if the teak is bare teak --- a light sanding with a sanding block should be good and then follow that with a good rub down of teak oil ( sea-fin teak oil is a good brand ).
if the teak is finished teak --- and you want to remove the old finish and sand out any stains(?) then you will need to use a more aggressive sand paper and finish off with a lighter sand paper,, clean up with acetone, use a good tack cloth and start applying varnish -- the best varnish that I have ever used is a brand called ' Epiphanes ' and you will either want to use a ' matte ' finish or a ' gloss /semi-gloss ' finish. personally I have found the 'matte ' finish to look better and it brings out the true beauty of the teak itself. ( make sure you follow the sanding instructions between coats as this will give you a nice smooth and sharp look ).
enjoy the water ---
Shut the machine off, unplug the finisher from the copier, then plug it back in. Make sure the finisher is securely attached to the machine, then turn the machine back on. If that doesn't work, remove the finisher completely and use the machine without. Call a service technician to diagnose your finisher problem.
(fn) stands for finish nail,,, and there are different types of those,, this hitachi will use 15 guage, angle finish nails,, do not attempt to put 16 gauage strait or 16 guage angle nails in this gun,
AchievementsAccomplish the indicated achievement to get the corresponding number of Gamerscore points:
Tournament Completion (50 points): Finish the Tournament game mode.Tournament Master (40 points): Finish the Tournament game mode in first place (Gold Medal).Rapala Series (25 points): Finish the Rapala Series event.American Tour (25 points): Finish the American Tour event.Lund Series (25 points): Finish the Lund Series event.Elite Tour (25 points): Finish the Elite Tour event.Ranger Tour (25 points): Finish the Ranger Tour event.Legends Series (25 points): Finish the Legends Tour event.Rapala Pro Tournament (25 points): Finish the Rapala Pro Tournament event.Time Challenge Completion (50 points): Finish the Time Challenge game mode.Arcade Challenge Completion (50 points): Finish the Arcade Challenge game mode.Bass Champion (20 points): Catch 40 Bass.Perch Champion (20 points): Catch 40 Perch.Trout Champion (20 points): Catch 40 Trout.Catfish Champion (20 points): Catch 40 Catfish.Salmon King (20 points): Catch 20 King Salmon.Fish Master (25 points): Catch every fish in the game at least once.Fishing Boat Expert (20 points): Use all boats at least once in a tournament event.Shore Fishing Expert (20 points): Catch at least 15 different fish species casting only from the shores.Master of Deceivement (135 points): Finish the Tournament game mode with every character in the game at least once.Fishing Rod Expert (25 points): Catch at least 20 fish using every rod in the game.Fishing Reel Expert (25 points): Catch at least 20 fish using every reel in the game.Fishing Line Expert (25 points): Catch at least 20 fish using every fishing line in the game.Lure Master (75 points): Use each lure at least 10 times.Lure Apprentice (25 points): Catch at least 10 Lake Sturgeon using a single lure type.Lure Expert (25 points): Catch at least 30 Chain Pickerel using a single lure type.Lure Specialist (50 points): Catch at least 60 King Salmon using a single lure type.Always Ready (25 points): Catch your first fish within the first 2 minutes of entering a new tournament fishing day.Quick Fishing (40 points): Catch your first 3 fish in a new tournament fishing day in less then 6 minutes.Bad Weather (20 points): Catch at least 40 fish while in bad weather.
Do you mean you have internal finisher? Try to make any copy with staple it should comes out from there, if not you have to go to machine setting or copy setting , you do this by pressing menu buttom, and change the output paper to the internal finisher.
77-2 is a finisher prob..Make sure nothing is under the finisher like a small trash can preventing the finisher from moving up/down.Turn off then on,if prob. still there remove finisher by pressing a pen/pencil in small hole inside finisher door and pull fin. towards you. This will let you use copier until service rep. gets there.
Click Click File-> Print, and when the print dialogue pops up, click Properties. In the printer driver dialogue that opens select Spot Colour, click the Spot Colour button, select Finish (Glossy Finish) and print.
