Question about Kenmore 79383 Dual Fuel (Electric and Gas) Kitchen Range
I have a kenmore elite dual fuel range model 790-79463600. When oven is on broil or bake there is no heat at all. When the convection oven is activated it gets to a little over 100 degrees at best. Also posible related is that the ignigor for the stove top will not fire unless the oven is on. These problems seemed to have occured after removeing and replaceing the circuit breaker for the stove. Dont know if its realted. I have 240v going to the stove. im wondering if there is some type of fuse or breaker in the stove thats only allowing 120v rendering the ignightor and oven unworking. Im not getting any error codes. Any help or thoughts are appreciated. Sincerley, Rick
erpaalai
  • 999 Answers
SOURCE: stove top
Please supply the model number.
Eric
Posted on Jun 28, 2009
milten1
  • 1304 Answers
SOURCE: I have a Kenmore electric
sounds moree likely that you lost one side of your power
check your voltage at the outlet
l1 to ground 120
l2 to ground 120
l1 to l2 220
Posted on Oct 05, 2009
SOURCE: The oven of my kenmore dual fuel range will not heat.
Check to be sure that your 220 breaker isn't tripped or 220 fuses blown. I had the same problem. Fuse panel runs on 110, ovens are 220. I changed the 220 fuses and all works fine now. Good luck!
Posted on Nov 28, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Kenmore elite range, model 970-698593, Error Code E015
Just asking if your model number is correct. I do not find 970 models but do find 790 models. If it is a 790 model there can be aproblem with the door lock on the oven door. You may want to check to see if all the shipping materials have been removed from the door lock / latching area. I would recommend that you review the installation instructions in the owners manual, paying particular attention to the removal of shipping materials.
Adittionally if the problem presists it says to replace the Electronic Range Control (ERC) This is not a cheap part! Good thing it will be at their expense including the repair service call..
Hopefully you have already called for warranty service? We both know a brand new oven should not be producing any error codes. If you have not called for warranty service you do so now. Make sure to tell them that you already have talked to customer support and that unplugging the unit for ANY period of time made no difference in the error code.
Thanks for choosing FixYa.
Kelly
Posted on Aug 01, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore range oven model 880, broil element stays on
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 23, 2010
Oven quit, bake not working, replaced thermostat, now broil works, still no bake
Your problem may be the bake relay on the clock or wiring.try changing that
Aug 12, 2008 | Viking VDSC307-4B Dual Fuel (Electric and...
How can I get a user manual for my Kenmore Elite 30 inch Electric slide in range with ribbon radiant elements model number 46804
Kenmore Elite Electric Slide In Range 30 in. 41053 - Sears
www.kenmore.com/kenmore-elite-30inch-slide...electric-range...
Kenmore
Rating: 3 - ‎30 votes
The slide-in Kenmore Elite range 41053 has a true convection oven for faster pre. ...Kenmore Elite 30" Slide-In Electric Range w/ Convection - Stainless Steel ... Owners manual - English (Warranty) .... I called SEARS repair to look at my range and the repairman told me that this range has flaws with the oven fan and there is ...
Kenmore Elite 30" Double-Oven Slide-In Electric Range w
www.kenmore.com/kenmore-elite-30inch...slide...electric/p-02...
Kenmore
Rating: 3.5 - ‎30 votes
The exciting Kenmore Elite double-oven slide-in range 4111 offers all the feature. ... Versatile cooktop options include a 12-inch triple-ring element, a 9-inch Turbo Boil Flex™ element, and a ... Owners manual - English (Warranty) .... Ovens are both conventional or can be set to convection, my first bake was a cheese cake.
Nov 28, 2015 | Kenmore Kitchen Ranges
Will a plain fan convection/microwave ROAST/BAKE as well as a "true" convection that has an extra heating element and fan convection/microwave
Most likely the Kenmore is actually made by Sharp. Most of the combination microwave/convection ovens are. I have one with a "Wolf" name on it, and it roasts/bakes very well.
Apr 07, 2015 | Kenmore Kitchen Ranges
Hello Gene I have a fridgaire plcf489ccf Dual fuel 40 inch range. When in bake or convection mode the oven does not come up to selected temp. i have replaced the probe . It can take an hour to get up to...
Hey Joe,
What ya would need to check for is see their is 240 volts power going into the oven,the radiant bake element and the convection bake element are 2 different elements so i doubt that both of them are bad at the same time, (have ya checked on the broil to see if it heats quickly?) if the broil heats up fast i would say the incoming voltage is ok and would be looking to the control board as being the problem since ya have already replaced the thermostat. If ya have a volt meter you could set the oven to bake and see if 240 is at the bake element of if its less and being restricted by a burnt relay on the control board.
GENE
Oct 17, 2011 | Kitchen Ranges
Kenmore dual fuel oven model 79075503201. bottom element in oven will not heat. element has a resistance of about 22 ohms. 110v on each leg while off. 110v on each leg during bake cycle. I suspect the...
It seems that the control board is faulty. You would need to get the board repaired since it is no longer available for purchase from the manufacturer. You get the board fixed from www.partsimple.com at the lowest price compare to the rest of competitors online.
Here is the direct llink to the control board: http://www.partsimple.com/318010102-frg-r-12.html
Frigidaire Range Control Board Repair Service 318010102
Mar 15, 2011 | Kenmore Elite Stainless Steel 40" Dual...
The oven function (broil, bake, etc) knob does not light
Open high limit or bad relay most likely.
The relays are located on the back side.
The limit I am not sure where it is stashed.
Sep 08, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Viking Dual Fuel 6 Burner 48" OVEN DOES NOT HEAT
I hate self clean functions - If you think about it - you should too. These ranges are equipped with electronic components and running self clean at 950 degrees will more than likely burn something out. A lot of complaints are because of the self clean. It's not worth it to self clean than to clean it yourself. And 200 dollars is a great price for something like this if it includes parts and labor. Good luck.
Nov 25, 2007 | Viking VDSC365-6B Dual Fuel (Electric and...
Kenmore 79383 Dual Fuel (Electric and Gas) Kitchen Range Logo
233 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
