I have intel 845 chipset mother board and celeron 1.7 GHz processor will 250 GB SATA Hard Disk supports to this configuration?
  • 32,281 Answers
If your motherboard has a SATA controller then you would not have any problems.
Posted on Oct 04, 2010
Will the D915GEV support window7
Yes: Windows 7 can be used with this board.
If you want to run Windows 7 on your PC, here's what it takes:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
Here's the specs on the D915GEV
(See PDF Manual)
Click here:
D915GEV Technical Product Specification [PDF]
The Intel 915G chipset consists of the following devices:
• Intel 82915G Graphics Memory Controller Hub (MCH) with Direct Media Interface (DMI) interconnect
• Intel 82801FB I/O Controller Hub (ICH6) with DMI interconnect
• Firmware Hub (FWH)
The MCH is a centralized controller for the system bus, the memory bus, the PCI Express bus, and the DMI interconnect. The ICH6 is a centralized controller for the board’s I/O paths. The FWH
provides the nonvolatile storage of the BIOS.
Supported Memory Configurations.
Up to : • 4 GB maximum total system memory.
Processor:
The board is designed to support Intel Pentium 4 processors in an LGA775 processor socket with an 800 or 533 MHz system bus.
Note: All processors available for this board are in excess of the 1 gigahertz (GHz) minimum requirement for Windows 7. (see here) http://www.intel.com/support/motherboards/desktop/d915gev/sb/CS-026957.htm
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks.
Feb 08, 2010 | Intel D915GEV Motherboard
I HAVE AN INTEL D845GLLY MB WITH 1.6 GHZ PENTIUM 4 PROCESSOR AND 512 MB RAM AND VGA SUPPORT I HAVE INSTALLED WINDOWS VISTA BUT MY MOTHER BOARD CD DOESNOT RUN IN IT IT RUNS IN XP ENVIRONMENT AN APPCRASH...
today also some models of 845 chipset motherboards available in the market.Try to get the mother board cd of latest 845 chip set.
else you better go to xp
Jan 25, 2010 | Computers & Internet
I have asrock 845 mother board this board is not support my ext. hard drive .so plz give me solution.
1. If your system running Windows in SATA HDD, this will not support SATA External HDD
2. Better you try low capacity HDD such as 80GB, this will support and work with your system
thanks
ehsan
Jun 15, 2009 | Buffalo Technology 250GB USB SATA 2.0 HD...
S-ATA Hard Disk not detect
hi Dear,
You have to update your BIOS. If you have intel mother board just go thought their website and download BIOS Flash utility of your particular Board and Update BIOS.
The above fix will surely solved your problem.I had same problem as you and it's now fixed.
May 10, 2009 | Computers & Internet
Maximum MB or GB of graphic memory supported by Celeron d 325?
you can as high graphics card as you want as long as the is a PCI card.
hope this helps.
please rate good.
Mar 01, 2009 | Intel Celeron D 325 2.53GHz 533MHz 256KB...
250gb sata hard disk to 845 glad mother board
Hello all. I have the same issue. My MB is 845G [P4 2.4 Ghz] and SATA harddisk I need to install is Seagate 250 GB Baracuda with 3.0Gb/s interface, I belive which makes this HD as SATA II. So for this motherboard should I prefer PCI cards which support SATA II over the supports SATA I [these are cheaper].
Thanks so mcuh!!!
May 12, 2008 | Computers & Internet
Compatilblity with 845G mother board
try update the system bios because there were motherboards that had compatibility problems, this board is not a new one so it should work with your processor
Feb 07, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Ram support for intel 845 motherboard
Ok. So you've defined the Intel 845 chipset on your motherboard.
But is it the 845 or 845G chipset?
Click HERE for the specifications of the Intel 845 chipset.
Click HERE for the specifications of the Intel 845G chipset.
Peepnklown is only HALF right.
The Intel 845 chipset does NOT support PC133 memory.
The Intel 845G chipset DOES support both DDR and PC133 memory.
The difference?
The 845 has a single memory controller for DDR memory.
The 845G has two memory controllers. One for DDR and one for PC133.
Although you're going to need DDR memory as it is FASTER and less expensive than the older PC133 memory. (Believe it or not.)
I do NOT recommend using Corsair's ValuSelect memory on this chipset. I have two boards with the 845G chipset and that type of memory does not allow the board to boot.
These boards typically come with DDR266 (PC2100) modules installed.
I would go ahead and buy DDR333 (PC2700) memory for it. The board you have may not utilize the full speed of that memory, but will use tighter memory timings if the RAM is clocked down by the board. This will result in better efficiency of memory use by the processor.
Think of it as giving the motherboard "breathing room".
I could recommend PNY memory for the most basic compatability. (Not that they manufacture their own RAM modules...) Or perhaps Nanya, Infineon or Microtek.
Look for memory compatability lists for your particular motherboard module online. You could also use PNY's memory configurator on their website.
Click HERE for PNY's memory configurator.
Good luck.
Cyryl
Nov 10, 2007 | Intel Motherboard
Problems with Oracle Applications Installation on ASUS 945 MotherBoard with Intel Dual core 3.0 Ghz Processor
It isn't the motherboard or your PC. Install the latest service pack and security updates for you computer. You didn't say what version of Oracle you are installing.
Jun 26, 2007 | ASUS Intel 845D Chipset P4B266 (P4B266-PA)...
Computers & Internet Logo
David Payne
David Payne
