharged or replace. or 2) Your camera is malfunctioning and need service (repair).
To resolve the problem. first check battery on your camera, If battery indicator shows battery low, than you need to charge it or you need to replace your battery.
Rating the solution is highly appricaited...Good Luck.
Mar 03, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Camera doesnt work, got as a gift about 6 months ago and took out
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. This camera has an auto lens. Which means it will focus automatically every second, which makes this clicking sound. You can turn this option off: 1: Go into the menu 2: Chose option Cam Settings 3: Switch AUTO focus to single lens and click OK.
Jan 07, 2010 | Kodak EASYSHARE M1063 Digital Camera
Not turning on and has strange smell
Powershot A640 Could Not Be Powered On, Burnt Smell
My Powershot A640 died during a picture shot, lens remaining open. I thought it may be due to the dead batteries. But after putting new batteries and pushing the on/off button, the on/off indicator blinked once then shut off by itself. After a while, a strange smell came from camera batteries area, and I could feel warm there too. Immediately I took out all the batteries from camera.
When checking the posts here the other day, I tried one solution and got the lens back to close: first took out the memory card from camera, then put the new batteries in; push the on/off button with no memory card. I found the lens retracted a little before camera shut off by itself. I pushed on/off button three times to get the lens fully close. However, the burnt smell came out again. I immediately took out the batteries.
Did I get a short circuit inside? Is there any ways to fix it?
Oct 31, 2008 | Cameras
My Nikon D-40x has an auto focus that won't auto focus. Becasue it won't focus, it won't take a picture with the lens set to that mode. One day the camera worked fine. I put it up in the closet for about 5...
If your camera won't turn on then please remove the mem card and then insert the battery and see if it turns on.Next clean the contacts of the battery properly.
Let me know the result.
Oct 03, 2008 | Cameras
Camera won't power up
I think there is some internal problem.However try resetting the camera.That is first remove the memory card if you are using one,and then just check if the camera is working fine.Because there might be possibilities of the memory card being defective.So if the camera is working fine without the memory card then use a different memory card.But if the camera is still not working try removing the batteries and put them back in.If its still not working then you have to service the camera.
Sep 07, 2008 | Cameras
Kodak easy share z612 will not turn on to take a picture
When the battery dies, usually the camera will retract the lens if possible. If the battery is so dead the lens can not retract, I would recommend trying to charge or change the battery. Or try to turn the camera on, and then manually shutting it off if you can.
Nov 16, 2007 | Kodak EasyShare Z612 Digital Camera
Won't take pictures after batteries died
no u can't do that stupids never take out tha card now u messesd up big time sorry
Nov 12, 2007 | Fuji FinePix E510 Digital Camera
The lens doesnt close and when i turn the camera on it bips three times and the screan shuts off. the lens wont close.
The batteries need to be changed. The digital batteries sold at the stores die out too fast. I had this same problem. In result, I purchased rechargeable battieries.
Nov 19, 2006 | Samsung Digimax S500 Digital Camera
Sony Cyber-shot  DSC-S700 Digital Camera Logo
37 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
