Question about Panasonic Heating & Cooling
I have a Panasonic air conditioner model CU-E12EKU (inverter). The unit stop working and the timer indicator is blinking. I checked for this error and followed the instructions in the Operating Manual, page 4. The error code I got is : error code 16 (in the remote control unit). What is this? Please I need help. Edwin Berrios Mayaguez, Puerto Rico
3 Suggested Answers
  • 333 Answers
SOURCE: MY WALL AIR CONDITIONERS PANEL IS GETTING FROSTED .
You should have this unit checked for freon leaks. This usually happens when you are low on freon.
Posted on Nov 23, 2008
SOURCE: Panasonic Inverter CS-E12EKU timer indicator blink.
Today I install a new unit Panasonic CS-S13KKP also have a same problem timer blink and the outdoor unit wont start. Error code is 11. after checking the problem, can not using a 3 cable cord, solve the problem using 4 Cable cord and its run !
Victor
Posted on Dec 11, 2010
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
Timer blinking.outdoor unit does not functioning. what was the error?
Looks like you said it, the outdoor unit is not working. Check for power to the outdoor unit or try cutting power to it, then after a minute restore power in attempt to reset it.
Apr 28, 2015 | Panasonic CU-E18JKK-1/CS-E18JKKW-1 Wall...
Indicator light keep blinking for SHARP ECO INVERTER
The unit has popped up an error code. There is something wrong with the unit. What is the model number? 25325502-u40lsvyytnuesyuv3fbafhtd-1-0.jpg
Dec 16, 2014 | Kenmore Ac Airconditioner Remote Control...
I have a Panasonic air conditioner model CU-E12EKU (inverter). The unit stop working and the timer indicator is blinking. I checked for this error and followed the instructions in the Operating Manual,...
Not sure if yours has a letter 'H' before the 16 but if it does, it's the:
- Outdoor Current Transformer open circuit.
which means that your outdoor controller board is faulty.
Sep 08, 2011 | Panasonic Heating & Cooling
Panasonic air conditioner CS-E24GKR...The unit stops and the timer indicator blinks. Also displays error code H 11...Help...Please...its hot in here
H-11Indoor / outdoor abnormal communication. Check • Internal / external cable connections
• Indoor / Outdoor PCB
Jan 04, 2010 | Panasonic CS-A12C Air Conditioner
Panasonic Inverter CS-E12EKU timer indicator blink. The unit not work at all, I follow the manual instructions using the remote control but the instructions are not clear. Using other similar Panasonic...
Victor
Aug 21, 2009 | Panasonic Heating & Cooling
I've got a pana inverter CS-E24FKR, and the timer icon is blinking. I have not set a timer and i can not get the unit to respond. I tried holding the "check" button down for 5 seconds, then...
This is a sign of a bad board. They are cheap and easy to replace. They will need to be replaced or you will continue to have this problem for as long as you own the unit
Jun 03, 2009 | Panasonic CW-1006FU Air Conditioner
I had the same problem with a Panasonic Inverter mini split model cs-e12eku and i had to turn it off using the main power breaker switch. ( I could never get the darn error code.) I left it off for a couple of minutes and it seems to reset. My uncle is in the ac business and he has heard from other ac techs that the Panasonic ac's are problematic, sounds like it might be true...I suspect that the time, my unit worked perfectly for from 11/06 to June 08 and living in the tropics I used it every day I havent called Panasonic but it sounds like a faulty circuit board.
Jun 03, 2008 | Heating & Cooling
Panasonic split system air con cs/cu-e24gkr
check the indoor unit sirkit board,there is problem.
Feb 14, 2008 | Heating & Cooling
Heating & Cooling Logo
210 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
