Question about Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
My television keeps turning on and off, After turning it on the tv stays on for about 30 seconds and I receive both picture and sound, and then it turns off and restarts again, this cycle happens over and over. The tv basically turns on and off by itself.
  • paras916 Oct 04, 2010
    Do you know what specifically I need, when you say lamp am I purchasing just the light bulb. Can you please refer me to any websites or places where I can purchase this part
  • 10,594 Answers
This is symptom of weak lamp in tv that has reached to end of its working hours life span, replace lamp in tv to solve its issue.
Lamp is not dead/ broken yet but weak in result and causing above said problem.
Please buy Sony original lamp for good quality picture in tv.
Lamp replacement process is easy and written in user manual copy, click This Link to download user manual copy if required.
Thanks.
Posted on Oct 04, 2010
  • Shahid Electronics
    Shahid Electronics Oct 04, 2010
    OK, my reply is for Sony KDF-55XS955 model tv as its shown in question heading. If your tv model number is other than that, let me know before to order lamp/bulb.
    Required lamp part number is as follows:
    A1085447A
    LAMP BLOCK ASSY XL2200U
    and available in Sony Part Store.com for $200
    below is lamp image
My sony grand wega 55 constantly will turn off picture and sound, green lamp light stays green and then after about 30 seconds the picture and sound return, it has the original bulb in the tv and is around...
The LED light "LAMP" indication stay on or flashes in this problems?Yes,the projection lamp is the causes and problems.Change the projection lamp,should solved the problems.
Jan 30, 2011 | Sony KDF-E55A20 55 in. LCD Television
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
We keep losing sound and picture on our TV
If you haven't replaced the lamp, it is almost certainly time to change it. A weak lamp will cause the TV to play for a short time. As the old weak lamp heats up, it draws more current, and the reflector in the lamp, having become cloudy over time, converts the light into more heat rather than reflected it out into the set. Eventually the lamp draws too much current and the set turns it off, going into a restart cycle. Buy an original Sony lamp, as the aftermarket replacement lamps are known trouble makers. Be sure to rate this solution. Thanks!
Nov 13, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Loses Picture, Goes Black... Sound stays on
Sounds like power supply. Probably time for a new tv. You have already got almost 20 years service.
Dec 05, 2017 | RCA F36685 36" TV
SONY Projection TV keeps turning off.
Our Sony TV kept going on and off too. Repairman replaced the lamp, even though red light was never on. Problem solved.
Sony support insisted it was not the lamp if red lamp light was not on. Don't believe it. Picture and sound would go on for 30 seconds, then off for 30 seconds. The new lamp did fix the problem.
Jul 12, 2008 | Televison & Video
Tv turns off then on then off then on
I Just had the same problem. Had the LAMP changed work fine now. Just had it done today
Oct 24, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
