Question about Proscan PS32500 32" TV
Proscan TV Our TV does not have any audio output. It happened suddenly. Cable is fine, Tivo is fine and we can play DVDs. Any suggestions on what may be wrong? Is it worth repairing?
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 92 Answers
Maybe, but I would first go into menu and look at audio settings and make sure speakers are on internal and not external or turn off.
Also just unplug for an hour and restart unit. Lastly, it may be cheaper to just attach a 100.00 surround sound system for audio.
Craig www.classtorations.com
Posted on Jun 08, 2008
Proscan tv
Restart the tv, also check that its geting video input / signal. basicly double check all cables and restart it also try unpluging it for a while and try again.
Jul 24, 2008 | Proscan 32LA30Q Television
Tivo turns off TV
For some reason your Tivo is tripping the internal breaker of your TV. Check the cables and see that they are not damaged and are connected properly (all the cables that hook up to the Tivo). If you have a spare set of cables, try them to see if the TV still turns off.
Jan 01, 2008 | Tivo Series 2 80-Hours Video Recorder
No video from an Apex digital converter box to TIVO
You may have to set the channel 3/4 switch on the lower right rear of your TiVo to match the output setting of your Apex converter. If your Apex converter is equipped for L/R audio and video output you will get better results using a three-conductor cable to connect to your TiVo.
Dec 08, 2013 | Toshiba DVD Recorder AND Series2 TiVo...
Sony DVD Player worked fine forever, suddenly gets 'No Signal' on
check the video is going from output on the dvd player to the input of the tv. Good Luck.
Nov 12, 2009 | Televison & Video
TIVO output is black and white only.
To solve this problem, I powercycled my TIVO.
Sep 17, 2009 | Humax DRT800 TiVo 80-Hours Video Recorder
Trying to program my Directv (tivo) remote to new Proscan 32" tv. The codes from directv don't work. Any suggestions?
I read another post where they added 1 to make the code 5 digits. Use 01331 and try it, it worked on my Directv Tivo remote and Proscan 32".
Aug 01, 2009 | Proscan 42LA30H 42 in. LCD Television
Proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Jan 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Motorola DCT 6200/1000 seems to only have one audio output?
There are three options:
1) Connect the Tivo using the coax output of the cable box into the cable input of the Tivo
2) Exchange cable boxes with your cable provider for one with composite output jacks. It may require you to use a Motorola box that isn't High def depending on what your provider has. I know Comcast has a Motorola HD tuner that has composite outputs as well as component.
3) Upgrade to a Series 3 Tivo. Those units are designed for High Def. Use HDMI cable hookup.
Jan 17, 2009 | Arris DCT6200 DTV Receiver
Connecting my Humax Series 2 Tivo to a Motorola HD DCH3416 Cable Box
Yes, the Tivo will just record in standard definition, instead of high def.
You can still hook the two up together, though.
What I would suggest (and have done in the past) is this:
Split the cable coming out of the cable box.
Hook one up to your HD cable box, and the other up to the Tivo.
Hook the output of your HD cable box to one HD input on your TV
Hook the output of your Tivo up to a different (non-HD) input on your TV.
This will allow you to watch HD while recording standard definition, and vise versa.
Running the HD through the Tivo will work, but will limit you to not be able to watch HD through it.
Aug 10, 2008 | Humax DRT800 TiVo Video Recorder
Proscan PS32500 32" TV Logo
2,129 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
