Question about LG LS-L1210CL Mini Split Air Conditioner
My 3-year old LG air-conditioner was leaking water. So i called some 'experts' to come fix it. This is the first time I called for maintenance service on the air conditioner. The 'experts' dismantled some parts of the air-conditioner and washed out a lot of dirt and sticky stuff. After they put the air-conditioner back, there was no more water leaking but I noticed 2 new problems. When I switch on the air conditioner, the mouth does not immediately swing open, it takes about 3 minutes before it swings open. Second problem is worse -- after the air conditioner runs for 5 minutes it starts to spew white flakes like it is snowing! What should I do?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 6 Answers
White snow.. I had this issue when 2 inside unit electrical lines were hooked up backwards at the compressor. The compressor would pump too often and overcool the inside unit, because it was using the wrong temperature sensor. But you could have a different issue. I'd have them recheck your freon levels, that can cause it to cool too much - should be 120-135psi when it is running, after 5-10 minutes or so. They adjust this for the outside temperature though.
Posted on Oct 10, 2010
My heater control valve has a small leak it looks like water is dripping from it
Not enough information to fully answer question.
Control valve is usually associated with the gas line and gas control valve.
There should not be water dripping from control valve.
Open following link to help identify source of leak on tank-type water heater
http://waterheatertimer.org/Water-heater-is-leaking.html
If you are uncertain about parts on gas water heater, I suggest calling service technician.
There are several advantages. The technician can service the appliance and ensure there is no dangerous gas leaks or dangerous CO vent leaks.
And if your water heater is rusted and leaking, then service technician can prevent a possible flood.
Some gas is heavier than air and settles to floor, so always check for gas smell near floor level.
The combustion product from a water heater contains odorless CO which is poisonous, and must be vented outdoors so it will kill other things besides you.
The service technician can also see maintenance issues since gas water heaters require yearly maintenance, and some require more frequent attention.
Finally the service technician can give you a few tricks and tips for taking care of your water heater.
If you add a comment with the brand, type and model number of water heater, I can possibly locate a manual for that product which can help both you and me understand your water heater better.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 21, 2011 | Water Heaters
I have a Rheem Tankless Indoor RTG-74-PVN-2 that has been shutting off every now and then we would pull the power cord and wait for a few seconds and connect it back and wait for a seconds and push the...
Before calling service technician, open following link for Rheem troubleshooting resources:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Read manual for troubleshoot and yearly maintenance steps.
Repair most tankless problems yourself, same day, any brand for about $330
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Upvote the help.
May 08, 2011 | Heating & Cooling
Code A2 can I fix or do I need a plummer?
Generally, the easiest solution for Tankless problems is call service technician who can give tips and tricks for maintaining water heater. Tankless require yearly maintenance which offset promised energy savings of $8 to $100 per year over tank-type heaters. But tank-type need maintenance too. Save and read manual.
Error code A2 shows 5 initial things to try:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
For Bosch tankless troubleshoot resources including link for finding service technician:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
For Rheem tankless resources:
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
Feb 17, 2011 | Bosch & Tankless LP Hot Water Heater
Leaking water from bottom of inside unit while it is running
It's common problem due to non maintenance. Service your unit frequently, at least once in 4 months.Clean drain pan too.
Dec 06, 2010 | LG LA141CE Split System Air Conditioner
. I bought an Amcor AWS090HR a couple of years ago
?Call pridiom group 201-266-8234 option 2 for warranty and service
?*Self Diagnosis Functions*
Our company provides the thoughtful services for customer,air conditioners had been
installed self diagnosis system to display the information for the units.
INSTALLATION & REPAIR GUIDE
Split Wall-Mounted air conditioner
8
*According to the service conditions and operating environment , the inside of the air conditioner
will become dirty after several seasons (3 to 5years ) of service , resulting in decreased operating
performance .Inspection and maintenance are recommended in addition to usual cleaning (The
air conditioner can be used for a longer period and without anxiety .)
*As to inspection and maintenance , consult your dealer or any one of business offices of dealing
companies .(Service charge is required in this case .)
*We recommend to perform inspection and maintenance during an off seasons.
*Choose the place where hot air and operation noise from the outlet of the outdoor unit do not annoy
the neighborhood .
*Things left near the outlet and inlet of the outdoor unit cause malfunction or increased operation
noise . Do not leave obstacles near the outlet and inlet .
*If irregular sound is heard during operation , consult with your distributor .
*Inspection and Maintenance
Note:Above self check information is commonly applicable in our most air conditioners,but some
are special,you can refer to the User's Manual for information or contact the dealer or authorized
maintenance people for help.
Digital self-check code/
(Polychrome screen self-check code)
Hint to defrosting Flicker 1 time/1s
Hint to defense
against cold wind Flicker 1 time/3s
Failure of room
temperature sensor
Failure of coiled
pipe sensor
Abnormality of
outdoor unit
Without feedback of
internal fan motor
Zero crossing signal
without current
External feedback
failure
Overheat protection
Water pump failure
Self-check code of luminotron/
(Self-check code of running lamp)
Flicker 2 times/4s
(Flicker 2 times/8s)
Flicker 3 times/5s
(Flicker 1 time/8s)
Flicker 4 times/6s
(luminating)
Flicker 5 times/7s
(Flicker 6 times/8s)
Flicker 6 times/8s
Flicker 7 times/9s
Flicker 8 times/10s
Flicker 9 times/11s
Self-check
information
Indicates "dF"or defrosting
indicator displays
Fan motor picture not running
E2/(L2)
E3/(L1)
E4/(E5)
E5/(L6)
E7
E6
E8
E9
Nov 30, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
I have an LG LWHD2500ER wall air conditioner about 2-4 year old. The digital read out comes on but the unit will not come on.
The unit isn't kicking out any water. And its not cooling like it normally does. How can I fix this issue?
Oct 15, 2010 | LG LWHD2500ER Wall/Window Air Conditioner
Air condition cleaning
hi! there,
if your unit is almost five years from now,its more convenient to have a maintenance schedule every two to three time a year,if this a windows type,cleaning of ac unit mostly the eveporator and condenser should free from dust,upon installing,the a/c unit should be eleveted down on condenser,the tray should have a drain with hose to drip the water outside your room,so that water will not leak on your light,see this may cause electrical fault resulted on burning.have always clean the filter.try to inform the maintenance crew to elevate the condenser portion down gradually so that water will drip outside the room.have anice day,don't forget get to rate me,and thank's a lot.
Apr 26, 2009 | Heating & Cooling
DeLonghi portable airconditioner leaking water
nbenz ,
Welcome to fixya.
I'm Huuum and happy to assist you,
Portable units are supposed to spray the water on to the hot compressor an evaporate the water!
If it is only 3 weeks old ,you have a 1 year warranty. call service and let them fix it for !
Please remember to leave a rating before you go!
Thank you
Aug 26, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Samsung air conditioner AW0528
The company I work for has been servicing Samsung brand air conditioners for years. I myself am somewhat of the expert. We're called ABS Air Conditioning. I've got a pretty good idea as to what could be the problem but if possible I'd like to ask you a few more questions. Give me a call at our business and I'd be happy to help you even more. We're located in Clearwater, Florida and my number is 727-608-1251
Wes
Jun 09, 2008 | Samsung AS18A6RB Air Conditioner
FIX AC
contact the air conditation guy as the procudes of filling the gas can be only handled by an expert.
Hope this was helpful.
Jun 08, 2008 | LG LXA1230ACL Air Conditioner
LG LS-L1210CL Mini Split Air Conditioner Logo
367 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
