Question about Maytag SkyBox MBV1976A Beverage Dispenser
Bypass the flipper door sensor?
How can you bypass the flipper door sensor? it has 3 wires (1,2,and 3) Can you wire the sensor out?
  • pigdawg May 31, 2008
    I have the same problem with mine.it has actually burnt the wiring.i was wondering if there was a wiring diagram of the skybox, so i can bypass this.My em address is pig1dawg2@msn.com..
    thanx
    wade shankoff
  • 221 Answers
The flipper door switch is there to prevent a second beverage from being dispensed before the first one has been removed. Broken bottles would be the result. The switch consists if a very small magnet in the flipper door, and a small circuit board with a hall effect sensor. Verify the magnet is there. Unplug the Skybox and carefully remove the circuit board. You will see corrosion from the moisture on the board. Use a small stiff brush with a water and baking soda solution to remove the corrosion. The board, except for the sensor at the edge of the board, can be lightly coated with blue electrical silicone (found at any auto parts store) to prevent the corrosion from reoccurring. Replace the board and enjoy. I hope this helped.
Posted on Apr 26, 2015
    New Friend:
Can you bypass the switch
Posted on Apr 23, 2015
3 Suggested Answers
donna35657
SOURCE: where can I find a maytag flipper door sensor?
I just wanted to post how I repaired my flipper sensor board (11001182 ) for my Skybox Beverage Dispenser to help the next person looking for this impossible to find part. I repaired mine by removing the flipper sensor board and replaced the Hall Effect switch (looks like a transistor) with another one using part number A3213EUA-T (google it. Its also available on Amazon funny enough). If you are handy with a soldering iron this is an easy fix. On mine the circuit trace near the screw through hole on the circuit board was also damaged so I soldered a wire across it after scraping it clean. I then coated everything with black silicone glue to help keep the moisture under control and put it back in. Works perfectly.
Posted on Jun 15, 2014
  • 5 Answers
I thought I had a flipper door sensor problem but what was actually wrong was the magnet was missing from the door that tripped the sensor. That was a fun $4 magnet purchase.
Posted on Mar 12, 2010
Power loss - anti theft
Depends on Which Model you have.
Jul 14, 2008 | 1996 Chrysler Cirrus
What are the probable causes of DTCs P0030, P0039, P0074, and P0098?
code p 0030 refers to heated oxygen sensor (HO2S) 1 bank 1 -heater control-circuit malfunction
code p 0039 refers to turbo/super charger bypass valve , control circuit --range /performance problem===causes --wiring--- bypass valve
code p 74 refers to outside air temperature sensor--circuit intermittent===causes ---wiring---poor connection---out side air temp sensor---ECM
code p 0098 refers to intake air temp (IAT) sensor 2 --circuit high input===causes --wiring short to positive ---IAT sensor---ECM
Nov 23, 2015 | 1994 Cadillac DeVille
Lambda sensor signal wire
If u mean bypass as in putting a new wire in, I'd be in plugging the Ecu connector and lambda sensor then running a simple test to make sure u got the right wire , a four wire lambda is 2 heater wires usually the same colour which when on is positive 1 5v Ecu feed and a earth
Jun 27, 2015 | 2003 Chrysler Voyager
The part I need for my Maytag Skybox is NO LONGER AVAILABLE! UGH!!! Part# 11001182 Door Flipper Sensor. Is there a way to "short out" the old sensor so that it "always" shows the door in the proper...
You can not short it out as the purpose is to tell the board that a dispensed beveraged has been removed from the bin. It will not dispense another beverage until the signal is received. The danger could be a second "glass" bottle coming down into one in the bin and breaking. The small board can be removed, cleaned with a very small stiff bristled brush, then reinstalled. It contains a hall effect sensor that reacts to a magnet in the flipper door.
Aug 08, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
I am trying to locate the starter of my 1998 LS 400 pls. help me.
The starter is located under the intake manifold on this engine.
Jun 17, 2009 | 1998 Lexus Gs 400
1990 buick lesabre - 3.8 liter. won't start, it's not firing.Is there anyway to bypass the camshaft sensor or crankshaft sensor. And should the coil pack have 2 hot wires going to it with the ignition on...
no u cannot bypass the sensors 1 hot and 2 signal wires. test the sensors if u got no spark from any coil and the sensors are good replace the ignition controlle modgule... the coils are mounted on top of it
dont forget to rate me
Dec 10, 2008 | Buick LeSabre Cars & Trucks
Maytag SkyBox MBV1976A Beverage Dispenser Logo
344 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
